/home/paulo/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/home/paulo/.arduino15/packages/esp8266/hardware/esp8266/2.7.4/tools/sdk/include -I/home/paulo/.arduino15/packages/esp8266/hardware/esp8266/2.7.4/tools/sdk/lwip2/include -I/home/paulo/.arduino15/packages/esp8266/hardware/esp8266/2.7.4/tools/sdk/libc/xtensa-lx106-elf/include -I/tmp/arduino_build_409351/core -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 -I/home/paulo/.arduino15/packages/esp8266/hardware/esp8266/2.7.4/cores/esp8266 -I/home/paulo/.arduino15/packages/esp8266/hardware/esp8266/2.7.4/variants/nodemcu -I/home/paulo/Arduino/Projects/libraries/ESP_WiFiManager_Lite-main/src -I/home/paulo/.arduino15/packages/esp8266/hardware/esp8266/2.7.4/libraries/ESP8266WiFi/src -I/home/paulo/.arduino15/packages/esp8266/hardware/esp8266/2.7.4/libraries/ESP8266WebServer/src -I/home/paulo/.arduino15/packages/esp8266/hardware/esp8266/2.7.4/libraries/LittleFS/src -I/home/paulo/.arduino15/packages/esp8266/hardware/esp8266/2.7.4/libraries/DNSServer/src /tmp/arduino_build_409351/sketch/ESP_WiFi_MQTT.ino.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
In file included from /tmp/arduino_build_409351/sketch/defines.h:75:0,
Alternatives for ESP_MultiResetDetector.h: []
from /home/paulo/Arduino/libraries/ESP_WiFiManager_Lite-main/examples/ESP_WiFi_MQTT/ESP_WiFi_MQTT.ino:36:
/home/paulo/Arduino/Projects/libraries/ESP_WiFiManager_Lite-main/src/ESP_WiFiManager_Lite.h:169:98: fatal error: ESP_MultiResetDetector.h: No such file or directory
ResolveLibrary(ESP_MultiResetDetector.h)
#include <ESP_MultiResetDetector.h> //https://github.com/khoih-prog/ESP_MultiResetDetector
-> candidates: [] ^
compilation terminated.
Bibliothek ESP_WiFiManager_Lite-main in Version 1.2.0 im Ordner: /home/paulo/Arduino/Projects/libraries/ESP_WiFiManager_Lite-main wird verwendet
Bibliothek ESP8266WiFi in Version 1.0 im Ordner: /home/paulo/.arduino15/packages/esp8266/hardware/esp8266/2.7.4/libraries/ESP8266WiFi wird verwendet
Bibliothek ESP8266WebServer in Version 1.0 im Ordner: /home/paulo/.arduino15/packages/esp8266/hardware/esp8266/2.7.4/libraries/ESP8266WebServer wird verwendet
Bibliothek LittleFS in Version 0.1.0 im Ordner: /home/paulo/.arduino15/packages/esp8266/hardware/esp8266/2.7.4/libraries/LittleFS wird verwendet
Bibliothek DNSServer in Version 1.1.1 im Ordner: /home/paulo/.arduino15/packages/esp8266/hardware/esp8266/2.7.4/libraries/DNSServer wird verwendet
exit status 1
Fehler beim Kompilieren für das Board NodeMCU 1.0 (ESP-12E Module).
I am using PubSubClient.
It is compatible for ESP8266, ESP32, Arduino + Ethernet (Wiznet W5100 / W5500 or ENC28J60 aswell).
So one library for all microcontrollers that I am using
