Library for writing to EEPROM
If you are interested.
I created a library to write strings to the EEPROM. Also works with Node MCU.
Handy for when you want to save Access point SSIDs or Passwords.
It writes data in segments/fields of 20 characters, so the limitation is 20 characters for each setting that you want to save.
You can find the library here --> https://github.com/mailmartinviljoen/eeprm
The library contains 2 example sketches for Arduino and ESP8266.
Just a tip (Not included in the library)
When loading an access SSID and Password you do it like this.
Eeprm Eeprm(0);
APSSID=Eeprm.readdata(1);
APPASS=Eeprm.readdata(2);
WiFi.softAP(APSSID.c_str(),APPASS.c_str());
THanks for sharing
a quick view shows some improvements
  if (field==1){field=0;}
  if (field==2){field=20;}
  if (field==3){field=40;}
  if (field==4){field=60;}
  if (field==5){field=80;}
  if (field==6){field=100;}
  if (field==7){field=120;}
  if (field==8){field=140;}
  if (field==9){field=160;}
  if (field==10){field=180;}
could be: field = (field-1)*20;
(note that the function does not check invalid values for field)
another improvement is this loop
   for (i=field; i <= field+19; i++)
    if(EEPROM.read(i)==126){break;}
    Datatoread += char(EEPROM.read(i));
   for (i = field; i < field+20; i++)
    int val = EEPROM.read(i);
    if (val == 126) break;
    Datatoread += char(val);
check your variables:
Datatoread ==> dataToRead // called camel case, bit easier to read
Last but not least
EEPROM.write(i+field, CurASCIICode);
should become this to minimize write cycles.
int val = EEPROM.read(i + field);
if (val != CurASCIICode)
Thanks for the suggestions ,will most certainly improve it.
Its been updated.
I’m sure more improvements can be made by converting from String to char to int using a more elegant convertion.
String CurCharacter;
char CharConv;
int CurASCIICode;
CurCharacter = datatowrite.substring(i,i+1); //Get String character
CharConv = CurCharacter.charAt(0); //Convert string to Char
CurASCIICode=CharConv; //Convert char to integer (ASCII CODE)
