Library for generating pulsepatterns
Today I posted an experimental class called PulsePattern on the playground for generating [HIGH LOW] pulse patterns with the help of Timer1. - http://playground.arduino.cc//Main/PulsePattern -
The idea is to have an array of [LOW|HIGH] periods that is used by Timer1 as alarm trigger one by one. When alarm goes of a predefined pin flips from HIGH to LOW or vice versa. Timer1 is encapsulated by an instance of the class called PPGenerator, PP = PulsePattern of course. When all elements of the array are used it restarts at the begin of the array. The array can contain as many elements as you like (restricted by free memory of course)
Elaborated patterns can be placed into a pattern array and "played back" by the timer. PatternPlayer might be a better name? One can change the contents of the array runtime or reinitialize the PPGenerator with another array. A fun feature is using an array with an odd number of entries (try it).
Not implemented Placing the pattern in an array is fast, but I am thinking of a callback function that returns the next period to the timer. It is much slower due to function call overhead but it can encapsulate the pattern array or calculate the next period e.g. based upon sensor values. e.g. increase frequency or duty cycle when dew point temperature drops.
The sample sketch explains how it can be used.
//    FILE: SOS_demo2.pde
//  AUTHOR: Rob Tillaart
//    DATE: 2012-11-23
// PUPROSE: demo of the PulsePattern Library
//          uses timer1
#include "PulsePattern.h"
uint16_t SOSpattern[] = {
  500,500,500,500,500,1500,       // S in morse
  1500,500,1500,500,1500,1500,   // O in morse
  500,500,500,500,500,1500 };    // S in morse
uint8_t patternSize = 18;
uint8_t startLevel = LOW;
  Serial.println("Start PulsePattern");
  // as the prescaler = 1024 the periods of the pattern are a
  // few percent less than a millisecond
  PPGenerator.init(13, SOSpattern, patternSize, startLevel, PRESCALE_1024);
  PPGenerator.start();
  // dummy code that does something in the foreground
  Serial.println(millis());
As always, ideas, comments and remarks are welcome!
You could use the old sizeof/sizeof trick here.
PRESCALE_1024
I've done something similar on an LPC and I use two constants
HWTIMER_COUNT_RATE_US HWTIMER_COUNT_RATE_MS
So the user just has to know if he is counting uS or mS and doesn't have to think about what the prescaler is doing.
Rob
True, would be more elegant. however for a next version I am thinking of a change that uses a begin and end index, so the user can select a part of the whole array. (Now the user can for instance say size=6 and only blink the letter S.)
Thanks,
Hi Rob,
Are you still around? You lib is very useful. I was wondering if you are still developing it?
yes I am still around, the latest version can be found on github but little changed.
Do you have special requirements?
