Library for lcd I2C display (Matrix Orbital LK404-25)
Hi all,
I have a Matrix Orbital 4x40 lcd I2C display, LK404-25 / VK404-25 version
Looking for a proper library, the best I found is "LCDi2c-LK162-12" library from Arduino Playground - HomePage
When I try to compile this simple code
#include <LCDI2C_LK162-12.h>
LCDI2C lcd = LCDI2C(4,40,0x50,0);
void setup(){
  lcd.init();
  lcd.setCursor(0,0);
  lcd.print("Hello");
void loop(){
I have the following internal library error:
LCDI2C_LK162-12.h:38: error: conflicting return type specified for ‘virtual void LCDI2C::write(uint8_t)’
Print.h:48: error: overriding ‘virtual size_t Print::write(uint8_t)’
Here is the library .h and .cpp files
LCDI2C_LK162-12.h
#ifndef LCDI2Ct_h
#define LCDI2C_h
#define CMDDELAY 50        // Delay to wait after sending commands;
#define POSDELAY 100		 // Long delay required by Position command
#define CHARDELAY 0
#define LCDI2C_MIN_BRIGHTNESS		0
#define LCDI2C_MAX_BRIGHTNESS		250
#define LCDI2C_VALUE_OUT_OF_RANGE	1
#define LCDI2C_MIN_CONTRAST			0
#define LCDI2C_MAX_CONTRAST			100
#include <inttypes.h>
#include "Print.h"
class LCDI2C : public Print {
public:
//LCDI2C(int num_lines,int num_col,int i2c_address,int display);
LCDI2C(int,int,int,int);
	void command(int value);
	void writeStartUpScreen(char message[32]);
  void init();
  virtual void write(uint8_t);
  void clear();
  void home();
  void on(int value);
  void off();
  void cursor_on();
  void cursor_off();
  void blink_on();
  void blink_off();
  void left();
  void right();
  int keypad();
  	// Overload the Print class function for strings because
	// the base class implementation causes problems by doing
	// an I2C I/O for every character
  void printstr(const char[]);
  void setCursor(int line_num, int x);
// Values for graphtype in calls to init_bargraph
#define LCDI2C_THIN_VERTICAL_BAR_GRAPH    1 // **
#define LCDI2C_THICK_VERTICAL_BAR_GRAPH    2 // **
#define LCDI2C_HORIZONTAL_BAR_GRAPH  3
#define LCDI2C_HORIZONTAL_LINE_GRAPH 4
  unsigned char init_bargraph(unsigned char graphtype);
  void draw_horizontal_graph(unsigned char row, unsigned char column, unsigned char len,  unsigned char pixel_col_end);
  void draw_vertical_graph(unsigned char row, unsigned char column, unsigned char len,  unsigned char pixel_col_end);
#define LCDI2C_NUM_CUSTOM_CHARS 8
#define LCDI2C_CUSTOM_CHAR_SIZE 8
  void load_custom_character(unsigned char char_num, unsigned char *rows);
  unsigned char set_backlight_brightness(unsigned char new_val);
  unsigned char set_contrast(unsigned char new_val);
private:
#endif
LCDI2C_LK162-12.cpp only involved part
void LCDI2C::write(uint8_t value) {
	Wire.beginTransmission(g_i2caddress);
	Wire.send(value);
	Wire.endTransmission();
	delay(5);
Is this library wrong? Someone knows a solution to tix this, or another library to use a standard lcd display connected by I2C?
The message is telling you that the write() method in that class is incorrect. It is telling you that the return type, void, is wrong, and should be size_t.
Both the header file and source file need to be changed. Don't forget to add the required return statement (returning the number of bytes printed/written).
