I am trying to use the DMXSerial2.h library, which uses the Serial to send the DMX data to the shield.
I would like to also use the SevenSeg.h library, but those don't work along. I am asuming that is because both libraries are using the serial. Is there a way to built around this problem? I can include the code if needed
Post a link to where you got the libraries from. Please use the chain links icon on the toolbar to make it clickable. Or if you installed it using Library Manger (Sketch > Include Library > Manage Libraries) then say so and state the full name of the library.
Hans-Adolf:
Please explain exactly what you mean by "don't work". Are you encountering a compilation error or does the code compile and upload fine, but then not work as expected?
The DMXSerial2 (by Matthias Hertel) is installed via Manage Libraries.
pert:
When compiling, I get this error:
HardwareSerial0.cpp.o (symbol from plugin): In function `Serial':
(.text+0x0): multiple definition of `__vector_25'
libraries\DMXSerial\DMXSerial.cpp.o (symbol from plugin):(.text+0x0): first defined here
c:/users/nicoas/appdata/local/arduino15/packages/arduino/tools/avr-gcc/4.9.2-atmel3.5.4-arduino2/bin/../lib/gcc/avr/4.9.2/../../../../avr/bin/ld.exe: Disabling relaxation: it will not work with multiple definitions
(.text+0x0): multiple definition of `__vector_26'
Anyway, I think the problem has absolutely nothing to do with the SevenSeg library. It's caused by using DMXSerial2 library and Serial at the same time. Here's a minimal demonstration:
pert:
You said you were using the DMXSerial2 library.
Oooops, I was messing around with the DMXSerial to find out if it changes anything and forgot to change it back..
pert:
Deactivated all Serial. Sadly, that didn't help
oqibidipo:
Then you can edit DMXSerial2.cpp to use Serial1
