Library extracted folders not showing
When I extract a library from it's zip archive into the libraries folder, often the extracted folder is not shown in the directory sometimes for several minutes (Win10). I have tried many fixes such as selecting out of the folder into other folders in different locations, refreshing the folder, and re-opening windows explorer. I've read others have had this problem, I was wondering if anyone has found a good fix for this.
Are you extracting the files from the .zip file yourself or are you using "Add .ZIP Library" from the IDE menu ?
The 'good fix' is to use the install procedure as shown. The other possibility is it is NOTG a valid library. Since we don't know where you are getting it from we can't tell.
