I'm currently writing an Arduino Library to support xPL protocol (more details there : http://www.mgth.fr).
Cause it is very memory angry, I try to get it configurable.
for now I just have a config.h inside the library folder, but I would like to have configuration sketch dependent. Does anyone have an idea on how to achieve that ?
eh, it seams to work with #define I don't know why when I first tried, I got the feeling that defines declared into main sketch were not taken into accounts inside libraries cpp, but your right it is. I'm gonna do that.
does any body know if this is a normal c++ behaviour or a special Arduino magic ?
If you define things before including a file, the included file will have the defines in scope. They are valid with in the defining translation unit ( .cpp/.ino file being compiled + all code inside of #include files )
Is normal behaviour ( although IDE may have ordered things in such a way that a non working design will work ), consider a #include as literally pasting the included file's contents into the file being compiled.
Ahh yes, the cpp file for the library will be compiled before any file includes the library header. You would need a global header like global.h that the library and your code ( sketch includes first ) so the #defines are taken into account before compiling the library .cpp.
I think passing a struct of values is adequate ( not really much different that having a constructor with a lot of parameters ). And if there are a lot of options/settings, you could store the struct in program memory and pass the PGM pointer to the library for it to handle data access, but easier is having a predefined struct as a data member then if a user provides one in a constructor, copy the values into the struct member to overwrite the default values.
