Libraries in Libraries?
Hey All,
I’m writing some software to make my Arduino control a 3 axis cartesian bot (think CNC machine). Anyway, here’s the basic setup that is causing me problems:
I have 3 classes:
  1. LinearAxis
  2. LimitSwitch
  3. RepStepper (my version of the stepper class)
i want the LinearAxis class to have a RepStepper instance and two LimitSwitch instances. I’m getting this error:
LinearAxis.h:18: error: ‘RepStepper’ does not name a type
LinearAxis.h:20: error: ‘LimitSwitch’ does not name a type
LinearAxis.h:21: error: ‘LimitSwitch’ does not name a type
I’m somewhat inexperienced when it comes to C++, but I have tons of experience programming PHP and OO design, so i’m guessing its some sort of syntactical thing I’m missing.
the code is all located here: http://reprap.svn.sourceforge.net/viewvc/reprap/trunk/users/hoeken/arduino/
the sketch is located here: http://reprap.svn.sourceforge.net/viewvc/reprap/trunk/users/hoeken/arduino/firmware/HoekensCustom/
thanks in advance for your help.
~Zach
You need the right #include's within the library (i.e. LinearAxis.h should include RepStepper.h), and you need to have #include's for all the libraries in your sketch.
yay! that worked.
now i have another problem:
In function 'void setup()': error: request for member 'x' in 'bot', which is of non-class type 'CartesianBot ()()'
here's the code i'm trying to do:
//init our steppers
      bot.x.stepper = RepStepper(X_DIR_PIN, X_STEP_PIN);
      bot.y.stepper = RepStepper(Y_DIR_PIN, Y_STEP_PIN);
      bot.z.stepper = RepStepper(Z_DIR_PIN, Z_STEP_PIN);
basically, i have a CartesianBot class that contains 3 LinearAxis instances which each contain a RepStepper and 2 LimitSwitch instances. Any ideas on how I would go about that so I can initialize them at runtime?
Now you're getting to the fun parts of C++. It gets a little strange, but not too bad. You need to do something like this:
In LinearAxis.h:
class LinearAxis { public: LinearAxis(int dir_pin, int step_pin, int min_pin, int max_pin); private: RepStepper stepper; LimitSwitch min_switch, max_switch; };
In LinearAxis.cpp:
LinearAxis::LinearAxis(int dir_pin, int step_pin, int min_pin, int max_pin) : stepper(dir_pin, step_pin), min_switch(min_pin), max_switch(max_pin) { // any other initialization }
Basically, constructors can't be called in the middle of code, but only when you're declaring a variable or in the weird syntax above where they hang off the end of another constructor.
I just wrote a simple introduction to writing Arduino libraries, I think this could be a good topic for the advanced tutorial. :)
okay, i think i get it... so basically whats happening is that with that funky syntax, when i do something in my main sketch like this:
LinearAxis x(dir_pin, step_pin, min_pin, max_pin);
it would then internally call the LinearAxis constructor, as well as the stepper, min/max switch constructors, etc? i'm gonna give that a try! i'll report back here when/if i can get it working!
thanks mellis!
Exactly. I hope it works. Let us know if you have any problems.
yup, that worked!
now, the only thing that i need to figure out is how to do the microsecond resolution for my steppers =)
