Library Issue
Hi there.
I am busy creating my own library.
I have started with the header and source file of a class that will be used as an object in my sketch.
But when I call an instance of this class in my sketch it gives me the following error:
UserInput.cpp:9: error: expected initializer before 'getSerial’
Below is my code so far. The sketch is not much as I want to keep it simple in order to see if my library is linked correctly to my sketch.
header file:
#ifndef UserInput_h
#define UserInput_h
#include "Arduino.h"
class UserInput{
	public:
	//constructor
	UserInput();
    //public functions
	String getSerial();
	private:
	//private variables
	char serialChars[20]; //limit serial input to only 20 characters at a time to prevent buffer overflow. Will come later in cpp.
	boolean looper;
	int buffer;
	String data;
#endif
source file:
#include "UserInput.h"
//constructor
UserInput::UserInput(){
//get user input function named getSerial
String UserInput::String getSerial(){
  looper = true;
  buffer = 0;
  data = "";
  while (looper == true)
    if (Serial.available () > 0) //insert later a method to make sure the buffer is not flooded with text.
      delay(50);
      buffer = Serial.available();
      //Serial.println(buffer_size);
      serialChars[buffer];
       for (int x = 0; x < buffer; x++)
         serialChars[x] = Serial.read();
         delay(50);
         data += serialChars[x];
       //Serial.println(serial_data);
       looper = false;
       Serial.flush();
       delay(100);
  return data;
sketch:
#include <UserInput.h>
UserInput userinput;
  //userinput.getSerial();
I tried to figure out this error but was not able to.
Thanks for the help on this. I appreciate it.
Wait, I think I see my initialization issue.
Don't post answers yet, I'll post if I came rite or not.
Did not come rite.
Anyone welcome to help now.
So I changed my code to the following:
header file:
#ifndef UserInput_h
#define UserInput_h
class UserInput{
	public:
	//constructor used to start an instance of serial communications at baud rate supplied by programmer.
	UserInput(int);
	//public variables
	String data;
    //public functions
	String getSerial();
	private:
	//private variables
	boolean looper;
	int buffer;
#endif
Source File:
//constructor
UserInput::UserInput(int baud_rate){
 Serial.begin(baud_rate);
  looper = true;
  buffer = 0;
  data = "";
      delay(50);
      //serialChars[buffer];
         delay(50);
       looper = false;
       Serial.flush();
       delay(100);
  return data;
Sketch:
UserInput userinput(9600);
  //Serial.begin(9600);
Why is String in their twice? The function you are trying to implement is UserInput::getSerial().
Ditch the stupid String class BEFORE you dig yourself too deep a whole.
Thanks I'll remove that.
Any reason why you say I might dig myself a hole?
Because Strings are slow, memory-intensive, and non-value added.
Everything that you can do with a String can be done with a string.
Removed the extra String, it compiles fine now. Thank you for the help.
Oh ok, I understand.
Advice noted.
