Hmm. Unfortunately, I could not get the SPI Flash library by LowPowerLab to work for the Arduino Due. However, that code did help me out considerably. I've hacked together a working demo that writes and reads a byte to the W25Q128FV serial flash. I'm using pin 4 for the chip select:
#include <SPI.h>
#define SERIAL_BAUD 9600
#define MEMORY 4 // Chip select pin
#define SPI_FLASH_WRITE_ENABLE 0x06 // Write enable
#define SPI_FLASH_READ_ID 0x90 // Manufacturer/Device ID
#define SPI_FLASH_SECTOR_ERASE 0x20 // Sector Erase
#define SPI_FLASH_PAGE_PROGRAM 0x02 // Page program
#define SPI_FLASH_READ_DATA 0x03 // Read Data
#define SPI_FLASH_READ_STATUS 0x05 // Read Status Register 1
Serial.begin(SERIAL_BAUD);
Serial.println("Starting");
SPI.begin(MEMORY);
SPI.setClockDivider(MEMORY, 21);
SPI.setDataMode(MEMORY, SPI_MODE0);
// Get manufacturer id
SPI.transfer(MEMORY, SPI_FLASH_READ_ID, SPI_CONTINUE);
SPI.transfer(MEMORY, 0x00, SPI_CONTINUE);
byte response1 = SPI.transfer(MEMORY, 0x00, SPI_CONTINUE);
byte response2 = SPI.transfer(MEMORY, 0x00);
Serial.print("Manufacturer ID: ");
Serial.print(response1);
Serial.print(", ");
Serial.println(response2);
long address = 123;
// Erase some memory
Serial.println("Erasing memory");
SPI.transfer(MEMORY, SPI_FLASH_WRITE_ENABLE);
SPI.transfer(MEMORY, SPI_FLASH_SECTOR_ERASE, SPI_CONTINUE);
SPI.transfer(MEMORY, address >> 16, SPI_CONTINUE);
SPI.transfer(MEMORY, address >> 8, SPI_CONTINUE);
SPI.transfer(MEMORY, address);
while(busy());
// Write some memory
Serial.println("Writing memory");
SPI.transfer(MEMORY, SPI_FLASH_PAGE_PROGRAM, SPI_CONTINUE);
SPI.transfer(MEMORY, address, SPI_CONTINUE);
SPI.transfer(MEMORY, 49); // Byte to transfer
while(busy());
// Read some memory
Serial.println("Reading memory");
SPI.transfer(MEMORY, SPI_FLASH_READ_DATA, SPI_CONTINUE);
byte result = SPI.transfer(MEMORY, 0x00);
Serial.print("Byte read: ");
Serial.println(result);
boolean busy()
Serial.print("Status: ");
SPI.transfer(MEMORY, SPI_FLASH_READ_STATUS, SPI_CONTINUE);
byte status = SPI.transfer(MEMORY, 0x00);
Serial.println(status);
return(status & 1); // first bit of status register byte is "Erase/Write in progress" flag
