I need some expert help. New to forum, but an old timer with uPs.
Not sure where to post this as this is my first post on this forum.
I have a Elegoo 2.8 inch touchscreen display shield stacked on a L293D V1 motor shield on a Arduino uno processor board. The hardware all works correctly. I can run the display test programs. I can run the stepper motor test program.
The libraries involved are
#include <Elegoo_GFX.h> // Core graphics library
#include <Elegoo_TFTLCD.h> // Hardware-specific library
#include <AFMotor.h> // Arduino Stepper Library
When I attempt to issue the class statements
Elegoo_TFTLCD tft(A3, A2, A1, A0, A4);
AF_Stepper motor(800,1); // Steps/rev, channel M1
I get data corruption on the LCD screen.
Setting the channel to 1 (channel M1) causes the display to corrupt the written characters. The triangle and line functions kind of work, but the corruption is seen in the characters and the drawn lines. Also the left and top boundaries are messed up.
The code works until the AF_Stepper motor class is declared. I've tried many ways to isolate the corruption problem, but it comes back to the class code that runs the devices corrupting the LCD driver. I have not resorted to a logic analyzer or probe yet, but I'm convinced its library problem.
Attempting to initialize the LCDTFT display with both classes declared results in a white screen. I know this is because the AF_stepper motor( ) channel constant value is at fault. It only will initialize before the AF_Stepper motor() statement is issued.
Using the code below, the display makes the first pass with no corruption. The second pass results in LCD running corrupted. Pushing reset will repeat exactly the same as download restart.
Code follows (excuse my commented out stuff)
// IMPORTANT: ELEGOO_TFTLCD LIBRARY MUST BE SPECIFICALLY
// CONFIGURED FOR EITHER THE TFT SHIELD OR THE BREAKOUT BOARD.
// SEE RELEVANT COMMENTS IN Elegoo_TFTLCD.h FOR SETUP.
// Technical support:goodtft@163.com
// The control pins for the LCD can be assigned to any digital or
// analog pins...but we'll use the analog pins as this allows us to
// double up the pins with the touch screen (see the TFT paint example).
#define LCD_CS A3 // Chip Select goes to Analog 3
#define LCD_CD A2 // Command/Data goes to Analog 2
#define LCD_WR A1 // LCD Write goes to Analog 1
#define LCD_RD A0 // LCD Read goes to Analog 0
#define LCD_RESET A4 // Can alternately just connect to Arduino's reset pin
// When using the BREAKOUT BOARD only, use these 8 data lines to the LCD:
// For the Arduino Uno, Duemilanove, Diecimila, etc.:
// D0 connects to digital pin 8 (Notice these are
// D1 connects to digital pin 9 NOT in order!)
// D2 connects to digital pin 2
// D3 connects to digital pin 3
// D4 connects to digital pin 4
// D5 connects to digital pin 5
// D6 connects to digital pin 6
// D7 connects to digital pin 7
// For the Arduino Mega, use digital pins 22 through 29
// (on the 2-row header at the end of the board)
// Create instance of Stepper Class
// Specify Pins used for motor coils
// The pins used are 8,9,10,11
// Connected to ULN2003 Motor Driver In1, In2, In3, In4
// Pins entered in sequence 1-3-2-4 for proper step sequencing
// Stepper steppermotor(Steps_per_rev, 8, 10, 9, 11);
// Assign human-readable names to some common 16-bit color values:
#define BLACK 0x0000
#define BLUE 0x001F
#define RED 0xF800
#define GREEN 0x07E0
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFF
//AF_Stepper motor(800,0); // Steps/rev, channel M1
// Elegoo_TFTLCD tft(LCD_CS, LCD_CD, LCD_WR, LCD_RD, LCD_RESET);
// AF_Stepper motor(400,1); // Steps/rev, channel M1
// If using the shield, all control and data lines are fixed, and
// a simpler declaration can optionally be used:
// Elegoo_TFTLCD tft;
// --------------------------------SET UP-----------------------------------
uint16_t identifier;
void setup(void) {
// Elegoo_TFTLCD tft(A3, A2, A1, A0, A4);
// Serial.begin(9600);
tft.reset();
delay(1);
//identifier=tft.readID();
tft.begin(tft.readID()); //This works without setting an identifier variable
// ---------------------------------MAIN------------------------------------
void loop(void) {
// Elegoo_TFTLCD tft(A3, A2, A1, A0, A4); //address lines hard coded
// tft.reset();
// delay(10);
// tft.begin(tft.readID());
// setup();
// Serial.print(F("Screen fill "));
Serial.println(testFillScreen());
Serial.print(F("Text "));
Serial.println(testText());
delay(3000);
// Serial.print(F("Lines "));
Serial.println(testLines(CYAN));
// Serial.print(F("Horiz/Vert Lines "));
Serial.println(testFastLines(RED, BLUE));
// Serial.print(F("Rectangles (outline) "));
Serial.println(testRects(GREEN));
// Serial.print(F("Rectangles (filled) "));
Serial.println(testFilledRects(YELLOW, MAGENTA));
// Serial.print(F("Circles (filled) "));
Serial.println(testFilledCircles(10, MAGENTA));
// Serial.print(F("Circles (outline) "));
Serial.println(testCircles(10, WHITE));
// Serial.print(F("Triangles (outline) "));
Serial.println(testTriangles());
// Serial.print(F("Triangles (filled) "));
Serial.println(testFilledTriangles());
// Serial.print(F("Rounded rects (outline) "));
Serial.println(testRoundRects());
// Serial.print(F("Rounded rects (filled) "));
Serial.println(testFilledRoundRects());
for(uint8_t rotation=0; rotation<4; rotation++) {
tft.setRotation(rotation);
testText();
stepit();
// -------------------------------MACRO FUNCTIONS TO USE-------------------------------
unsigned long stepit() {
unsigned long start = micros();
// The AF_Stepper motor is a problem causing LCD screen write curroption
// Specifically with the AF_Stepper motor() statement
// digitalWrite(A3, LOW);
// Rotate the stepper motor
// Rotate CW 1/2 turn slowly
motor.setSpeed(12);
motor.step(800, FORWARD, INTERLEAVE);
motor.release();
// Rotate CCW 1/2 turn slowly
motor.setSpeed(12);
motor.step(800, BACKWARD, INTERLEAVE);
motor.release();
// digitalWrite(A3, HIGH);
// Attempt to change pins 8,9,10,11)
// claimed used pins for stepper motor
pinMode(8,OUTPUT);
pinMode(9,OUTPUT);
pinMode(10,OUTPUT);
pinMode(11,OUTPUT);
return micros() - start;
unsigned long testFillScreen() {
tft.fillScreen(BLACK);
tft.fillScreen(RED);
tft.fillScreen(GREEN);
tft.fillScreen(BLUE);
unsigned long testText() {
tft.setCursor(0, 0);
tft.setTextColor(WHITE); tft.setTextSize(1);
tft.println("Hello World!");
tft.setTextColor(YELLOW); tft.setTextSize(2);
tft.println(identifier, HEX);
tft.setTextColor(RED); tft.setTextSize(3);
tft.println(0xDEADBEEF, HEX);
tft.println();
tft.setTextColor(GREEN);
tft.setTextSize(5);
tft.println("Groop");
tft.setTextSize(2);
tft.println("I implore thee,");
tft.setTextSize(1);
tft.println("my foonting turlingdromes.");
tft.println("And hooptiously drangle me");
tft.println("with crinkly bindlewurdles,");
tft.println("Or I will rend thee");
tft.println("in the gobberwarts");
tft.println("with my blurglecruncheon,");
tft.println("see if I don't!");
unsigned long testLines(uint16_t color) {
unsigned long start, t;
int x1, y1, x2, y2,
w = tft.width(),
h = tft.height();
x1 = y1 = 0;
y2 = h - 1;
start = micros();
for(x2=0; x2<w; x2+=6) tft.drawLine(x1, y1, x2, y2, color);
x2 = w - 1;
for(y2=0; y2<h; y2+=6) tft.drawLine(x1, y1, x2, y2, color);
t = micros() - start; // fillScreen doesn't count against timing
x1 = w - 1;
y1 = 0;
y2 = h - 1;
start = micros();
x2 = 0;
t += micros() - start;
x1 = 0;
y1 = h - 1;
y2 = 0;
start = micros();
x2 = w - 1;
x1 = w - 1;
y1 = h - 1;
y2 = 0;
start = micros();
x2 = 0;
unsigned long testFastLines(uint16_t color1, uint16_t color2) {
unsigned long start;
int x, y, w = tft.width(), h = tft.height();
start = micros();
for(y=0; y<h; y+=5) tft.drawFastHLine(0, y, w, color1);
for(x=0; x<w; x+=5) tft.drawFastVLine(x, 0, h, color2);
unsigned long testRects(uint16_t color) {
int n, i, i2,
cx = tft.width() / 2,
cy = tft.height() / 2;
n = min(tft.width(), tft.height());
start = micros();
for(i=2; i<n; i+=6) {
i2 = i / 2;
tft.drawRect(cx-i2, cy-i2, i, i, color);
unsigned long testFilledRects(uint16_t color1, uint16_t color2) {
unsigned long start, t = 0;
int n, i, i2,
cx = tft.width() / 2 - 1,
cy = tft.height() / 2 - 1;
for(i=n; i>0; i-=6) {
i2 = i / 2;
start = micros();
tft.fillRect(cx-i2, cy-i2, i, i, color1);
// Outlines are not included in timing results
tft.drawRect(cx-i2, cy-i2, i, i, color2);
return t;
unsigned long testFilledCircles(uint8_t radius, uint16_t color) {
int x, y, w = tft.width(), h = tft.height(), r2 = radius * 2;
start = micros();
for(x=radius; x<w; x+=r2) {
for(y=radius; y<h; y+=r2) {
tft.fillCircle(x, y, radius, color);
unsigned long testCircles(uint8_t radius, uint16_t color) {
int x, y, r2 = radius * 2,
w = tft.width() + radius,
h = tft.height() + radius;
// Screen is not cleared for this one -- this is
// intentional and does not affect the reported time.
start = micros();
for(x=0; x<w; x+=r2) {
for(y=0; y<h; y+=r2) {
tft.drawCircle(x, y, radius, color);
unsigned long testTriangles() {
int n, i, cx = tft.width() / 2 - 1,
n = min(cx, cy);
start = micros();
for(i=0; i<n; i+=5) {
tft.drawTriangle(
cx , cy - i, // peak
cx - i, cy + i, // bottom left
cx + i, cy + i, // bottom right
tft.color565(0, 0, i));
unsigned long testFilledTriangles() {
int i, cx = tft.width() / 2 - 1,
start = micros();
for(i=min(cx,cy); i>10; i-=5) {
start = micros();
tft.fillTriangle(cx, cy - i, cx - i, cy + i, cx + i, cy + i,
tft.color565(0, i, i));
tft.drawTriangle(cx, cy - i, cx - i, cy + i, cx + i, cy + i,
tft.color565(i, i, 0));
return t;
unsigned long testRoundRects() {
int w, i, i2,
w = min(tft.width(), tft.height());
start = micros();
for(i=0; i<w; i+=6) {
i2 = i / 2;
tft.drawRoundRect(cx-i2, cy-i2, i, i, i/8, tft.color565(i, 0, 0));
unsigned long testFilledRoundRects() {
int i, i2,
start = micros();
for(i=min(tft.width(), tft.height()); i>20; i-=6) {
i2 = i / 2;
tft.fillRoundRect(cx-i2, cy-i2, i, i, i/8, tft.color565(0, i, 0));
