Library looping error
I am writing a library and have come across a problem. In one of my voids in the .cpp file, I am recreating the LED fade effect from the fade example sketch. Here is that part of the .cpp file:
void LED::fade(int amount)
  _amount = amount;
  analogWrite(_pin, _bright);
  _bright = _bright + _amount;
  if (_bright <= 0 || _bright >= 255) {
    _amount = -_amount;
  delay(30);
The problem comes in the part where I am setting the private “_amount” variable to be equal to the public “amount” variable(_amount = amount;). At the beginning of a loop this will always change the “_amount” variable back to the “amount” variable and I don’t want that to happen because the “_amount” variable changes at the end of the code(_amount = -_amount;). I have tried putting that statement(_amount = amount;) in other places like the header file but of course that didn’t work. Is there another place where I can put it?
Loop? What Loop?
JaBa: Loop? What Loop?
The loop in my actual sketch:
  led.fade(5)
You might want to post the rest of your LED class.
-jim lee
jimLee:
-jim lee
OK here it is:
LED::LED(int pin)
  pinMode(pin, OUTPUT);
  _pin = pin;
void LED::blink(int mill)
  _mill = mill;
  digitalWrite(_pin, HIGH);
  delay(_mill);
  digitalWrite(_pin, LOW);
  delay(_mill);
  _amount = amount;
    _amount = -_amount;
  delay(30);
void LED::on()
void LED::off()
You need to fill those voids with functions.
Lets see the header file so we know what's been defined..
And void is a way of saying, nothing.
void function(void); passes back nothing and you pass in nothing. int function(void); passes back an int but you pass in nothing.
For some reason many people are getting this mixed up lately.
Oh, and if they are in a class, void classname::function(void) they are called methods, not functions.
Go figure.
So, .h file?
-jim lee
No offense intended but if you call those things 'void', you might not be ready to write a library. It's called a function or a member function (also known as method). In this case member function / method as it's part of a class but if you called it function it would also be fine (my view).
I would also suggest that you read up on millis() based timing (see e.g. blink-without-delay) instead of delay if you want that library to be really re-usable.
jimLee: Lets see the header file so we know what's been defined..
Go figure.
So, .h file?
-jim lee
Here it is:
#ifndef SYMPEL_h
#define SYMPEL_h
#include "Arduino.h"
class LED
  public:
    LED(int pin);
    void blink(int mill);
    void fade(int amount);
    void on();
    void off();
  private:
    int _pin;
    int _mill;
    int _amount;
    int _bright = 0;
#endif
What is supposed to cause the brightness of the LED to actually change? You set the brightness to the exact same value every time you call the function.
