Library addition problem
Hello, I am trying to add the radio library to the arduino ide and I am using the Galileo Gen 2 board. I am facing problem . It is not geting added so the library not available error is thrown when compiled. But same thing doesn't happen with the UNO board. Please help.
Please do the following:
  • Copy and paste the full error message. There should be a button that says "Copy error messages" on the right side of the orange bar after you get the error.
  • Click on that and then paste in a post here.
  • Post your code using code tags(</>button).
  • Explain exactly how you installed the radio library. Did you use Library Manager or did you download it from somewhere, if so post a link to where you downloaded it from.
