I thought this was interesting so I tried the same program on my MEGA ADK board. On the first try, it compiled and gave a ton of output from the compile, but it finished quickly. Then I tried to upload it to the board. It compiled quickly, giving the same verbose output from the compile process, but once again it completed and started uploading to the board. 10 minutes later it was still uploading to the board! I interupted the upload. I selected the board and port again and tried to upload again. It said it couldn’t connect. I selected the board and port again and tried and this time it worked and very quickly, but it did still give very verbose output from the compile. Here is that verbose output…
Warning: platform.txt from core ‘Arduino AVR Boards’ contains deprecated recipe.preproc.macros="{compiler.path}{compiler.cpp.cmd}" {compiler.cpp.flags} {preproc.macros.flags} -mmcu={build.mcu} -DF_CPU={build.f_cpu} -DARDUINO={runtime.ide.version} -DARDUINO_{build.board} -DARDUINO_ARCH_{build.arch} {compiler.cpp.extra_flags} {build.extra_flags} {includes} “{source_file}”, automatically converted to recipe.preproc.macros="{compiler.path}{compiler.cpp.cmd}" {compiler.cpp.flags} {preproc.macros.flags} -mmcu={build.mcu} -DF_CPU={build.f_cpu} -DARDUINO={runtime.ide.version} -DARDUINO_{build.board} -DARDUINO_ARCH_{build.arch} {compiler.cpp.extra_flags} {build.extra_flags} {includes} “{source_file}” -o “{preprocessed_file_path}”. Consider upgrading this core.
“/opt/tools/avr-gcc/4.8.1-arduino5/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_ADK -DARDUINO_ARCH_AVR “-I/opt/cores/arduino/avr/cores/arduino” “-I/opt/cores/arduino/avr/variants/mega” “/tmp/tmp/webide_tmp728250/sketch_feb20b/sketch/sketch_feb20b.ino.cpp” -o “/dev/null”
“/opt/tools/avr-gcc/4.8.1-arduino5/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_ADK -DARDUINO_ARCH_AVR “-I/opt/cores/arduino/avr/cores/arduino” “-I/opt/cores/arduino/avr/variants/mega” “-I/opt/cores/arduino/avr/libraries/Wire” “/tmp/tmp/webide_tmp728250/sketch_feb20b/sketch/sketch_feb20b.ino.cpp” -o “/dev/null”
<… missing output in file attached…> MEGA_ADK-WireExampleOutput.txt
Using library Wire at version 1.0 in folder: /opt/cores/arduino/avr/libraries/Wire
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x1e9801
avrdude: reading input file “C:/Users/Alex/AppData/Local/Temp/arduino-create-agent865913766/sketch_feb20b.ino.hex”
avrdude: writing flash (2348 bytes):
Writing | ################################################## | 100% 0.41s
avrdude: 2348 bytes of flash written
avrdude: verifying flash memory against C:/Users/Alex/AppData/Local/Temp/arduino-create-agent865913766/sketch_feb20b.ino.hex:
avrdude: load data flash data from input file C:/Users/Alex/AppData/Local/Temp/arduino-create-agent865913766/sketch_feb20b.ino.hex:
avrdude: input file C:/Users/Alex/AppData/Local/Temp/arduino-create-agent865913766/sketch_feb20b.ino.hex contains 2348 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.33s
avrdude: verifying …
avrdude: 2348 bytes of flash verified
avrdude: safemode: Fuses OK (H:00, E:00, L:00)
avrdude done. Thank you.
MEGA_ADK-WireExampleOutput.txt (19.8 KB)
