Hello,
I needed a lib for a magnetic position sensor and because i could not find any i did it myself…so look in the attachament
If any one can help to improve it then please reply.
AS5048.zip (6.32 KB)
Hello,
Thanks for sharing this lib,
I had a quick look at it and have the following comments.
version numbering
#define AS5084A_LIB_VERSION “0.1.0”
readability
you need to add more spaces and white lines to make the code a bit more readable.
some code tricky
_data = (uint16_t)((_hB << 8) | _lB); // are you sure _hB << 8 become 16 bit before the | ??
sometimes it is simpler to write
_data = 256 * _hB + _1B;
(and please name them _highByte and _lowByte
(not reworked in all detail but just to get an idea)
//Read Registers included parity bit
#define SPI_READ_DIAGNOSTICS 0x7FFD
#define SPI_REG_MAGNITUDE 0x7FFE // Magnitude information after ATAN calculation
#define SPI_REG_ANGLE_INFO 0xFFFF // Angle information after ATAN calculation and zero position adder
uint16_t AS5048::getAngle(void)
sendCMD(SPI_REG_ANGLE_INFO);
return (getData() & 0x3FFF);
uint16_t AS5048::getMagnitude(void)
sendCMD(SPI_REG_MAGNITUDE);
sendCMD(SPI_NOP);
return getData();
uint16_t AS5048::getDiagnostics(void)
sendCMD(SPI_READ_DIAGNOSTICS);
sendCMD(SPI_NOP);
return getData();
void AS5048::sendCMD(uint16_t cmd)
//CheckSPI;//because i use the same library for SPI memory where SPCR = B01010000
CS0(_devPin);
mySPI.transferData(cmd >> 8);
mySPI.transferData(cmd & 0xFF);
CS1(_devPin);
uint16_t AS5048::getData(void)
CS0(_devPin);
_data = 256 * mySPI.transferData(0xFF);
_data += mySPI.transferData(0xFF);
CS1(_devPin);
if (_data & SPI_RESET_ERROR ) // define magic numbers like 0x4000 also for the 65535 (0xFFFF) that is also magic :)
sendCMD(SPI_REG_CLRERR);
return 65535;
return _data;
the code seems to be hard coded to PORTD while the sensor can (I assume) be connected to any pin.
uint16_t getData(void); can be private I guess?
my 2 cents
Thank for reply,
I will try to implement your suggestions.
regarding point 4, this lib was made so that it can serve my application as best as possible
point 5 - it can be, but sometimes because the way the sensor works (you read the result of previous command) i think i will need the function public, if not i will make it private.
OK, getting a working version is always the first step. Gold-plating can be done afterwards
