Library Issues with Radio Shack Robotics Starter Kit 2770406
We purchased the Radio Shack Robotics Starter Kit 2770406. When trying to load the library files from GitHub - RadioShackCorp/2770406-Robotics-Starter-Kit to Arduino/Libraries folder, it still gets an error when running the walk.ino. The files loaded are from the above link (GNU GENERAL PUBLIC LICENSE.pdf, keywords.txt, library.properties, RadioShackRobotics.cpp, RadioShackRobotics.h, README.md) into C:\Program Files (x86)\Arduino\libraries\RadioShackRobotics\ The error message is below
Error Message:
Arduino: 1.6.12 (Windows 10), Board: “Arduino/Genuino Uno”
Property line ‘’ in file C:\Program Files (x86)\Arduino\libraries\RadioShackRobotics\library.properties is invalid
Error compiling for board Arduino/Genuino Uno.
“Show verbose output during compilation”
option enabled in File → Preferences.
Below is the Verbose output:
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Richard\Documents\Arduino\libraries -fqbn=arduino:avr:uno -ide-version=10612 -build-path C:\Users\Richard\AppData\Local\Temp\arduino_build_386536 -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\Richard\Documents\Arduino\Programming_Arduino_Getting_Started_With_Skethches\Programming_Arduino_Getting_Started_With_Skethches.ino
The files should be downloaded as a ZIP. Then use library manager to install the ZIP.
Ray
Your files are munged - they appear to contain chunks of HTML. This can happen when saving pages off github from a browser - you end up saving the github viewer page, rather than just the file you were viewing. Either download the zip, or use the github desktop client to sync the repo into a folder inside libraries.
Thanks for the responses! Got it working
