Hi!
I'm trying to build a world clock (Arduino Word Clock - 3D Printable by DIY_Machines - Thingiverse). I have 3d printed and bought the parts but unfortunately, I get the following error message when I compile the code:
Arduino: 1.8.19 (Windows 10), Board: "Arduino Nano, ATmega328P (Old Bootloader)"
C:\Users\moimo\AppData\Local\Temp\ccPwDp3h.ltrans0.ltrans.o: In function `checkDST':
C:\Users\moimo\Documents\Arduino\libraries\DST_RTC-master/DST_RTC.cpp:36: undefined reference to `rulesDST'
C:\Users\moimo\Documents\Arduino\libraries\DST_RTC-master/DST_RTC.cpp:71: undefined reference to `rulesDST'
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board Arduino Nano.
option enabled in File -> Preferences.
The Sketch code is:
// include the library code:
#include <Wire.h>
#include <RTClib.h>
#include <DST_RTC.h>
#include <Adafruit_GFX.h>
#include <Adafruit_NeoMatrix.h>
// define pins
#define NEOPIN 6 // connect to DIN on NeoMatrix 8x8 via a resistor
#define RTCGND A2 // use this as ground
#define RTCPWR A3 // use this as power
RTC_DS1307 RTC; // Establish clock object
DST_RTC dst_rtc; // DST object
DateTime theTime; // Holds current clock time
// configure for 8x8 neopixel matrix
Adafruit_NeoMatrix matrix = Adafruit_NeoMatrix(8, 8, NEOPIN,
NEO_MATRIX_TOP + NEO_MATRIX_LEFT +
NEO_MATRIX_COLUMNS + NEO_MATRIX_PROGRESSIVE,
NEO_GRB + NEO_KHZ800);
//array to store if LEDs are lit or not
int ledMatrix[8][8] = {
{1, 1, 1, 0, 0, 0, 0, 0},
{0, 0, 0, 0, 0, 0, 0, 0},
int ledCount = 64; // the 8x8 grid of the Neomatrix
//Serial for debugging
// set pinmodes
pinMode(NEOPIN, OUTPUT);
// start clock
Wire.begin(); // Begin I2C
RTC.begin(); // begin clock
RTC.adjust(DateTime(__DATE__, __TIME__));
matrix.begin();
matrix.setBrightness(100);
matrix.fillScreen(0); // Initialize all pixels to 'off'
matrix.show();
// get the time
theTime = dst_rtc.calculateTime(RTC.now());
// add 2.5 minutes to get better estimates
theTime = theTime.unixtime() + 150;
//write 'it is' everytime:
ledMatrix[0][0] = 1;
ledMatrix[0][1] = 1;
if ((theTime.minute() > 4) && (theTime.minute() < 10)) {
ledMatrix[2][0] = 1;
ledMatrix[2][1] = 1;
ledMatrix[2][2] = 1;
Serial.print("mfive ");
if ((theTime.minute() > 9) && (theTime.minute() < 15)) {
ledMatrix[0][6] = 1;
ledMatrix[0][7] = 1;
Serial.print("mten ");
if ((theTime.minute() > 14) && (theTime.minute() < 20)) {
ledMatrix[1][0] = 1;
ledMatrix[1][1] = 1;
ledMatrix[1][2] = 1;
ledMatrix[1][3] = 1;
Serial.print("mquarter ");
if ((theTime.minute() > 19) && (theTime.minute() < 25)) {
ledMatrix[1][4] = 1;
ledMatrix[1][5] = 1;
ledMatrix[1][6] = 1;
ledMatrix[1][7] = 1;
Serial.print("mtwenty ");
if ((theTime.minute() > 24) && (theTime.minute() < 30)) {
Serial.print("mtwenty five ");
if ((theTime.minute() > 29) && (theTime.minute() < 35)) {
ledMatrix[0][3] = 1;
ledMatrix[0][4] = 1;
ledMatrix[0][5] = 1;
Serial.print("mhalf ");
if ((theTime.minute() > 34) && (theTime.minute() < 40)) {
if ((theTime.minute() > 39) && (theTime.minute() < 45)) {
if ((theTime.minute() > 44) && (theTime.minute() < 50)) {
if ((theTime.minute() > 49) && (theTime.minute() < 55)) {
Serial.print("mten");
if (theTime.minute() > 54) {
if ((theTime.minute() < 5))
switch (theTime.hour()) {
case 1:
case 13:
ledMatrix[3][3] = 1;
ledMatrix[3][4] = 1;
Serial.print("hone ");
case 2:
case 14:
ledMatrix[4][0] = 1;
ledMatrix[4][1] = 1;
Serial.print("htwo ");
case 3:
case 15:
ledMatrix[3][7] = 1;
ledMatrix[3][6] = 1;
Serial.print("hthree ");
case 4:
case 16:
ledMatrix[4][2] = 1;
ledMatrix[4][3] = 1;
ledMatrix[4][4] = 1;
Serial.print("hfour ");
case 5:
case 17:
ledMatrix[5][6] = 1;
ledMatrix[5][7] = 1;
Serial.print("hfive ");
case 6:
case 18:
ledMatrix[6][6] = 1;
ledMatrix[6][7] = 1;
Serial.print("hsix ");
case 7:
case 19:
ledMatrix[6][3] = 1;
ledMatrix[6][4] = 1;
ledMatrix[6][5] = 1;
Serial.print("hseven ");
case 8:
case 20:
ledMatrix[4][5] = 1;
ledMatrix[4][6] = 1;
ledMatrix[4][7] = 1;
Serial.print("height ");
case 9:
case 21:
ledMatrix[6][0] = 1;
ledMatrix[6][1] = 1;
ledMatrix[6][2] = 1;
Serial.print("hnine ");
case 10:
case 22:
ledMatrix[5][4] = 1;
ledMatrix[5][5] = 1;
Serial.print("hten ");
case 11:
case 23:
ledMatrix[5][0] = 1;
ledMatrix[5][1] = 1;
ledMatrix[5][2] = 1;
ledMatrix[5][3] = 1;
Serial.print("heleven ");
case 0:
case 12:
ledMatrix[7][0] = 1;
ledMatrix[7][1] = 1;
ledMatrix[7][2] = 1;
ledMatrix[7][3] = 1;
Serial.print("htwelve ");
else if ((theTime.minute() < 35) && (theTime.minute() > 4))
ledMatrix[3][0] = 1;
ledMatrix[3][1] = 1;
ledMatrix[3][2] = 1;
Serial.print("past");
case 1:
case 13:
Serial.print("one ");
case 2:
case 14:
Serial.print("two ");
case 3:
case 15:
Serial.print("three ");
case 4:
case 16:
Serial.print("four ");
case 5:
case 17:
Serial.print("five ");
case 6:
case 18:
Serial.print("six ");
case 7:
case 19:
Serial.print("seven ");
case 8:
case 20:
Serial.print("eight ");
case 9:
case 21:
Serial.print("nine ");
case 10:
case 22:
Serial.print("ten ");
case 11:
case 23:
Serial.print("eleven ");
case 0:
case 12:
Serial.print("twelve ");
// if we are greater than 34 minutes past the hour then display
// the next hour, as we will be displaying a 'to' sign
ledMatrix[2][6] = 1;
ledMatrix[2][7] = 1;
Serial.print("to ");
//Serial.print(" to ");
case 1:
case 13:
case 14:
case 2:
case 15:
case 3:
case 4:
case 16:
case 5:
case 17:
case 6:
case 18:
case 7:
case 19:
case 8:
case 20:
case 9:
case 21:
case 10:
case 22:
case 11:
case 23:
case 0:
case 12:
//it's show time....
for(int i = 0; i < 8; i++) {
for(int j = 0; j < 8; j++) {
if (ledMatrix[i][j] == 1) {
matrix.drawPixel(i, j, matrix.Color(255, 255, 0));
else {
matrix.drawPixel(i, j, matrix.Color(0, 0, 0));
displayTime();
checkArray();
matrix.show();
delay(5000);
resetArray();
void checkArray(){
//print out the array to check it:
Serial.print(ledMatrix[i][j]);
Serial.print(",");
void resetArray(){
//set all the array values to 0 (off):
ledMatrix[i][j] = 0;
Serial.print("Array reset (All LEDs switched set to off)");
void displayTime() {
// get time from the RTC
DateTime theTime = RTC.now();
// serial print current time
Serial.print(theTime.year(), DEC);
Serial.print('/');
Serial.print(theTime.month(), DEC);
Serial.print('/');
Serial.print(theTime.day(), DEC);
Serial.print(' ');
Serial.print(theTime.hour(), DEC);
Serial.print(':');
Serial.print(theTime.minute(), DEC);
Serial.print(':');
Serial.print(theTime.second(), DEC);
The header DST_RTC.h:
#include <Arduino.h>
#include "RTClib.h"
extern const char rulesDST[];
class DST_RTC
public:
DST_RTC();
boolean checkDST(DateTime RTCTime);
DateTime calculateTime(DateTime RTCTime);
The code DST_RTC.ccp:
#include "Arduino.h"
#include "DST_RTC.h"
DST_RTC::DST_RTC()
boolean DST_RTC::checkDST(DateTime RTCTime)
// Get the day of the week. 0 = Sunday, 6 = Saturday
int previousSunday = RTCTime.day() - RTCTime.dayOfTheWeek();
boolean dst = false; //Assume we're not in DST
if (strcmp(rulesDST, "US") == 0) {
// Serial.print("test of rulesDST: ");
// Serial.println(rulesDST);
if (RTCTime.month() > 3 && RTCTime.month() < 11) dst = true; //DST is happening in America!
//In the USA in March we are DST if the previous Sunday was on or after the 8th (and on or before the 14th).
if (RTCTime.month() == 3)
if (RTCTime.dayOfTheWeek() == 0) { // if today is Sunday
if (previousSunday >= 8 // on or after 8th
&& previousSunday <= 14 // but on or before 14th
&& RTCTime.hour() >= 2) // and at or after 2:00 AM
dst = true;
else if (previousSunday >= 15) // it is a Sunday after the second Sunday
dst = true;
else if (previousSunday >= 8) // it is not Sunday and we are after the change to DST
dst = true;
//In November we must be before the first Sunday to be dst for USA.
//In this case we are changing time at 2:00 AM so since the change to the previous Sunday
//happens at midnight the previous Sunday is actually this Sunday at 2:00 AM
//That means the previous Sunday must be on or before the 7th.
if (RTCTime.month() == 11) // November for the USA
if (RTCTime.dayOfTheWeek() == 0) // if today is Sunday
if (previousSunday <= 7 // and it is also the first Sunday
&& RTCTime.hour() <= 1) // less than 2:00 AM
dst = true;
else if (previousSunday <= 0) // it is not yet the first Sunday and the previous Sunday was before Nov 1
dst = true;
if (strcmp(rulesDST, "EU") == 0) {
if (RTCTime.month() > 3 && RTCTime.month() < 10) dst = true; //DST is happening in Europe!
//In Europe in March, we are DST if the previous Sunday was on or after the 25th.
if (RTCTime.dayOfTheWeek() == 0) // Today is Sunday
if (previousSunday >= 25 // and it is a Sunday on or after 25th (there can't be a Sunday in March after this)
&& RTCTime.hour() >= 2) // 2:00 AM for Europe
dst = true;
else if (previousSunday >= 25) // if not Sunday and the last Sunday has passed
dst = true;
//In October we must be before the last Sunday to be in DST for Europe.
//That means the previous Sunday must be on or before the 31st but after the 25th.
if (RTCTime.month() == 10) // October for Europe
if (previousSunday >= 25 // and it is also on or after 25th
&& RTCTime.hour() <= 1) // less than 2:00 AM for Europe
dst = true;
else if (previousSunday < 25) // it is not yet the last Sunday
dst = true;
else if // it is not Sunday
dst = true;
return dst;
DateTime DST_RTC::calculateTime(DateTime RTCTime)
if (checkDST(RTCTime) == true) {
RTCTime = RTCTime.unixtime() + 3600; // add 1 hour or 3600 seconds to the time
return RTCTime;
Any help will be much appreciated!
Thank you!
