Library conflicts
a relative newcomer to arduino has encountered a problem
When calling the second Arcnet library(Artnet Arnet;) the scan library stops working(E131 e131;) the signal simply stops receiving
files .h attach i use arduino Uno separately, both libraries work fine
How can I call Artnet Arnet; "separately" from all the code,
My task is to have sACN called when the button is pressed and when the button is not pressed ArtNet is called
#include <E131.h>
#include <SPI.h>
#include <Ethernet.h>
#include <Wire.h>
#include "src/Artnet/Artnet.h"
#include "src/Artnet/Packets.h"
#include "src/Conceptinetics/Conceptinetics.h"
#include <EEPROM.h>
LiquidCrystal_I2C lcd(0x27, 16, 2);
DMX_Master DMXMaster( 512 , 2 );
int def = EEPROM.read(1);
E131 e131;
-->//Artnet Arnet;
IPAddress IP(192,168,50,177);
IPAddress subnetMask(255, 255, 255, 0);
byte mac[] = {0xDE,0xAD,0xBE,0xEF,0xFE,0xED};
IPAddress gateway;
IPAddress dns;
byte artnetNet = 0;
byte artnetSubnet = 0;
byte artnetUniverse = 1;
char shortName[18] = "Arduino Art-Net";
char longName[64] = "Arduino Art-Net Node";
    lcd.init();
    lcd.backlight();
    lcd.setCursor(2, 0);
    e131.begin(mac,  IP, subnetMask, gateway, dns);
    DMXMaster.enable();
    /* Parse a packet */
    uint16_t num_channels = e131.parsePacket();
    /* Process channel data if we have it */
    if (num_channels) {
        for(int i = 1; i <= 512; i++ ){
    DMXMaster.setChannelValue (i, e131.data[i-1]);
        lcd.print(e131.data[0]);
#define ARTNET_H
#include <Arduino.h>
#include <EthernetUdp.h>
#include <string.h>
#include "Packets.h"
#define ARTNET_PORT 6454
// OP Codes
#define OP_POLL 0x2000
#define OP_POLL_REPLY 0x2100
#define OP_DMX 0x5000
// Error Codes
#define ERR_PACKET_DIMENSION 0x1000
#define ERR_NOT_ARTNET 0x1001
#define ERR_NOT_EXISTING_OPCODE 0x1002
#define ERR_OLD_PACKET 0x1003
#define ERR_WRONG_UNIVERSE 0x1004
#define MAX_ARTNET_BUFFER 530 // 18 (Art-Net Headers) + 512 (DMX Channels)
#define ARTNET_ID "Art-Net\0"
#define ARTNET_DMX_START 18 // Start point for dmx data in the Art-Net packet
#define ARTNET_HEADER 17 // End point for Art-Net header
class Artnet {
  public:
    Artnet();
    void begin(byte mac[], byte ip[], byte subnetMask[], byte _artnetNet, byte _artnetSubnet, byte _artnetUniverse);
    void begin(byte mac[], byte ip[], byte subnetMask[], byte _artnetNet, byte _artnetSubnet, byte _artnetUniverse, char _longName[64]);
    void begin(byte mac[], byte ip[], byte subnetMask[], byte _artnetNet, byte _artnetSubnet, byte _artnetUniverse, char _longName[64], char _shortName[18]);
    void setArtnetNet(byte _artnetNet);
    void setArtnetSubnet(byte _artnetSubnet);
    void setArtnetUniverse(byte _artnetUniverse);
    uint16_t read(uint8_t data[]);
    void sendArtPollReply();
  private:
    EthernetUDP Udp;
    char shortName[18] = "Arduino Art-Net\0";
    char longName[64] = "Arduino Art-Net Node\0";
    IPAddress broadcast;
    uint8_t artnetPacketHeader[ARTNET_DMX_START];
    uint8_t lastSequence;
    byte artnetNet = 0;
    byte artnetUniverse = 0;
#endif
* E131.h
* Project: E131 - E.131 (sACN) library for Arduino
* Copyright (c) 2015 Shelby Merrick
* http://www.forkineye.com
*  This program is provided free for you to use in any way that you wish,
*  subject to the laws and regulations where you are using it.  Due diligence
*  is strongly suggested before using this code.  Please give credit where due.
*  The Author makes no warranty of any kind, express or implied, with regard
*  to this program or the documentation contained in this document.  The
*  Author shall not be liable in any event for incidental or consequential
*  damages in connection with, or arising out of, the furnishing, performance
*  or use of these programs.
#ifndef E131_H_
#define E131_H_
#include "Arduino.h"
#include "netconv.h"
/* Network interface detection.  WiFi for ESP8266 and Ethernet for AVR */
#if defined (ARDUINO_ARCH_ESP8266)
#   include <ESP8266WiFi.h>
#   include <ESP8266WiFiMulti.h>
#   include <WiFiUdp.h>
#   include <lwip/ip_addr.h>
#   include <lwip/igmp.h>
#   define _UDP WiFiUDP
#   define INT_ESP8266
#   define INT_WIFI
#elif defined (ARDUINO_ARCH_AVR)
#   include <Ethernet.h>
#   include <EthernetUdp.h>
#   include <avr/pgmspace.h>
#   include <utility/util.h>
#   define _UDP EthernetUDP
#   define INT_ETHERNET
#   define NO_DOUBLE_BUFFER
#endif
/* Defaults */
#define E131_DEFAULT_PORT 5568
#define WIFI_CONNECT_TIMEOUT 10000  /* 10 seconds */
/* E1.31 Packet Offsets */
#define E131_ROOT_PREAMBLE_SIZE 0
#define E131_ROOT_POSTAMBLE_SIZE 2
#define E131_ROOT_ID 4
#define E131_ROOT_FLENGTH 16
#define E131_ROOT_VECTOR 18
#define E131_ROOT_CID 22
#define E131_FRAME_FLENGTH 38
#define E131_FRAME_VECTOR 40
#define E131_FRAME_SOURCE 44
#define E131_FRAME_PRIORITY 108
#define E131_FRAME_RESERVED 109
#define E131_FRAME_SEQ 111
#define E131_FRAME_OPT 112
#define E131_FRAME_UNIVERSE 113
#define E131_DMP_FLENGTH 115
#define E131_DMP_VECTOR 117
#define E131_DMP_TYPE 118
#define E131_DMP_ADDR_FIRST 119
#define E131_DMP_ADDR_INC 121
#define E131_DMP_COUNT 123
#define E131_DMP_DATA 125
/* E1.31 Packet Structure */
typedef union {
    struct {
        /* Root Layer */
        uint16_t preamble_size;
        uint16_t postamble_size;
        uint8_t  acn_id[12];
        uint16_t root_flength;
        uint32_t root_vector;
        uint8_t  cid[16];
        /* Frame Layer */
        uint16_t frame_flength;
        uint32_t frame_vector;
        uint8_t  source_name[64];
        uint8_t  priority;
        uint16_t reserved;
        uint8_t  sequence_number;
        uint8_t  options;
        uint16_t universe;
        /* DMP Layer */
        uint16_t dmp_flength;
        uint8_t  dmp_vector;
        uint8_t  type;
        uint16_t first_address;
        uint16_t address_increment;
        uint16_t property_value_count;
        uint8_t  property_values[513];
    } __attribute__((packed));
    uint8_t raw[638];
} e131_packet_t;
/* Error Types */
typedef enum {
    ERROR_NONE,
    ERROR_IGNORE,
    ERROR_ACN_ID,
    ERROR_PACKET_SIZE,
    ERROR_VECTOR_ROOT,
    ERROR_VECTOR_FRAME,
    ERROR_VECTOR_DMP
} e131_error_t;
/* E1.31 Listener Types */
typedef enum {
    E131_UNICAST,
    E131_MULTICAST
} e131_listen_t;
/* Status structure */
typedef struct {
    uint32_t    num_packets;
    uint32_t    packet_errors;
    IPAddress   last_clientIP;
    uint16_t    last_clientPort;
} e131_stats_t;
class E131 {
 private:
    /* Constants for packet validation */
    static const uint8_t ACN_ID[];
    static const uint32_t VECTOR_ROOT = 4;
    static const uint32_t VECTOR_FRAME = 2;
    static const uint8_t VECTOR_DMP = 2;
    e131_packet_t   pbuff1;     /* Packet buffer */
#ifndef NO_DOUBLE_BUFFER
    e131_packet_t   pbuff2;     /* Double buffer */
#endif
    e131_packet_t   *pwbuff;    /* Pointer to working packet buffer */
    _UDP            udp;        /* UDP handle */
    /* Internal Initializers */
    int initWiFi(const char *ssid, const char *passphrase);
    int initEthernet(uint8_t *mac, IPAddress ip, IPAddress netmask,
            IPAddress gateway, IPAddress dns);
    void initUnicast();
    void initMulticast(uint16_t universe, uint8_t n = 1);
 public:
    uint8_t       *data;                /* Pointer to DMX channel data */
    uint16_t      universe;             /* DMX Universe of last valid packet */
    e131_packet_t *packet;              /* Pointer to last valid packet */
    e131_stats_t  stats;                /* Statistics tracker */
    E131();
    /* Generic UDP listener, no physical or IP configuration */
    void begin(e131_listen_t type, uint16_t universe = 1, uint8_t n = 1);
/****** START - Wireless ifdef block ******/
#if defined (INT_WIFI) || defined (INT_ESP8266)
    /* Unicast WiFi Initializers */
    int begin(const char *ssid, const char *passphrase);
    int begin(const char *ssid, const char *passphrase,
            IPAddress ip, IPAddress netmask, IPAddress gateway, IPAddress dns);
#endif
/****** END - Wireless ifdef block ******/
/****** START - ESP8266 ifdef block ******/
#if defined (INT_ESP8266)
    /* Multicast WiFi Initializers  -- ESP8266 Only */
    int beginMulticast(const char *ssid, const char *passphrase,
            uint16_t universe, IPAddress ip, IPAddress netmask,
            IPAddress gateway, IPAddress dns, uint8_t n = 1);
#endif
/****** END - ESP8266 ifdef block ******/
/****** START - Ethernet ifdef block ******/
#if defined (INT_ETHERNET)
    /* Unicast Ethernet Initializers */
    int begin(uint8_t *mac);
    void begin(uint8_t *mac,
    /* Multicast Ethernet Initializers */
    int beginMulticast(uint8_t *mac, uint16_t universe, uint8_t n = 1);
    void beginMulticast(uint8_t *mac, uint16_t universe,
#endif
/****** END - Ethernet ifdef block ******/
    /* Diag functions */
    void dumpError(e131_error_t error);
    /* Main packet parser */
    inline uint16_t parsePacket() {
        e131_error_t error;
        uint16_t retval = 0;
        int size = udp.parsePacket();
        if (size) {
            udp.readBytes(pwbuff->raw, size);
            error = validate();
            if (!error) {
                e131_packet_t *swap = packet;
                packet = pwbuff;
                pwbuff = swap;
#endif
                universe = htons(packet->universe);
                data = packet->property_values + 1;
                retval = htons(packet->property_value_count) - 1;
                stats.num_packets++;
                stats.last_clientIP = udp.remoteIP();
                stats.last_clientPort = udp.remotePort();
            } else if (error == ERROR_IGNORE) {
                // Do nothing
                if (Serial)
                    dumpError(error);
                stats.packet_errors++;
        return retval;
    /* Packet validater */
    inline e131_error_t validate() {
#ifdef ARDUINO_ARCH_AVR
        if (memcmp_P(pwbuff->acn_id, ACN_ID, sizeof(pwbuff->acn_id)))
#else
        if (memcmp(pwbuff->acn_id, ACN_ID, sizeof(pwbuff->acn_id)))
#endif
            return ERROR_ACN_ID;
        if (htonl(pwbuff->root_vector) != VECTOR_ROOT)
            return ERROR_VECTOR_ROOT;
        if (htonl(pwbuff->frame_vector) != VECTOR_FRAME)
            return ERROR_VECTOR_FRAME;
        if (pwbuff->dmp_vector != VECTOR_DMP)
            return ERROR_VECTOR_DMP;
        if (pwbuff->property_values[0] != 0)
            return ERROR_IGNORE;
        return ERROR_NONE;
#endif /* E131_H_ */
It is when creating an object that sACN stops working, I have not found any reasons why this may happen.
I'm trying to make a switch between sACN and ArtNet
GitHub - forkineye/E131: E1.31 (sACN) library for Arduino with ESP8266 support - sACN
The library for ArtNet was downloaded from some guide that I can't find because it was two months ago
I've also tried other libraries, but as soon as I create an object, nothing works for me.
To switch between using the E131 and Artnet libraries based on the state of a button, you can structure your code to initialize and handle each library conditionally within the loop function.
The problem is that when I create two objects (sACN and ArtNet) in the same code, both protocols stop working
