I am a newby to Arduino.
I made up a basic IO sketch last night with no external libraries and it works fine on my Uno R3.
I want this board to interface with "Loconet" (model railway) so I have downloaded the latest LocoNet Library I can find, it loads as expected with both the .cpp and .h files in the library folder but when I do the "include", the name doesn't change colour and the compiler fails on "unknown file LocoNet.h"
Ok possibly a problem with this library, so I randomly try a few native libraries. Such as ethernet...well half of the listed includes change colour half dont. When I check the Library it has all the ones listed in both .h and .cpp....cant work out whats wrong.
Try a different library that by chance only had 1 include and it worked fine....
I have changed the IDE 1.6.3 software to load in compatibility mode, load in admin mode, I have removed and then re-installed running as administrator....... same problem. Win8 64bit, so I bailed to my desktop. Win7 64 bit....... guess what same issue!!!
Whats the chances this is a 64 bit operating system issue??
Can someone help and give me a why and what to do to fix it pls.
Library is installed in the location the "properties" window refers to ..\mydocuments\arduino\
In frustration I have also copied it to the directory my sketch is in and the c:\programs\ directory.
As I said though it is not just the library I am after, I tried a couple of the default libraries such as Ethernet and it didn't work either only a couple of the "includes" were recognized.
Thanks for any help to solve this issue...
oh and yes it was shut down and started many times in the last 24 hours, including the entire PC (all 3 of them, 1 x Win 8, 1 x Win7, 1 x XP) all have the exact same issue. I am beginning to think it may be an issue with 1.6.3 and windows.
Ghosty
The "Properties" window refers to the "Sketchbook location". That is where your sketches are saved. That is ALSO where you create the directory called "libraries". Inside that "libraries" directory you create a directory for each of the third-party libraries, usually each is named the same as the main .h file they contain. In your case the .h file would be:
Thanks very much, the problem was the "include libraries" in my case "Loconet" was not under the Libraries directory, but under the sketch folder as you say, in the NRMA folder.
I had mydoc\library\nrma\loconet
All my sketches are in the "library" folder, I now have the folder structure
mydoc\library\library\loconet and it is working fine.
Placing it under the Library folder has solved the issue.
