Library for 128x64 I2C
I bought this module: https://store.ncd.io/product/oled-128x64-graphic-display-i2c-mini-module/
I am upgrading a project that previously used this module: https://www.adafruit.com/product/931
But I am having difficulty getting the new display to behave.
At this time, I have not changed any code.
If I don't plug in the weather sensors, then the screen will display as the program intends/commands for it to display. As soon as I plug the weather sensors in, the arduino/program freezes.
I am using an Arduino Pro Mini (5V/16M) as the host.
Part of me wants to think this is a data conflict, but since the display works by itself, I assume that I can rule out an addressing or command issue?
I get Booting1 and Booting2 in Serial Monitor, but no Booting3.
  Wire.begin();
  Serial.println("Booting1");
  // by default, we'll generate the high voltage from the 3.3v line internally! (neat!)
  display.begin(SSD1306_SWITCHCAPVCC, 0x3C);  // initialize with the I2C addr 0x3C (for the 128x32)
  display.display();
  display.clearDisplay();
  Serial.println("Booting2");
  display.setTextSize(2);
  display.setTextColor(WHITE);
  display.setCursor(0,0);
  display.println("Booting Up");
  display.display();
  Serial.println("Booting3");
  delay(5000);
If i start commenting things out, I find out that it hangs at display.display(). Setting the text color, size, origin works fine. If I change the address from 3C to 3D, the display does not turn on but the program runs as it should properly in serial monitor. If i use 3C but change the 1306.h file from 128x32 to 128x64, the program still freezes, and I get this error at compile:
Sketch uses 24,322 bytes (79%) of program storage space. Maximum is 30,720 bytes.
Global variables use 2,040 bytes (99%) of dynamic memory, leaving 8 bytes for local variables. Maximum is 2,048 bytes.
Low memory available, stability problems may occur.
So i basically just need guidance for modifying the library for twice the lines and fix this issue. I am hoping somebody here can be of assistance. I am strictly writing text. I don't need the fancy adafruit boot graphic or anything else.
Hi, Can you please post your complete code, including how you are powering the ProMini and the peripherals.
Thanks.. Tom.. :)
I’m using NCD CPS120 and SHT30 boards, plus the display linked above. They connect i2c using 4-pin ribbon cables. I de-pinned one connector to connect to pin (tack-soldered) on the Pro Mini.
I’m powering the Pro-Mini using the 5V FTDI cable.
I figured out a few things, specifically that I had to enable the jumper pull-ups for i2C to get the screen to command. However, I am wondering if I am indeed encountering buffer overrun.
This first block of code work. The code that I have attached does not. The only difference is that my test file is just reading the 2 sensors and writing it to the screen (19k program, 1.7k memory), while my long program does a big pile of math on the 2 sensor readings (24.5k program, 2.0k memory).
This is an example for our Monochrome OLEDs based on SSD1306 drivers
  Pick one up today in the adafruit shop!
  ------> http://www.adafruit.com/category/63_98
This example is for a 128x64 size display using I2C to communicate
3 pins are required to interface (2 I2C and one reset)
Adafruit invests time and resources providing this open source code,
please support Adafruit and open-source hardware by purchasing
products from Adafruit!
Written by Limor Fried/Ladyada  for Adafruit Industries.
BSD license, check license.txt for more information
All text above, and the splash screen must be included in any redistribution
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define OLED_RESET 4
Adafruit_SSD1306 display(OLED_RESET);
#define NUMFLAKES 10
#define XPOS 0
#define YPOS 1
#define DELTAY 2
#define LOGO16_GLCD_HEIGHT 16
#define LOGO16_GLCD_WIDTH  16
static const unsigned char PROGMEM logo16_glcd_bmp[] =
{ B00000000, B11000000,
  B00000001, B11000000,
  B00000011, B11100000,
  B11110011, B11100000,
  B11111110, B11111000,
  B01111110, B11111111,
  B00110011, B10011111,
  B00011111, B11111100,
  B00001101, B01110000,
  B00011011, B10100000,
  B00111111, B11100000,
  B00111111, B11110000,
  B01111100, B11110000,
  B01110000, B01110000,
  B00000000, B00110000 };
#if (SSD1306_LCDHEIGHT != 64)
#error("Height incorrect, please fix Adafruit_SSD1306.h!");
#endif
void setup()   {
  display.begin(SSD1306_SWITCHCAPVCC, 0x3C);  // initialize with the I2C addr 0x3D (for the 128x64)
  // init done
  // Show image buffer on the display hardware.
  // Since the buffer is intialized with an Adafruit splashscreen
  // internally, this will display the splashscreen.
  display.display();
  delay(2000);
// Clear the buffer.
  // text display tests
    static String tempHum = SHT30();
    static String temp = tempHum.substring(0,tempHum.indexOf("*"));
    static String hum = tempHum.substring(tempHum.indexOf("*")+1);
    int temperatureC = temp.toInt();
    float temperatureK = temperatureC + 273.15;
    int temperatureF = int(((temperatureC * 9)/5) + 32);
  display.print(temperatureF);
  display.print(" F, ");
  display.print(hum);
  display.println("%");
    float pascals = CPS120(); // in pascals
    float atm = pascals / 101325; // "standard atmosphere atms"
    float baro_millibars = pascals / 100;
    float baro_inHg = pascals * 0.0002953;
  display.print("B ");
  display.print(baro_inHg);
  display.println("\"");
  display.display();
  delay(10000);
  display.display();
String SHT30() {
  static byte state;
  static long temp1;
  static long temp2;
  static double temperature;
  static long hum1;
  static long hum2;
  static int humidity;
  static int buff[6] = {0,0,0,0,0,0};
  //static int address = 0x44;
  String output = "";
  Wire.beginTransmission(0x44);
  Wire.write(0x27);
  Wire.write(0x37);
  state = Wire.endTransmission();
  if (state != 0){
    //Report sensor failure
    Serial.println("SHT30 Failure");
    return "0";
  delay(10);
  Wire.requestFrom(0x44,6);
  delay(50);
  buff[0] = Wire.read();
  buff[1] = Wire.read();
  buff[2] = Wire.read();
  buff[3] = Wire.read();
  buff[4] = Wire.read();
  buff[5] = Wire.read();
  temp1 = (buff[0] * long(256));
  temp2 = temp1 + buff[1];
  temperature = int((temp2*0.00267) - 45);
  hum1 = buff[3]*long(256);
  hum2 = hum1 + buff[4];
  humidity = int(hum2*0.001526);
  output = String(temperature) + "*" + String(humidity);
  return ( output );
double CPS120(){
  //static int address = 0x28;
  static byte state;
  static int buff[2] = {0,0};
  float barometer;
  static long baro1;
  static long baro2;
  Wire.beginTransmission(0x28);
  Wire.write(0x80);
  if (state != 0){
    Serial.println("CPS120 Failure");
    return 0;
  delay(10);
  Wire.requestFrom(0x28,2);
  delay(50);
  baro1 = buff[0] & 0x3F;
  baro1 = baro1* 256;
  baro2 = baro1 + buff[1];
  barometer = 1000 * ((( baro2 / 16384.00)*90) + 30) ;
  //Serial.print(barometer);
  //Serial.print(" pascal = ");
  return barometer;
(Test File)
Sketch uses 19,012 bytes (61%) of program storage space. Maximum is 30,720 bytes.
Global variables use 1,690 bytes (82%) of dynamic memory, leaving 358 bytes for local variables. Maximum is 2,048 bytes.
(Actual Program)
Sketch uses 24,368 bytes (79%) of program storage space. Maximum is 30,720 bytes.
Global variables use 2,046 bytes (99%) of dynamic memory, leaving 2 bytes for local variables. Maximum is 2,048 bytes.
Wx-Station-V4.ino (10.2 KB)
Through troubleshooting, I think it was a memory issue.
This code now works (after alot of thinning)
#include <SPI.h>
#include <Wire.h>
#endif
void setup()   {
  display.display();
  delay(2000);
    float temperatureC = SHT30T();
    float humidity = SHT30H();
    float vaporPres = vapor(temperatureC);
    float vaporInHg = vaporPres / 33.86;
    float vaporPres2 = vaporInHg * (humidity/100);
    float vaporInHg2 = vaporPres2 / 33.86;
    float dewPointC = (243.5 * log(vaporPres2/6.112))/(17.67 - log(vaporPres2/6.112));
    float dewPointF = (dewPointC * (9/5)) + 32;
    float virTemp_r = virTemp(baro_millibars,vaporPres,temperatureK);
    int wgrains = int(grains(vaporPres2, atm, temperatureC) * (humidity/100.00));
    //int airDensity_r = int(airDensity(baro_inHg,virTemp_r));
    int airDensity_r = int(airDensity(baro_inHg,temperatureF));
    display_OLED(temperatureF, int(humidity), baro_inHg, vaporInHg2, int(dewPointF), wgrains, airDensity_r);
void display_OLED(int tempF, int hum, float baro, float vapor, int dewPoint, int grains, int DA){
      Serial.print("Sending to Display: ");
      Serial.print(tempF);
      Serial.print(",");
      Serial.print(hum);
      Serial.print(",");
      Serial.print(baro);
      Serial.print(", ");
      Serial.print(vapor);
      Serial.print(", ");
      Serial.print(dewPoint);
      Serial.print(", ");
      Serial.print(grains);
      Serial.print(", ");
      Serial.println(DA);
  for (int i=0;i<5;i++){
      display.print("T ");
      display.print(tempF);
      display.println(" F");
      display.print("H ");
      display.print(hum);
      display.print(baro);
      display.display();
      display.print("DA ");
      display.print(DA);
      display.display();
      delay(5000);
      display.print("V ");
      display.print(vapor);
      display.display();
      display.print("DP ");
      display.print(dewPoint);
      display.display();
      display.print("G ");
      display.print(grains);
      display.println("");
      display.display();
      display.print(DA);
      display.display();
      delay(5000);
  return;
float SHT30T() {
  static byte state;
  static long temp;
  static float temperature;
  Wire.write(0x27);
  Wire.write(0x37);
  if (state != 0){
    return 0.0;
  delay(10);
  delay(50);
  temp = (buff[0] << 8) | buff[1];
  temperature = (temp*0.00267) - 45;
  Serial.print("Temp: ");
  Serial.println(temperature);
  return ( temperature );
float SHT30H() {
  static byte state;
  static long hum;
  static float humidity;
  Wire.write(0x27);
  Wire.write(0x37);
  if (state != 0){
    return 0.0;
  delay(10);
  delay(50);
  hum = (buff[3] << 8) | buff[4];
  humidity = hum*0.001526;
  Serial.print("Hum: ");
  Serial.println(hum);
  Serial.print("Humidity: ");
  Serial.println(humidity);
  return ( humidity );
float CPS120(){
  static byte state;
  float barometer;
  static long baro1;
  Wire.write(0x80);
  if (state != 0){
    return 0;
  delay(10);
  delay(50);
  baro1 = ((buff[0] & 0x3F) << 8) | buff[1];
  barometer = 1000 * ((( baro1 / 16384.00)*90) + 30) ;
  Serial.print("Baro: ");
  Serial.println(barometer);
  return barometer;
float vapor(float tempC){ // Saturated
  float power = (7.5 * tempC) / (237.3 + tempC);
  float saturated = 6.1078 * pow(10,power);
        Serial.print("saturated: ");
        Serial.println(saturated);
        return saturated;
float virTemp(float millibar,float vapor,float tempK){
  float denom = (1 - ((vapor / millibar) * 0.378));
  float virTemp = tempK / denom;
        virTemp = ((9/5) * (virTemp - 273.15) + 32) + 459.69;
  return virTemp;
float grains(float vapor, float atm, float tempC){
        float atmPres = atm * 14.696;
        float power = 8.07131 - ( 1730.63 / (233.426 + tempC));
        float vaporPres = 0.0193367747*(pow(10,power));
        float waterGrains = (((7000*18.02)/28.85) * vaporPres) / (atmPres - vaporPres);
        return waterGrains;
float airDensity(float inHg,float airTemp){
  float inner = (17.326 * inHg) / (airTemp+459.67);
  float middle = 1 - pow(inner,0.235);
  float density = 145366 * middle;
  return density;
Sketch uses 17,290 bytes (56%) of program storage space. Maximum is 30,720 bytes.
Global variables use 1,731 bytes (84%) of dynamic memory, leaving 317 bytes for local variables. Maximum is 2,048 bytes.
