Bonjour,
Je voudrais tester cette bibliothèque mais avec une install neuve d'Arduino 1.8.19 et la bibliothèque je n'arrive pas à compiler avec un ESP32S2
Arduino : 1.8.19 (Windows 10), Carte : "ESP32S2 Dev Module, Disabled, Enabled, Disabled, Disabled, Internal USB, Enabled, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 240MHz (WiFi), QIO, 80MHz, 4MB (32Mb), 921600, None, Disabled"
In file included from C:\Users\admin\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11\libraries\WebServer\src/HTTP_Method.h:4,
from C:\Users\admin\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11\libraries\WebServer\src/WebServer.h:30,
from C:\Users\admin\Documents\Arduino\libraries\ElegantOTA-master\src/ElegantOTA.h:73,
from C:\Users\admin\AppData\Local\Temp\arduino_modified_sketch_65598\AsyncDemo.ino:34:
C:\Users\admin\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11/tools/sdk/esp32s2/include/nghttp/port/include/http_parser.h:95:6: error: 'HTTP_DELETE' conflicts with a previous declaration
XX(0, DELETE, DELETE) \
C:\Users\admin\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11/tools/sdk/esp32s2/include/nghttp/port/include/http_parser.h:138:45: note: in definition of macro 'XX'
#define XX(num, name, string) HTTP_##name = num,
C:\Users\admin\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11/tools/sdk/esp32s2/include/nghttp/port/include/http_parser.h:139:3: note: in expansion of macro 'HTTP_METHOD_MAP'
HTTP_METHOD_MAP(XX)
In file included from C:\Users\admin\AppData\Local\Temp\arduino_modified_sketch_65598\AsyncDemo.ino:33:
C:\Users\admin\Documents\Arduino\libraries\ESPAsyncWebServer\src/ESPAsyncWebServer.h:64:3: note: previous declaration 'WebRequestMethod HTTP_DELETE'
HTTP_DELETE = 0b00000100,
C:\Users\admin\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11/tools/sdk/esp32s2/include/nghttp/port/include/http_parser.h:96:6: error: 'HTTP_GET' conflicts with a previous declaration
XX(1, GET, GET) \
HTTP_METHOD_MAP(XX)
C:\Users\admin\Documents\Arduino\libraries\ESPAsyncWebServer\src/ESPAsyncWebServer.h:62:3: note: previous declaration 'WebRequestMethod HTTP_GET'
HTTP_GET = 0b00000001,
C:\Users\admin\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11/tools/sdk/esp32s2/include/nghttp/port/include/http_parser.h:97:6: error: 'HTTP_HEAD' conflicts with a previous declaration
XX(2, HEAD, HEAD) \
HTTP_METHOD_MAP(XX)
C:\Users\admin\Documents\Arduino\libraries\ESPAsyncWebServer\src/ESPAsyncWebServer.h:67:3: note: previous declaration 'WebRequestMethod HTTP_HEAD'
HTTP_HEAD = 0b00100000,
C:\Users\admin\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11/tools/sdk/esp32s2/include/nghttp/port/include/http_parser.h:98:6: error: 'HTTP_POST' conflicts with a previous declaration
XX(3, POST, POST) \
HTTP_METHOD_MAP(XX)
C:\Users\admin\Documents\Arduino\libraries\ESPAsyncWebServer\src/ESPAsyncWebServer.h:63:3: note: previous declaration 'WebRequestMethod HTTP_POST'
HTTP_POST = 0b00000010,
C:\Users\admin\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11/tools/sdk/esp32s2/include/nghttp/port/include/http_parser.h:99:6: error: 'HTTP_PUT' conflicts with a previous declaration
XX(4, PUT, PUT) \
HTTP_METHOD_MAP(XX)
C:\Users\admin\Documents\Arduino\libraries\ESPAsyncWebServer\src/ESPAsyncWebServer.h:65:3: note: previous declaration 'WebRequestMethod HTTP_PUT'
HTTP_PUT = 0b00001000,
C:\Users\admin\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11/tools/sdk/esp32s2/include/nghttp/port/include/http_parser.h:102:6: error: 'HTTP_OPTIONS' conflicts with a previous declaration
XX(6, OPTIONS, OPTIONS) \
HTTP_METHOD_MAP(XX)
C:\Users\admin\Documents\Arduino\libraries\ESPAsyncWebServer\src/ESPAsyncWebServer.h:68:3: note: previous declaration 'WebRequestMethod HTTP_OPTIONS'
HTTP_OPTIONS = 0b01000000,
C:\Users\admin\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11/tools/sdk/esp32s2/include/nghttp/port/include/http_parser.h:128:6: error: 'HTTP_PATCH' conflicts with a previous declaration
XX(28, PATCH, PATCH) \
HTTP_METHOD_MAP(XX)
C:\Users\admin\Documents\Arduino\libraries\ESPAsyncWebServer\src/ESPAsyncWebServer.h:66:3: note: previous declaration 'WebRequestMethod HTTP_PATCH'
HTTP_PATCH = 0b00010000,
C:\Users\admin\AppData\Local\Temp\arduino_modified_sketch_65598\AsyncDemo.ino: In function 'void setup()':
AsyncDemo:88:27: error: no matching function for call to 'ElegantOTAClass::begin(AsyncWebServer*)'
ElegantOTA.begin(&server); // Start ElegantOTA
In file included from C:\Users\admin\AppData\Local\Temp\arduino_modified_sketch_65598\AsyncDemo.ino:34:
C:\Users\admin\Documents\Arduino\libraries\ElegantOTA-master\src/ElegantOTA.h:107:10: note: candidate: 'void ElegantOTAClass::begin(WebServer*, const char*, const char*)'
void begin(ELEGANTOTA_WEBSERVER *server, const char * username = "", const char * password = "");
C:\Users\admin\Documents\Arduino\libraries\ElegantOTA-master\src/ElegantOTA.h:107:10: note: no known conversion for argument 1 from 'AsyncWebServer*' to 'WebServer*'
Plusieurs bibliothèque trouvées pour "WiFi.h"
Utilisé : C:\Users\admin\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11\libraries\WiFi
Non utilisé : C:\Users\admin\Desktop\arduino-1.8.19\libraries\WiFi
exit status 1
Ce rapport pourrait être plus détaillé avec
l'option "Afficher les résultats détaillés de la compilation"
activée dans Fichier -> Préférences.
