Library declration
Dear all.
I would like to know where the function declaration define for
Serial.print();
digitalWrite();
digitalRead();
all arduino functions defined. I am using windows xp system
Windows or Mac?
Here is a link to the core folder.
You'll find the serial specifics in HardwareSerial.h, HardwareSerial.cpp
print() & println() are inherited by the Print library, you can look in Print.h, Print.cpp (Serial actually inherits the Stream library, which in turn inherits Print)
digitalRead/Write functions are defined in wiring_digital.c and declared in Arduino.h
Although if you wanted to find them on your computer,
If windows, then idk, but this looks promising
If Mac, then go to here
Machintosh SSD ▸ Applications ▸ Arduino ▸ Contents ▸ Java ▸ hardware ▸ arduino ▸ avr ▸ cores
i finally found in core library function In arduino. Thanks for support
