retrolefty:
Well i recall the IDE developers did spend a lot of time explaining and warning of the then upcoming IDE 1.0 and the things it would break. They felt is was important at the time to make the changes to move the IDE from beta to 1.0 and I do think they made a commitment to not force such drastic changes in the future. However one can never make everyone happy all the time and I'm sure there will be those that felt they did more harm then good when moving from beta to 1.0.
That is not my recollection of what happened at all.
I would totally disagree that they spent a lot of time explaining and warning, and
more importantly considering the full implications of this "break the world" decision.
Before the changes were made, several of the higher level 3rd party developers,
brought up how it would break 100% of the 3rd party libraries and recommended against handling it the way
the Arduino team wanted to do it.
The 3rd party developer stance was that there were better ways to handle it by including some backward
compatibility support such that the vast majority of libraries could transparently continue to work
"as is" using some behind the scenes compatibility defines, headers, and macros.
Some libraries would immediately break since you couldn't provide backward comparability for everything,
but the vast majority could continue to work, "as is", with no changes, using the backward compatibility.
It was a very very small amount of changes, and the work had already been done.
All that had to be done was to roll it into the official release.
The Arduino team stance was that they wanted the 3rd party developers
to change their code as fast as possible to the "new way" of doing things,
and thought it was a desirable feature to break 100% of the code, since that would force all
the authors to convert their code quicker and the net result would be that all the 3rd party
libraries would be fully converted over sooner.
The Arduino team put no weight on backward compatibility, nor on the support effort that
breaking 100% of the existing libraries would create.
If you search the issues list, you can find their comments, and they consciously decided
to break 100% of the existing 3rd party libraries rather than provide any sort of backward comparability.
They flat rejected providing any backward compatibility and moved forward knowingly and consciously
deciding to break 100% of the existing 3rd party library code base.
To make matters worse, they made the changes after the s/w was already in release candidate state
just before the actual 1.0 release. There was no time allocated for a beta of these changes
much less an RC after these drastic changes were made.
There was a limited release available if you followed the developer forums but it was not generally available and wasn't announced.
This really limited the audience for it.
This is a VERY BAD s/w practice.
This is not a normal s/w release process. Normally, you don't go breaking 100% of your existing
code base that has been very stable for several years between the final release candidate the final release.
If you made that sort of a drastic change, it should knock the release cycle back to beta for while
to allow everyone time to recover. Then after a while move back to RC status and final release.
Nope. They didn't do that, they went from an RC directly to a final release that broke the world.
After nearly 3 years, we are still fighting pre 1.x vs 1.x library issues.
In my opinion, this "break the world" stance was a terrible decision and showed
an immaturity with respect to s/w design and release processes.
If you happen to have a Teensy product, Paul adds in backward compatibility capabilities for his boards.
so most of the older pre 1.x libraries work when used on a Teensy board.
I've gone in and created half a dozen changes to the Arduino core to allow most of the pre-1.x libraries
to work by providing the trivial backward compatibility stuff that the Arduino team rejected.
In terms of not every doing this again....
If you were following the 1.5 library & directory structure changes that was being discussed about 4-6 months ago,
history was about to repeat itself in that the Arduino team was going to break 100% of all the 3rd party
libraries AGAIN in 1.5x
It wasn't until a very heated discussion ensued about the 1.5x library format,
that some of the Arduino team finally grasped the pain of breaking backward compatibility
for the 3rd party library developers.
The original 1.5x format resulted in two different sets of library directory structures,
and they were not compatible with each other.
i.e. you couldn't load an existing 1.x library on 1.5x
and you couldn't load a new 1.5x library on to 1.x
They were living in bubble where everything is released at once and once they did a release, they never looked
back at previous releases and so they never had these sorts of compatibility issues.
Finally, they understood and grasped how the 3rd party world of thousands of libraries doesn't work that way.
And because of this 1.5x library discussion, the 1.5x library format was relaxed to provide backward compatibility
with 1.x libraries and we so now have a 1.5x that can use the existing 1.x libraries.
Had there not been this heated discussion earlier in the year, we would eventually be having all kinds of library
issues in 1.5x just like like we had with 1.0
--- bill
