Library for Gyroscope needing review
Hello Arduino community! I have been working with the arduino for almost a year now, and recently decided to get more in depth and write my own library. After much research I finally made a library. It doesn't work, at all. That is why I am asking those whom have the greater knowledge than I to review my code.
header first:
//gyro header
#ifndef gyro_h
#define gyro_h
#include <Wire.h>
class  gyro
 public:
 gyro();
 void begin();
 void xValue(int x);
 void yValue(int y);
 void zValue(int z);
 private:
 void readI2C();
 void writeI2C();
 #endif
and the body:
//This is a library for reading and reporting the axis
//states of the sensor.
//Anonymous Parallax
// and Nicolas Guerra-Contreras
#include <Wire.h>
#include "gyro.h"
#define CTRL_REG1 0x20
#define CTRL_REG2 0x21
#define CTRL_REG3 0x22
#define CTRL_REG4 0x23
#define Addr = 105;
#define int x
#define int y
#define int z
gyro::gyro(){
void gyro::begin() //start the gyro
	Wire.begin();
	writeI2C(CTRL_REG1, 0x1F);    // Turn on all axes, disable power down
    writeI2C(CTRL_REG3, 0x08);    // Enable control ready signal
    writeI2C(CTRL_REG4, 0x80);    // Set scale (500 deg/sec)
    delay(100);                   // Wait to synchronize
void gyro::xValue()	//gets x value
	byte MSB, LSB; //byte stores an 8-bit unsigned number(MSB,LSB) from 0 to 255.
	MSB = readI2C(0x29); //reads x memreg MSB
	LSB = readI2C(ox28); //reads x memreg LSB
	x = ((MSB << 8) | LSB); //moves MSB out of memo
void gyro::yValue()
	byte MSB, LSB;
	MSB = readI2C(0x2B);
	LSB = readI2C(0x2A);
	y = ((MSB << 8) | LSB);
void gyro::zValue()
	byte MSB, LSB;
	MSB = readI2C(0x2D);
	LSB = readI2C(0x2C);
	z = ((MSB << *) | LSB);
void gyro::readI2C(byte regAddr)
    Wire.beginTransmission(Addr);
    Wire.write(regAddr);                // Register address to read
    Wire.endTransmission();             // Terminate request
    Wire.requestFrom(Addr, 1);          // Read a byte
    while(!Wire.available()) { };       // Wait for receipt
    return(Wire.read());				// Get result
void gyro::writeI2C(byte regAddr, byte val)
    Wire.write(val);
all help and criticism is greatly appreciated.
Hell, if you could point me to a debugger for libraries that would be cool too.
