library for 2 digit 7 segment display
hello everyone i have this display and am trying to get it to work with a 8 bit shift register. I have gotten it to work as a single sketch but am wanting to make it into a library that i can use for other projects with the display. if anyone knows how to finish this library i would like it. also if anyone knows can the coding be made a simple as possable.
sketch file
//Define which pins will be used for the Shift Register control
  int dataPin = 2;
  int latchPin = 3;
  int clockPin = 4;
  #define CA1 13
  #define CA2 12
  //The byte sequence
  int numbers[10] = {0b00000011,0b10011111,0b00100101,0b00001101,0b10011001,0b01001001,0b01000001,0b00011111,0b00000001,0b00001001};
  //Configure each IO Pin
     pinMode(dataPin, OUTPUT);
     pinMode(latchPin, OUTPUT);
     pinMode(clockPin, OUTPUT);
     pinMode(CA1, OUTPUT);
     pinMode(CA2, OUTPUT);
  for (int digit1=0; digit1 < 10; digit1++) {
    for (int digit2=0; digit2 < 10; digit2++) {
      unsigned long startTime = millis();
      for (unsigned long elapsed=0; elapsed < 600; elapsed = millis() - startTime) {
        lightDigit1(digit1);
        delay(5);
        lightDigit2(digit2);
        delay(5);
void lightDigit1(int number) {
  digitalWrite(CA1, LOW);
  digitalWrite(CA2, HIGH);
  lightSegments(number);
void lightDigit2(int number) {
  digitalWrite(CA1, HIGH);
  digitalWrite(CA2, LOW);
void lightSegments(int number) {
  digitalWrite(latchPin, LOW);
  shiftOut(dataPin, clockPin, MSBFIRST, numbers[number]);
  digitalWrite(latchPin, HIGH);
h file
#if ARDUINO >= 100     // Arduino 1.0 and 0023 compatible!
#include "Arduino.h"
#else
#include "WProgram.h"
#endif
class Display
public:
registerpin(int dataPin, int latchPin, int clockPin);
digitpins(int CA1, int CA2);
void lightdigit1(int);
void lightdigit2(int);
private:
int _dataPin, _latchPin, _clockPin;
cpp file
#include "Display.h"
#else
#endif
Display::registerpin(int dataPin, int latchPin, int clockPin) {
_dataPin = dataPin;
_latchPin = latchPin;
_clockPin = clockPin;
pinMode(_dataPin,OUTPUT);
pinMode(_latchPin,OUTPUT);
pinMode(_clockPin,OUTPUT);
void Display::lightdigit1(){
void Display::lightdigit2(){
void Display::lightsegment(int numbero) {
_numbero=numbero;
_number=number;
int number[10] = {0b00000011,0b10011111,0b00100101,0b00001101,0b10011001,0b01001001,0b01000001,0b00011111,0b00000001,0b00001001};
digitalWrite(_latchPin, LOW);
shiftOut(dataPin, clockPin, MSBFIRST, number[numbero]);
digitalWrite(_latchPin, HIGH);
2_Digit_display.ino (3.76 KB)
Display.h (331 Bytes)
Display.cpp (870 Bytes)
The code you posted does something - point A.
You want the code to do something - point B.
You did not describe what is actually does (where point A is), nor did you describe what you want it to do (where point B is).
So, how can you expect us to help you get from point A to point B?
Sorry I did not say what it does
So what it does is makes a 2 digit display count from 00 to 99 using a shift register. The code in the loop can be changed to anything you like and use the commands in the 3 void statements to display the number. So what I want is a library that can have voids in it with commands to call them.
Until you understand the terminology, you have no business creating libraries. There are three functions whose return type is void.
A library with voids in it is next to useless. To make it do anything, you have to fill the voids.
