I’ve been making an “Ultimate Debounce” library based on the article:
DEBOUNCE YOUR NOISY BUTTONS, PART II by: Elliot Williams
I’m still quite new to Library making, so I took this as a seemingly easy, but useful, learning project.
I have it working just fine, per his article and code.
I’ve also added an overloaded constructor to allow per-object definition of active High or Low for the button signals.
My question come in where I’m wanting to implement his 16-bit History idea (Mentioned but no examples).
As the larger history versions (16-bit, 32-bit , etc) use virtually the same code - the only differences come with storing the history in a ‘larger’ memory type and comparing to a different mask.
I believe I can make it work as a separate standalone, Library, however I was hoping to be able to combine everything into a single class, but I don’t know what the best approach would be.
The code, as it stands, is HERE
I have a couple of ideas, but none of them seem to be any better than the others, from my still-learning hobbyist level of understanding:
I can pass an argument in a constructor and use a variety of IF statements (or similar) to cover the different options.
The only other thing I can think of is to have a seperate class, perhaps UltimateDebounce16 (??), and just copy the same code over, but keep it in the same overall Library.
I recently came across the Idea of namespaces, but haven’t tried playing with them yet.
#1 - Seems awkward and not very elegant. I’d rather make this nice, not just something Hacked together.
#2 - Seems like it would be quite awkward for any updating, as I’d have to do it in two seperate places, and a few functions would be identical between them.
#3 - Seems like it may be possible, but I have no idea if/how this would affect the library size or efficiency.
Is any of my ideas considered ‘Better’ than the others?
Is there an even better way to learn about?
Side question - How do I enter a tab, or indent on this post editor???
Below are just some ramblings that may or may not be relevant …
To save going to the linked Github, here is a small example:
Inside the .h file, I have, among others:
private:
uint8_t _button_history=0;
And within the .cpp file:
#define MASK8 0b11000111 // Mask8 0's are "don't care"
#define DOWN8 0b11111111
uint8_t UltimateDebounce::is_down(void){
return (_button_history == DOWN8);
(I know MASK8 isn’t used in this example function)
With the 16 bit idea, I would need to have:
private:
uint16_t _button_history=0;
#define MASK16 0b1110000000011111 // Mask16 0's are "don't care"
#define DOWN16 0b1111111111111111
uint8_t UltimateDebounce::is_down(void){ // if Button is being held active, return true
return (_button_history == DOWN16);
Ideally, I’d like to be able to use it something like:
UltimateDebounce(uint8_t buttonPin, uint8_t activeLevel, uint8_t historySize);
While still being quick, small, and light on the processor.
With various constructor options, such as:
UltimateDebounce someSW1(someSW1_PIN); // Defaults to active High and 8-bit history, on pin someSW1_PIN
UltimateDebounce someSW2(someSW2_PIN,LOW); // 8-bit history, on pin someSW2_PIN, while Active LOW
UltimateDebounce someSW3(someSW3_PIN,LOW, 16BIT);
(Sorry for not using the code bracket for those last few, but for only a couple of lines, it seems like a huge box on preview.)
