The verbose output is below. However, I see now that the library is being built as needed. That's good. So the actual problem is that, when I first was compiling my project after installing 2.2.1, I was getting quite a few warnings that I didn't expect. They mostly fell into two categories:
- The first were implicit conversion of long long to long. This would occur for printf format strings using %ul and passing a long long parameter. The long long were always a time_t type. So I would substitute "%llu" for "%lu" in those cases.
- The second class of warnings were potential buffer overflows where is calculated the worst-case string length that would exceed the buffer size. I would increase the buffer size for those.
As I was working through those, I would make one correction at a time and recompile. Sometimes the warning persisted, which looked like the file was not being compiled. I would make the edits again and recompile and eventually the specific warning I was fixing would go away.
Then all the remaining warnings went away. I supposed the library files weren't being compiled.
Now I see that the warnings just magically disappeared. I put the "%lu" back in and it compiles with no warnings. I tried this with each warning level (DEFAULT, MORE, and ALL) and did not see the long long warning again.
When I first started compiling the project, until just now, I did not change any Preferences.
So those initial warnings are a mystery. And I doubt I can reproduce them.
(I actually found those warnings to be useful, particularly the buffer overflows, so I wouldn't mind getting them back.)
Thanks for showing me how to look at issues like this, @ptillisch ! I only changed one instance of "%lu" to "%llu" in snCmdCl.cpp:72. Here is the pre- and post-edit verbose output that shows it built. Here is before the edit:
FQBN: teensy:avr:teensy35
Using board 'teensy35' from platform in folder: C:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1
Using core 'teensy3' from platform in folder: C:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1
Detecting libraries used...
C:\Users\me\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY35 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\cores\teensy3 C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\sketch\project-v2-teensy35.ino.cpp -o nul
Alternatives for snEepromCl.h: [SNTimeCl]
ResolveLibrary(snEepromCl.h)
-> candidates: [SNTimeCl]
C:\Users\me\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY35 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\cores\teensy3 -Ic:\Users\me\Documents\Arduino\libraries\SNTimeCl C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\sketch\project-v2-teensy35.ino.cpp -o nul
Alternatives for EEPROM.h: [EEPROM@2.0]
ResolveLibrary(EEPROM.h)
-> candidates: [EEPROM@2.0]
C:\Users\me\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY35 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\cores\teensy3 -Ic:\Users\me\Documents\Arduino\libraries\SNTimeCl -IC:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\EEPROM C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\sketch\project-v2-teensy35.ino.cpp -o nul
Alternatives for SdFat.h: [SdFat@2.1.2]
ResolveLibrary(SdFat.h)
-> candidates: [SdFat@2.1.2]
C:\Users\me\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY35 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\cores\teensy3 -Ic:\Users\me\Documents\Arduino\libraries\SNTimeCl -IC:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\EEPROM -IC:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SdFat\src C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\sketch\project-v2-teensy35.ino.cpp -o nul
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
-> candidates: [SPI@1.0]
C:\Users\me\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY35 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\cores\teensy3 -Ic:\Users\me\Documents\Arduino\libraries\SNTimeCl -IC:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\EEPROM -IC:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SdFat\src -IC:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SPI C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\sketch\project-v2-teensy35.ino.cpp -o nul
Alternatives for TimeAlarms.h: [TimeAlarms@1.5]
ResolveLibrary(TimeAlarms.h)
-> candidates: [TimeAlarms@1.5]
C:\Users\me\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY35 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\cores\teensy3 -Ic:\Users\me\Documents\Arduino\libraries\SNTimeCl -IC:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\EEPROM -IC:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SdFat\src -IC:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SPI -IC:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\TimeAlarms C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\sketch\project-v2-teensy35.ino.cpp -o nul
Alternatives for TimeLib.h: [Time@1.6.1]
ResolveLibrary(TimeLib.h)
-> candidates: [Time@1.6.1]
C:\Users\me\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY35 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\cores\teensy3 -Ic:\Users\me\Documents\Arduino\libraries\SNTimeCl -IC:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\EEPROM -IC:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SdFat\src -IC:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SPI -IC:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\TimeAlarms -IC:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\Time C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\sketch\project-v2-teensy35.ino.cpp -o nul
Alternatives for Statistic.h: [Statistic@1.0.5]
ResolveLibrary(Statistic.h)
-> candidates: [Statistic@1.0.5]
C:\Users\me\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY35 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\cores\teensy3 -Ic:\Users\me\Documents\Arduino\libraries\SNTimeCl -IC:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\EEPROM -IC:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SdFat\src -IC:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SPI -IC:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\TimeAlarms -IC:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\Time -Ic:\Users\me\Documents\Arduino\libraries\Statistic C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\sketch\project-v2-teensy35.ino.cpp -o nul
Using cached library dependencies for file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\sketch\AudioFIle.cpp
Using cached library dependencies for file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\sketch\motor.cpp
Using cached library dependencies for file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\sketch\sleepy_test_v2_hw.cpp
Using cached library dependencies for file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\sketch\sound.cpp
Using cached library dependencies for file: c:\Users\me\Documents\Arduino\libraries\SNTimeCl\snCmdCl.cpp
Using cached library dependencies for file: c:\Users\me\Documents\Arduino\libraries\SNTimeCl\snCommCl.cpp
Using cached library dependencies for file: c:\Users\me\Documents\Arduino\libraries\SNTimeCl\snEepromCl.cpp
Using cached library dependencies for file: c:\Users\me\Documents\Arduino\libraries\SNTimeCl\snLogCl.cpp
Using cached library dependencies for file: c:\Users\me\Documents\Arduino\libraries\SNTimeCl\snReadWriteCl.cpp
Using cached library dependencies for file: c:\Users\me\Documents\Arduino\libraries\SNTimeCl\snRestCl.cpp
Using cached library dependencies for file: c:\Users\me\Documents\Arduino\libraries\SNTimeCl\snTimeCl.cpp
Using cached library dependencies for file: C:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\EEPROM\EEPROM.cpp
Using cached library dependencies for file: C:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SdFat\src\ExFatLib\ExFatDbg.cpp
Using cached library dependencies for file: C:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SdFat\src\ExFatLib\ExFatFile.cpp
Using cached library dependencies for file: C:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SdFat\src\ExFatLib\ExFatFilePrint.cpp
Using cached library dependencies for file: C:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SdFat\src\ExFatLib\ExFatFileWrite.cpp
Using cached library dependencies for file: C:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SdFat\src\ExFatLib\ExFatFormatter.cpp
Using cached library dependencies for file: C:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SdFat\src\ExFatLib\ExFatName.cpp
Using cached library dependencies for file: C:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SdFat\src\ExFatLib\ExFatPartition.cpp
Using cached library dependencies for file: C:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SdFat\src\ExFatLib\ExFatVolume.cpp
Using cached library dependencies for file: C:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SdFat\src\ExFatLib\upcase.cpp
Using cached library dependencies for file: C:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SdFat\src\FatLib\FatDbg.cpp
Using cached library dependencies for file: C:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SdFat\src\FatLib\FatFile.cpp
Using cached library dependencies for file: C:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SdFat\src\FatLib\FatFileLFN.cpp
Using cached library dependencies for file: C:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SdFat\src\FatLib\FatFilePrint.cpp
Using cached library dependencies for file: C:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SdFat\src\FatLib\FatFileSFN.cpp
Using cached library dependencies for file: C:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SdFat\src\FatLib\FatFormatter.cpp
Using cached library dependencies for file: C:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SdFat\src\FatLib\FatName.cpp
Using cached library dependencies for file: C:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SdFat\src\FatLib\FatPartition.cpp
Using cached library dependencies for file: C:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SdFat\src\FatLib\FatVolume.cpp
Using cached library dependencies for file: C:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SdFat\src\FreeStack.cpp
Using cached library dependencies for file: C:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SdFat\src\FsLib\FsFile.cpp
Using cached library dependencies for file: C:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SdFat\src\FsLib\FsNew.cpp
Using cached library dependencies for file: C:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SdFat\src\FsLib\FsVolume.cpp
Using cached library dependencies for file: C:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SdFat\src\MinimumSerial.cpp
Using cached library dependencies for file: C:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SdFat\src\SdCard\SdCardInfo.cpp
Using cached library dependencies for file: C:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SdFat\src\SdCard\SdSpiCard.cpp
Using cached library dependencies for file: C:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SdFat\src\SdCard\SdioTeensy.cpp
Using cached library dependencies for file: C:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SdFat\src\SpiDriver\SdSpiArtemis.cpp
Using cached library dependencies for file: C:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SdFat\src\SpiDriver\SdSpiChipSelect.cpp
Using cached library dependencies for file: C:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SdFat\src\SpiDriver\SdSpiDue.cpp
Using cached library dependencies for file: C:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SdFat\src\SpiDriver\SdSpiESP.cpp
Using cached library dependencies for file: C:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SdFat\src\SpiDriver\SdSpiParticle.cpp
Using cached library dependencies for file: C:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SdFat\src\SpiDriver\SdSpiSTM32.cpp
Using cached library dependencies for file: C:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SdFat\src\SpiDriver\SdSpiSTM32Core.cpp
Using cached library dependencies for file: C:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SdFat\src\SpiDriver\SdSpiTeensy3.cpp
Using cached library dependencies for file: C:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SdFat\src\common\FmtNumber.cpp
Using cached library dependencies for file: C:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SdFat\src\common\FsCache.cpp
Using cached library dependencies for file: C:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SdFat\src\common\FsDateTime.cpp
Using cached library dependencies for file: C:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SdFat\src\common\FsName.cpp
Using cached library dependencies for file: C:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SdFat\src\common\FsStructs.cpp
Using cached library dependencies for file: C:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SdFat\src\common\FsUtf.cpp
Using cached library dependencies for file: C:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SdFat\src\common\PrintBasic.cpp
Using cached library dependencies for file: C:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SdFat\src\common\upcase.cpp
Using cached library dependencies for file: C:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SdFat\src\iostream\StdioStream.cpp
Using cached library dependencies for file: C:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SdFat\src\iostream\StreamBaseClass.cpp
Using cached library dependencies for file: C:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SdFat\src\iostream\istream.cpp
Using cached library dependencies for file: C:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SdFat\src\iostream\ostream.cpp
Using cached library dependencies for file: C:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SPI\SPI.cpp
Using cached library dependencies for file: C:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\TimeAlarms\TimeAlarms.cpp
Using cached library dependencies for file: C:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\Time\DateStrings.cpp
Using cached library dependencies for file: C:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\Time\Time.cpp
Generating function prototypes...
C:\Users\me\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY35 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\cores\teensy3 -Ic:\Users\me\Documents\Arduino\libraries\SNTimeCl -IC:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\EEPROM -IC:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SdFat\src -IC:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SPI -IC:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\TimeAlarms -IC:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\Time -Ic:\Users\me\Documents\Arduino\libraries\Statistic C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\sketch\project-v2-teensy35.ino.cpp -o C:\Users\me\AppData\Local\Temp\618594172\sketch_merged.cpp
C:\Users\me\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\me\AppData\Local\Temp\618594172\sketch_merged.cpp
Compiling sketch...
"C:\\Users\\me\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-tools\\1.58.0/precompile_helper" "C:\\Users\\me\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.1/cores/teensy3" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD" "C:\\Users\\me\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-g++" -x c++-header -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY35 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\me\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.1/cores/teensy3" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD/pch/Arduino.h" -o "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD/pch/Arduino.h.gch"
Using previously compiled file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\pch\Arduino.h.gch
"C:\\Users\\me\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY35 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD/pch" "-IC:\\Users\\me\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.1\\cores\\teensy3" "-Ic:\\Users\\me\\Documents\\Arduino\\libraries\\SNTimeCl" "-IC:\\Users\\me\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.1\\libraries\\EEPROM" "-IC:\\Users\\me\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.1\\libraries\\SdFat\\src" "-IC:\\Users\\me\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.1\\libraries\\SPI" "-IC:\\Users\\me\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.1\\libraries\\TimeAlarms" "-IC:\\Users\\me\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.1\\libraries\\Time" "-Ic:\\Users\\me\\Documents\\Arduino\\libraries\\Statistic" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\sketch\\project-v2-teensy35.ino.cpp" -o "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\sketch\\project-v2-teensy35.ino.cpp.o"
Using previously compiled file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\sketch\AudioFIle.cpp.o
Using previously compiled file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\sketch\motor.cpp.o
Using previously compiled file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\sketch\sleepy_test_v2_hw.cpp.o
Using previously compiled file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\sketch\sound.cpp.o
Compiling libraries...
Compiling library "SNTimeCl"
Using previously compiled file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\libraries\SNTimeCl\snCommCl.cpp.o
Using previously compiled file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\libraries\SNTimeCl\snEepromCl.cpp.o
Using previously compiled file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\libraries\SNTimeCl\snLogCl.cpp.o
Using previously compiled file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\libraries\SNTimeCl\snCmdCl.cpp.o
Using previously compiled file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\libraries\SNTimeCl\snRestCl.cpp.o
Using previously compiled file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\libraries\SNTimeCl\snReadWriteCl.cpp.o
Using previously compiled file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\libraries\SNTimeCl\snTimeCl.cpp.o
Compiling library "EEPROM"
Using previously compiled file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\libraries\EEPROM\EEPROM.cpp.o
Compiling library "SdFat"
Using previously compiled file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\libraries\SdFat\ExFatLib\ExFatFile.cpp.o
Using previously compiled file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\libraries\SdFat\ExFatLib\ExFatFileWrite.cpp.o
Using previously compiled file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\libraries\SdFat\ExFatLib\ExFatDbg.cpp.o
Using previously compiled file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\libraries\SdFat\ExFatLib\ExFatFilePrint.cpp.o
Using previously compiled file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\libraries\SdFat\ExFatLib\ExFatFormatter.cpp.o
Using previously compiled file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\libraries\SdFat\ExFatLib\upcase.cpp.o
Using previously compiled file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\libraries\SdFat\ExFatLib\ExFatName.cpp.o
Using previously compiled file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\libraries\SdFat\ExFatLib\ExFatPartition.cpp.o
Using previously compiled file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\libraries\SdFat\FatLib\FatFileLFN.cpp.o
Using previously compiled file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\libraries\SdFat\FatLib\FatDbg.cpp.o
Using previously compiled file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\libraries\SdFat\FatLib\FatFile.cpp.o
Using previously compiled file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\libraries\SdFat\ExFatLib\ExFatVolume.cpp.o
Using previously compiled file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\libraries\SdFat\FatLib\FatFilePrint.cpp.o
Using previously compiled file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\libraries\SdFat\FatLib\FatFileSFN.cpp.o
Using previously compiled file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\libraries\SdFat\FatLib\FatName.cpp.o
Using previously compiled file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\libraries\SdFat\FreeStack.cpp.o
Using previously compiled file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\libraries\SdFat\FatLib\FatFormatter.cpp.o
Using previously compiled file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\libraries\SdFat\FatLib\FatPartition.cpp.o
Using previously compiled file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\libraries\SdFat\FsLib\FsNew.cpp.o
Using previously compiled file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\libraries\SdFat\FatLib\FatVolume.cpp.o
Using previously compiled file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\libraries\SdFat\FsLib\FsFile.cpp.o
Using previously compiled file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\libraries\SdFat\SdCard\SdCardInfo.cpp.o
Using previously compiled file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\libraries\SdFat\MinimumSerial.cpp.o
Using previously compiled file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\libraries\SdFat\SdCard\SdSpiCard.cpp.o
Using previously compiled file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\libraries\SdFat\FsLib\FsVolume.cpp.o
Using previously compiled file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\libraries\SdFat\SdCard\SdioTeensy.cpp.o
Using previously compiled file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\libraries\SdFat\SpiDriver\SdSpiChipSelect.cpp.o
Using previously compiled file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\libraries\SdFat\SpiDriver\SdSpiArtemis.cpp.o
Using previously compiled file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\libraries\SdFat\SpiDriver\SdSpiParticle.cpp.o
Using previously compiled file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\libraries\SdFat\SpiDriver\SdSpiSTM32.cpp.o
Using previously compiled file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\libraries\SdFat\SpiDriver\SdSpiSTM32Core.cpp.o
Using previously compiled file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\libraries\SdFat\common\FmtNumber.cpp.o
Using previously compiled file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\libraries\SdFat\SpiDriver\SdSpiDue.cpp.o
Using previously compiled file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\libraries\SdFat\SpiDriver\SdSpiESP.cpp.o
Using previously compiled file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\libraries\SdFat\SpiDriver\SdSpiTeensy3.cpp.o
Using previously compiled file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\libraries\SdFat\common\FsCache.cpp.o
Using previously compiled file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\libraries\SdFat\common\FsUtf.cpp.o
Using previously compiled file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\libraries\SdFat\common\FsName.cpp.o
Using previously compiled file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\libraries\SdFat\common\upcase.cpp.o
Using previously compiled file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\libraries\SdFat\common\FsDateTime.cpp.o
Using previously compiled file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\libraries\SdFat\common\FsStructs.cpp.o
Using previously compiled file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\libraries\SdFat\common\PrintBasic.cpp.o
Using previously compiled file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\libraries\SdFat\iostream\StreamBaseClass.cpp.o
Using previously compiled file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\libraries\SdFat\iostream\StdioStream.cpp.o
Using previously compiled file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\libraries\SdFat\iostream\istream.cpp.o
Using previously compiled file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\libraries\SdFat\iostream\ostream.cpp.o
Compiling library "SPI"
Using previously compiled file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\libraries\SPI\SPI.cpp.o
Compiling library "TimeAlarms"
Using previously compiled file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\libraries\TimeAlarms\TimeAlarms.cpp.o
Compiling library "Time"
Using previously compiled file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\libraries\Time\Time.cpp.o
Using previously compiled file: C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\libraries\Time\DateStrings.cpp.o
Compiling library "Statistic"
Compiling core...
Using precompiled core: C:\Users\me\AppData\Local\Temp\arduino\cores\teensy_avr_teensy35_usb_serial,speed_120,opt_o2std,keys_en-us_3146ed455d7c9d798a4376d2b5e2a720\core.a
Linking everything together...
"C:\\Users\\me\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc" -O2 -Wl,--gc-sections,--relax,--defsym=__rtc_localtime=1699473123 "-TC:\\Users\\me\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.1\\cores\\teensy3/mk64fx512.ld" -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -o "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD/project-v2-teensy35.ino.elf" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\sketch\\AudioFIle.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\sketch\\motor.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\sketch\\sleepy_test_v2_hw.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\sketch\\project-v2-teensy35.ino.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\sketch\\sound.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SNTimeCl\\snCmdCl.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SNTimeCl\\snCommCl.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SNTimeCl\\snEepromCl.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SNTimeCl\\snLogCl.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SNTimeCl\\snReadWriteCl.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SNTimeCl\\snRestCl.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SNTimeCl\\snTimeCl.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\EEPROM\\EEPROM.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\ExFatLib\\ExFatDbg.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\ExFatLib\\ExFatFile.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\ExFatLib\\ExFatFilePrint.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\ExFatLib\\ExFatFileWrite.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\ExFatLib\\ExFatFormatter.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\ExFatLib\\ExFatName.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\ExFatLib\\ExFatPartition.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\ExFatLib\\ExFatVolume.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\ExFatLib\\upcase.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\FatLib\\FatDbg.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\FatLib\\FatFile.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\FatLib\\FatFileLFN.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\FatLib\\FatFilePrint.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\FatLib\\FatFileSFN.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\FatLib\\FatFormatter.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\FatLib\\FatName.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\FatLib\\FatPartition.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\FatLib\\FatVolume.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\FreeStack.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\FsLib\\FsFile.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\FsLib\\FsNew.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\FsLib\\FsVolume.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\MinimumSerial.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\SdCard\\SdCardInfo.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\SdCard\\SdSpiCard.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\SdCard\\SdioTeensy.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\SpiDriver\\SdSpiArtemis.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\SpiDriver\\SdSpiChipSelect.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\SpiDriver\\SdSpiDue.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\SpiDriver\\SdSpiESP.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\SpiDriver\\SdSpiParticle.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\SpiDriver\\SdSpiSTM32.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\SpiDriver\\SdSpiSTM32Core.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\SpiDriver\\SdSpiTeensy3.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\common\\FmtNumber.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\common\\FsCache.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\common\\FsDateTime.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\common\\FsName.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\common\\FsStructs.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\common\\FsUtf.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\common\\PrintBasic.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\common\\upcase.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\iostream\\StdioStream.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\iostream\\StreamBaseClass.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\iostream\\istream.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\iostream\\ostream.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SPI\\SPI.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\TimeAlarms\\TimeAlarms.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\Time\\DateStrings.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\Time\\Time.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD/..\\..\\cores\\teensy_avr_teensy35_usb_serial,speed_120,opt_o2std,keys_en-us_3146ed455d7c9d798a4376d2b5e2a720\\core.a" "-LC:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD" -larm_cortexM4lf_math -lm -lstdc++
"C:\\Users\\me\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD/project-v2-teensy35.ino.elf" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD/project-v2-teensy35.ino.eep"
"C:\\Users\\me\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-objcopy" -O ihex -R .eeprom "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD/project-v2-teensy35.ino.elf" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD/project-v2-teensy35.ino.hex"
"C:\\Users\\me\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-tools\\1.58.0/teensy_secure" encrypthex TEENSY35 "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD/project-v2-teensy35.ino.hex"
This board does not support code encryption
"C:\\Users\\me\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-tools\\1.58.0/teensy_post_compile" -file=project-v2-teensy35.ino "-path=C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD" "-tools=C:\\Users\\me\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-tools\\1.58.0/" -board=TEENSY35
"C:\\Users\\me\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-tools\\1.58.0/stdout_redirect" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD/project-v2-teensy35.ino.sym" "C:\\Users\\me\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-objdump" -t -C "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD/project-v2-teensy35.ino.elf"
"C:\\Users\\me\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-tools\\1.58.0/teensy_size" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD/project-v2-teensy35.ino.elf"
"C:\\Users\\me\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-tools\\1.58.0/stdout_redirect" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD/project-v2-teensy35.ino.lst" "C:\\Users\\me\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-objdump" -d -S -C "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD/project-v2-teensy35.ino.elf"
Using library SNTimeCl in folder: C:\Users\me\Documents\Arduino\libraries\SNTimeCl (legacy)
Using library EEPROM at version 2.0 in folder: C:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\EEPROM
Using library SdFat at version 2.1.2 in folder: C:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SdFat
Using library SPI at version 1.0 in folder: C:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SPI
Using library TimeAlarms at version 1.5 in folder: C:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\TimeAlarms
Using library Time at version 1.6.1 in folder: C:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\Time
Using library Statistic at version 1.0.5 in folder: C:\Users\me\Documents\Arduino\libraries\Statistic
"C:\\Users\\me\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-size" -A "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD/project-v2-teensy35.ino.elf"
Sketch uses 327376 bytes (62%) of program storage space. Maximum is 524288 bytes.
Global variables use 14080 bytes (5%) of dynamic memory, leaving 248056 bytes for local variables. Maximum is 262136 bytes.
And here is the post-edit output:
C:\Users\me\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY35 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\cores\teensy3 -Ic:\Users\me\Documents\Arduino\libraries\SNTimeCl -IC:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\EEPROM -IC:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SdFat\src -IC:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SPI -IC:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\TimeAlarms -IC:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\Time -Ic:\Users\me\Documents\Arduino\libraries\Statistic c:\Users\me\Documents\Arduino\libraries\SNTimeCl\snCmdCl.cpp -o nul
C:\Users\me\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY35 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\cores\teensy3 -Ic:\Users\me\Documents\Arduino\libraries\SNTimeCl -IC:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\EEPROM -IC:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SdFat\src -IC:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SPI -IC:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\TimeAlarms -IC:\Users\me\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\Time -Ic:\Users\me\Documents\Arduino\libraries\Statistic C:\Users\me\AppData\Local\Temp\arduino\sketches\52727AC3EC0A62F194516ABECA6826BD\sketch\project-v2-teensy35.ino.cpp -o C:\Users\me\AppData\Local\Temp\3948041193\sketch_merged.cpp
C:\Users\me\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\me\AppData\Local\Temp\3948041193\sketch_merged.cpp
Compiling sketch...
"C:\\Users\\me\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=158 -DARDUINO=10607 -DARDUINO_TEENSY35 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD/pch" "-IC:\\Users\\me\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.1\\cores\\teensy3" "-Ic:\\Users\\me\\Documents\\Arduino\\libraries\\SNTimeCl" "-IC:\\Users\\me\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.1\\libraries\\EEPROM" "-IC:\\Users\\me\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.1\\libraries\\SdFat\\src" "-IC:\\Users\\me\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.1\\libraries\\SPI" "-IC:\\Users\\me\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.1\\libraries\\TimeAlarms" "-IC:\\Users\\me\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.1\\libraries\\Time" "-Ic:\\Users\\me\\Documents\\Arduino\\libraries\\Statistic" "c:\\Users\\me\\Documents\\Arduino\\libraries\\SNTimeCl\\snCmdCl.cpp" -o "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SNTimeCl\\snCmdCl.cpp.o"
Compiling core...
"C:\\Users\\me\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc" -O2 -Wl,--gc-sections,--relax,--defsym=__rtc_localtime=1699473372 "-TC:\\Users\\me\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.1\\cores\\teensy3/mk64fx512.ld" -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -o "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD/project-v2-teensy35.ino.elf" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\sketch\\AudioFIle.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\sketch\\motor.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\sketch\\sleepy_test_v2_hw.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\sketch\\project-v2-teensy35.ino.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\sketch\\sound.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SNTimeCl\\snCmdCl.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SNTimeCl\\snCommCl.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SNTimeCl\\snEepromCl.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SNTimeCl\\snLogCl.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SNTimeCl\\snReadWriteCl.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SNTimeCl\\snRestCl.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SNTimeCl\\snTimeCl.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\EEPROM\\EEPROM.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\ExFatLib\\ExFatDbg.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\ExFatLib\\ExFatFile.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\ExFatLib\\ExFatFilePrint.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\ExFatLib\\ExFatFileWrite.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\ExFatLib\\ExFatFormatter.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\ExFatLib\\ExFatName.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\ExFatLib\\ExFatPartition.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\ExFatLib\\ExFatVolume.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\ExFatLib\\upcase.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\FatLib\\FatDbg.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\FatLib\\FatFile.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\FatLib\\FatFileLFN.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\FatLib\\FatFilePrint.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\FatLib\\FatFileSFN.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\FatLib\\FatFormatter.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\FatLib\\FatName.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\FatLib\\FatPartition.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\FatLib\\FatVolume.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\FreeStack.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\FsLib\\FsFile.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\FsLib\\FsNew.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\FsLib\\FsVolume.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\MinimumSerial.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\SdCard\\SdCardInfo.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\SdCard\\SdSpiCard.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\SdCard\\SdioTeensy.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\SpiDriver\\SdSpiArtemis.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\SpiDriver\\SdSpiChipSelect.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\SpiDriver\\SdSpiDue.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\SpiDriver\\SdSpiESP.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\SpiDriver\\SdSpiParticle.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\SpiDriver\\SdSpiSTM32.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\SpiDriver\\SdSpiSTM32Core.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\SpiDriver\\SdSpiTeensy3.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\common\\FmtNumber.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\common\\FsCache.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\common\\FsDateTime.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\common\\FsName.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\common\\FsStructs.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\common\\FsUtf.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\common\\PrintBasic.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\common\\upcase.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\iostream\\StdioStream.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\iostream\\StreamBaseClass.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\iostream\\istream.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SdFat\\iostream\\ostream.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\SPI\\SPI.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\TimeAlarms\\TimeAlarms.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\Time\\DateStrings.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD\\libraries\\Time\\Time.cpp.o" "C:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD/..\\..\\cores\\teensy_avr_teensy35_usb_serial,speed_120,opt_o2std,keys_en-us_3146ed455d7c9d798a4376d2b5e2a720\\core.a" "-LC:\\Users\\me\\AppData\\Local\\Temp\\arduino\\sketches\\52727AC3EC0A62F194516ABECA6826BD" -larm_cortexM4lf_math -lm -lstdc++
Thanks, again!
