Hi, I have a Scott Edwards LCD backpack. I have had to use the NewSoftSerial library as it SE backpack uses inverted signals.
I am new Arduino and cant work out how to also send data to and throw via the USB serial at the same time.
The programme I am using is below and I can see that it has declared pin 2 and 3 for rx and tx. Is this why I cant send data back to the serial monitor?
Can anyone tell me how to also use the serial monitor via the USB while using this programme.
Thanks
Simon
#include <NewSoftSerial.h>
#define rxPin 2 // unused, but necessary to create 'lcd' object
#define txPin 3
#define INVERTED true // this is impossible with standard Software Serial library
NewSoftSerial lcd(rxPin, txPin,INVERTED); // set up a new inverted serial port on pins 2 and 3
pinMode(rxPin, INPUT); // define pin modes for tx, rx:
pinMode(txPin, OUTPUT);
lcd.begin(9600);
delay(100); // necessary to wait after powering up
lcd.print(254,BYTE); // 254 is a command prefix
lcd.print(1,BYTE); // 1 is a Display Clear command
delay(10); // this command takes long time
lcd.print(254,BYTE); // for unknown reasons this is
lcd.print(1,BYTE); // necessary to repeat 2x
delay(10);
lcd.print(2 ,BYTE); // 2 is a Home command
delay(10);
lcd.print("Hello, World!");
lcd.print(192,BYTE); // set the cursor to column 0, line 1
lcd.print(millis()/1000); // print the number of seconds since reset:
