hi im getting this error when trying to compile a sketch in the IDE,i am using the file from
when i try to import it as a zip library it says no valid library so i just isolated the library folder inside of the src of the main folder and it is giving me this error below.
\OneDrive\Documents\Arduino\libraries\ESP8266WiFi\src\ESP8266WiFiAP.cpp:29:10: fatal error: LwipDhcpServer-NonOS.h: No such file or directory
29 | #include <LwipDhcpServer-NonOS.h>
do i need to import the library differently from time to time when i download from github it tells me "no usable library found" or something along those lines when there is a library inside/code examples
anyone have any ideas to help? i deleted the folder and tried to reinstall but sae issue
yes i did do the step below,its not a board issue its a compiler issue.
when i try to upload a sketch with the library "esp8266wifi" its gives me the error listed above,
im trying to figure out how to solve this issue
Hi. have you managed to solve this problem? I just installed arduino ide 1.8.19 with esp8266 3.0.2 and it is generating the same error and it does not allow me to compile the code
Hello, I had solved the problem by deleting one of the 2 possible directories the compilator found to compile ESP8266WiFi. As far as i understand the problem you should not install a specific "ESP8266WiFi library" (as I did) because the core lib of esp8266 allready has one.
Nicolas
