Hi everyone,
I have a problem; I have an error which tells me this:
and I couldn't find this library, it's my first time receiving this type or error.
c:\Users\alexi\OneDrive\Documents\Arduino\libraries\Adafruit_SSD1306\Adafruit_SSD1306.cpp:42:10: fatal error: pgmspace.h: No such file or directory
#include <pgmspace.h>
compilation terminated.
exit status 1
Compilation error: exit status 1
Hi @elmajinos . Which version of Arduino IDE are you using (e.g., "2.0.1")? The version is shown on the window title bar and also in the Help > About dialog.
I ask for this information because I want to give you the appropriate instructions for the IDE version you are using.
I'm using the 2.03 version.
thanks for you're answer
OK, I'm going to ask you to post some additional information that might help us to identify the problem.
NOTE: These instructions will not solve the problem. They are only intended to gather more information which might provide a clue that eventually leads to a solution.
Please do this:
Select File > Preferences from the Arduino IDE menus.
Check the box next to "Show verbose output during: ☐ compilation ".
Click the OK button.
Select Sketch > Verify/Compile from the Arduino IDE menus.
Wait for the compilation to fail.
You will see a "Compilation error: ... " notification at the bottom right corner of the Arduino IDE window. Click the COPY ERROR MESSAGES button on that notification.
Open a forum reply here by clicking the Reply button.
Click the </>
icon on the post composer toolbar.
This will add the forum's code block markup (```
) to your reply to make sure the error messages are correctly formatted.
Press Ctrl +V .
This will paste the compilation output into the code block.
Move the cursor outside of the code tags before you add any additional text to your reply.
Click the Reply button to post the output.
In case the output is longer than the forum software will allow to be added to a post, you can instead save it to a .txt
file and then attach that file to a reply here:
Open any text editor program.
Paste the copied output into the text editor.
Save the file in .txt
format.
Click the "Upload" icon ( ) on the post composer toolbar:
Select the .txt
file you saved.
Click the Open button.
Click the Reply button to publish the post.
Alternatively, instead of using the "Upload" icon on the post composer toolbar as described in steps (5) - (7) above, you can simply drag and drop the .txt
file onto the post composer field to attach it.
exit status 1
Is it okay?
No. I need the full verbose output. Please follow the instructions I provided in my previous reply. If you have any questions or problems while following them, just let me know and I'll help out.
Using board 'nanorp2040connect' from platform in folder: C:\Users\alexi\AppData\Local\Arduino15\packages\arduino\hardware\mbed_nano\3.5.1
Using core 'arduino' from platform in folder: C:\Users\alexi\AppData\Local\Arduino15\packages\arduino\hardware\mbed_nano\3.5.1
Detecting libraries used...
"C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT/defines.txt" "@C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT/cxxflags.txt" -DARDUINO_ARCH_RP2040 -mcpu=cortex-m0plus -w -x c++ -E -CC -DARDUINO=10607 -DARDUINO_NANO_RP2040_CONNECT -DARDUINO_ARCH_MBED_NANO -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino/api/deprecated" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino/api/deprecated-avr-comp" "-iprefixC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino" "@C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT/includes.txt" "C:\\Users\\alexi\\AppData\\Local\\Temp\\arduino-sketch-8202E3DFAA6B02BBA374C47A727E3C71\\sketch\\CO2_monitor.ino.cpp" -o nul
Alternative pour Wire.h: [Wire]
ResolveLibrary(Wire.h)
-> candidates: [Wire]
"C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT/defines.txt" "@C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT/cxxflags.txt" -DARDUINO_ARCH_RP2040 -mcpu=cortex-m0plus -w -x c++ -E -CC -DARDUINO=10607 -DARDUINO_NANO_RP2040_CONNECT -DARDUINO_ARCH_MBED_NANO -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\libraries\\Wire" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino/api/deprecated" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino/api/deprecated-avr-comp" "-iprefixC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino" "@C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT/includes.txt" "C:\\Users\\alexi\\AppData\\Local\\Temp\\arduino-sketch-8202E3DFAA6B02BBA374C47A727E3C71\\sketch\\CO2_monitor.ino.cpp" -o nul
Alternative pour Adafruit_GFX.h: [Adafruit GFX Library@1.11.3]
ResolveLibrary(Adafruit_GFX.h)
-> candidates: [Adafruit GFX Library@1.11.3]
"C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT/defines.txt" "@C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT/cxxflags.txt" -DARDUINO_ARCH_RP2040 -mcpu=cortex-m0plus -w -x c++ -E -CC -DARDUINO=10607 -DARDUINO_NANO_RP2040_CONNECT -DARDUINO_ARCH_MBED_NANO -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\libraries\\Wire" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino/api/deprecated" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino/api/deprecated-avr-comp" "-iprefixC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino" "@C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT/includes.txt" "C:\\Users\\alexi\\AppData\\Local\\Temp\\arduino-sketch-8202E3DFAA6B02BBA374C47A727E3C71\\sketch\\CO2_monitor.ino.cpp" -o nul
Alternative pour Adafruit_I2CDevice.h: [Adafruit BusIO@1.14.1]
ResolveLibrary(Adafruit_I2CDevice.h)
-> candidates: [Adafruit BusIO@1.14.1]
"C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT/defines.txt" "@C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT/cxxflags.txt" -DARDUINO_ARCH_RP2040 -mcpu=cortex-m0plus -w -x c++ -E -CC -DARDUINO=10607 -DARDUINO_NANO_RP2040_CONNECT -DARDUINO_ARCH_MBED_NANO -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\libraries\\Wire" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino/api/deprecated" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino/api/deprecated-avr-comp" "-iprefixC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino" "@C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT/includes.txt" "C:\\Users\\alexi\\AppData\\Local\\Temp\\arduino-sketch-8202E3DFAA6B02BBA374C47A727E3C71\\sketch\\CO2_monitor.ino.cpp" -o nul
Alternative pour SPI.h: [SPI]
ResolveLibrary(SPI.h)
-> candidates: [SPI]
"C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT/defines.txt" "@C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT/cxxflags.txt" -DARDUINO_ARCH_RP2040 -mcpu=cortex-m0plus -w -x c++ -E -CC -DARDUINO=10607 -DARDUINO_NANO_RP2040_CONNECT -DARDUINO_ARCH_MBED_NANO -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\libraries\\Wire" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\libraries\\SPI" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino/api/deprecated" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino/api/deprecated-avr-comp" "-iprefixC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino" "@C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT/includes.txt" "C:\\Users\\alexi\\AppData\\Local\\Temp\\arduino-sketch-8202E3DFAA6B02BBA374C47A727E3C71\\sketch\\CO2_monitor.ino.cpp" -o nul
Alternative pour Adafruit_SSD1306.h: [Adafruit SSD1306@2.5.7]
ResolveLibrary(Adafruit_SSD1306.h)
-> candidates: [Adafruit SSD1306@2.5.7]
"C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT/defines.txt" "@C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT/cxxflags.txt" -DARDUINO_ARCH_RP2040 -mcpu=cortex-m0plus -w -x c++ -E -CC -DARDUINO=10607 -DARDUINO_NANO_RP2040_CONNECT -DARDUINO_ARCH_MBED_NANO -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\libraries\\Wire" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\libraries\\SPI" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino/api/deprecated" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino/api/deprecated-avr-comp" "-iprefixC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino" "@C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT/includes.txt" "C:\\Users\\alexi\\AppData\\Local\\Temp\\arduino-sketch-8202E3DFAA6B02BBA374C47A727E3C71\\sketch\\CO2_monitor.ino.cpp" -o nul
Alternative pour DHT.h: [DHT sensor library@1.4.4]
ResolveLibrary(DHT.h)
-> candidates: [DHT sensor library@1.4.4]
"C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT/defines.txt" "@C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT/cxxflags.txt" -DARDUINO_ARCH_RP2040 -mcpu=cortex-m0plus -w -x c++ -E -CC -DARDUINO=10607 -DARDUINO_NANO_RP2040_CONNECT -DARDUINO_ARCH_MBED_NANO -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\libraries\\Wire" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\libraries\\SPI" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\DHT_sensor_library" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino/api/deprecated" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino/api/deprecated-avr-comp" "-iprefixC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino" "@C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT/includes.txt" "C:\\Users\\alexi\\AppData\\Local\\Temp\\arduino-sketch-8202E3DFAA6B02BBA374C47A727E3C71\\sketch\\CO2_monitor.ino.cpp" -o nul
Alternative pour MQ135.h: [MQ135@1.1.0]
ResolveLibrary(MQ135.h)
-> candidates: [MQ135@1.1.0]
"C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT/defines.txt" "@C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT/cxxflags.txt" -DARDUINO_ARCH_RP2040 -mcpu=cortex-m0plus -w -x c++ -E -CC -DARDUINO=10607 -DARDUINO_NANO_RP2040_CONNECT -DARDUINO_ARCH_MBED_NANO -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\libraries\\Wire" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\libraries\\SPI" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\DHT_sensor_library" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\MQ135" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino/api/deprecated" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino/api/deprecated-avr-comp" "-iprefixC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino" "@C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT/includes.txt" "C:\\Users\\alexi\\AppData\\Local\\Temp\\arduino-sketch-8202E3DFAA6B02BBA374C47A727E3C71\\sketch\\CO2_monitor.ino.cpp" -o nul
"C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT/defines.txt" "@C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT/cxxflags.txt" -DARDUINO_ARCH_RP2040 -mcpu=cortex-m0plus -w -x c++ -E -CC -DARDUINO=10607 -DARDUINO_NANO_RP2040_CONNECT -DARDUINO_ARCH_MBED_NANO -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\libraries\\Wire" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\libraries\\SPI" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\DHT_sensor_library" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\MQ135" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino/api/deprecated" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino/api/deprecated-avr-comp" "-iprefixC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino" "@C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT/includes.txt" "C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\libraries\\Wire\\Wire.cpp" -o nul
"C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT/defines.txt" "@C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT/cxxflags.txt" -DARDUINO_ARCH_RP2040 -mcpu=cortex-m0plus -w -x c++ -E -CC -DARDUINO=10607 -DARDUINO_NANO_RP2040_CONNECT -DARDUINO_ARCH_MBED_NANO -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\libraries\\Wire" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\libraries\\SPI" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\DHT_sensor_library" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\MQ135" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino/api/deprecated" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino/api/deprecated-avr-comp" "-iprefixC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino" "@C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT/includes.txt" "c:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library\\Adafruit_GFX.cpp" -o nul
"C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT/defines.txt" "@C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT/cxxflags.txt" -DARDUINO_ARCH_RP2040 -mcpu=cortex-m0plus -w -x c++ -E -CC -DARDUINO=10607 -DARDUINO_NANO_RP2040_CONNECT -DARDUINO_ARCH_MBED_NANO -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\libraries\\Wire" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\libraries\\SPI" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\DHT_sensor_library" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\MQ135" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino/api/deprecated" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino/api/deprecated-avr-comp" "-iprefixC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino" "@C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT/includes.txt" "c:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library\\Adafruit_GrayOLED.cpp" -o nul
"C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT/defines.txt" "@C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT/cxxflags.txt" -DARDUINO_ARCH_RP2040 -mcpu=cortex-m0plus -w -x c++ -E -CC -DARDUINO=10607 -DARDUINO_NANO_RP2040_CONNECT -DARDUINO_ARCH_MBED_NANO -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\libraries\\Wire" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\libraries\\SPI" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\DHT_sensor_library" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\MQ135" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino/api/deprecated" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino/api/deprecated-avr-comp" "-iprefixC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino" "@C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT/includes.txt" "c:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library\\Adafruit_SPITFT.cpp" -o nul
"C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT/defines.txt" "@C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT/cxxflags.txt" -DARDUINO_ARCH_RP2040 -mcpu=cortex-m0plus -w -x c++ -E -CC -DARDUINO=10607 -DARDUINO_NANO_RP2040_CONNECT -DARDUINO_ARCH_MBED_NANO -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\libraries\\Wire" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\libraries\\SPI" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\DHT_sensor_library" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\MQ135" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino/api/deprecated" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino/api/deprecated-avr-comp" "-iprefixC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino" "@C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT/includes.txt" "c:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library\\glcdfont.c" -o nul
"C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT/defines.txt" "@C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT/cxxflags.txt" -DARDUINO_ARCH_RP2040 -mcpu=cortex-m0plus -w -x c++ -E -CC -DARDUINO=10607 -DARDUINO_NANO_RP2040_CONNECT -DARDUINO_ARCH_MBED_NANO -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\libraries\\Wire" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\libraries\\SPI" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\DHT_sensor_library" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\MQ135" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino/api/deprecated" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino/api/deprecated-avr-comp" "-iprefixC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino" "@C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT/includes.txt" "c:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO\\Adafruit_BusIO_Register.cpp" -o nul
"C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT/defines.txt" "@C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT/cxxflags.txt" -DARDUINO_ARCH_RP2040 -mcpu=cortex-m0plus -w -x c++ -E -CC -DARDUINO=10607 -DARDUINO_NANO_RP2040_CONNECT -DARDUINO_ARCH_MBED_NANO -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\libraries\\Wire" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\libraries\\SPI" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\DHT_sensor_library" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\MQ135" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino/api/deprecated" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino/api/deprecated-avr-comp" "-iprefixC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino" "@C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT/includes.txt" "c:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO\\Adafruit_I2CDevice.cpp" -o nul
"C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT/defines.txt" "@C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT/cxxflags.txt" -DARDUINO_ARCH_RP2040 -mcpu=cortex-m0plus -w -x c++ -E -CC -DARDUINO=10607 -DARDUINO_NANO_RP2040_CONNECT -DARDUINO_ARCH_MBED_NANO -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\libraries\\Wire" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\libraries\\SPI" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\DHT_sensor_library" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\MQ135" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino/api/deprecated" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino/api/deprecated-avr-comp" "-iprefixC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino" "@C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT/includes.txt" "c:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO\\Adafruit_SPIDevice.cpp" -o nul
"C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT/defines.txt" "@C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT/cxxflags.txt" -DARDUINO_ARCH_RP2040 -mcpu=cortex-m0plus -w -x c++ -E -CC -DARDUINO=10607 -DARDUINO_NANO_RP2040_CONNECT -DARDUINO_ARCH_MBED_NANO -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\libraries\\Wire" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\libraries\\SPI" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\DHT_sensor_library" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\MQ135" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino/api/deprecated" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino/api/deprecated-avr-comp" "-iprefixC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino" "@C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT/includes.txt" "C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\libraries\\SPI\\SPI.cpp" -o nul
"C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT/defines.txt" "@C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT/cxxflags.txt" -DARDUINO_ARCH_RP2040 -mcpu=cortex-m0plus -w -x c++ -E -CC -DARDUINO=10607 -DARDUINO_NANO_RP2040_CONNECT -DARDUINO_ARCH_MBED_NANO -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\libraries\\Wire" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\libraries\\SPI" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\DHT_sensor_library" "-Ic:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\MQ135" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino/api/deprecated" "-IC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino/api/deprecated-avr-comp" "-iprefixC:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\cores\\arduino" "@C:\\Users\\alexi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\3.5.1\\variants\\NANO_RP2040_CONNECT/includes.txt" "c:\\Users\\alexi\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_SSD1306\\Adafruit_SSD1306.cpp" -o nul
Alternative pour pgmspace.h: []
ResolveLibrary(pgmspace.h)
-> candidates: []
Using my older 1.8.19 IDE, it is
#include <avr/pgmspace.h>
OK, I see there is a bug in the "Adafruit_SSD1306" library:
opened 09:31AM - 10 Jan 23 UTC
- Arduino board: Raspberry Pi Pico
- Arduino IDE version: 2.0.3
- Using Ardui… no Mbed OS RP2040 Boards (installed from Arduino's board manager) to program the Pico
The error I get when trying to compile the example file "ssd1306_128x64_12c" is the following:
Lines 39-42 of such cpp file looks like this:
#ifdef __AVR__
#elif defined(ESP8266) || defined(ESP32) || defined(ARDUINO_ARCH_RP2040)
If I modify line 42 like this:
then the sketch compiles and works as expected.
So it seems that the Pico uses the avr pgmspace, maybe this can be modified in the cpp file
Thanks!
(that report is from a user with a Pico board, but it also affects the Nano RP2040 Connect board, which is based on the same RP2040 microcontroller)
As markd833 explained, the #include
directory in the library should be for avr/pgmspace.h
I'll provide instructions you can follow to manually patch the bug in the library:
Open the file at this path in any text editor:c:\Users\alexi\OneDrive\Documents\Arduino\libraries\Adafruit_SSD1306\Adafruit_SSD1306.cpp
Change line 39 from this:#ifdef __AVR__
to this:#if defined(__AVR__) || defined(ARDUINO_ARCH_RP2040)
Save the file.
Now try compiling your sketch again. Hopefully this time the error will no longer occur.
A community member has already submitted a fix for the bug:
adafruit:master
← gabrielcsapo:master
opened 02:16AM - 31 Dec 22 UTC
Thank you for creating a pull request to contribute to Adafruit's GitHub code!
… Before you open the request please review the following guidelines and tips to
help it be more easily integrated:
- **Describe the scope of your change--i.e. what the change does and what parts
of the code were modified.** This will help us understand any risks of integrating
the code.
When utilizing this in a project with the RP2040, the following error occurs
- **Describe any known limitations with your change.** For example if the change
doesn't apply to a supported platform of the library please mention it.
None known.
- **Please run any tests or examples that can exercise your modified code.** We
strive to not break users of the code and running tests/examples helps with this
process.
Verified by running this locally on a rp2040. Examples on the esp32 still work as expected.
Thank you again for contributing! We will try to test and integrate the change
as soon as we can, but be aware we have many GitHub repositories to manage and
can't immediately respond to every request. There is no need to bump or check in
on a pull request (it will clutter the discussion of the request).
Also don't be worried if the request is closed or not integrated--sometimes the
priorities of Adafruit's GitHub code (education, ease of use) might not match the
priorities of the pull request. Don't fret, the open source community thrives on
forks and GitHub makes it easy to keep your changes in a forked repo.
After reviewing the guidelines above you can delete this text from the pull request.
So hopefully the next release of the "Adafruit_SSD1306" library will not have this problem.
That pull request makes a more proper fix than the one I provided in my instructions. My fix is slightly ugly from a code standpoint because I wanted to make it as simple as possible (replacing only a single line of code). But the two fixes are functionally identical so mine will work just fine for this use case of a provisional patch to your installed library.
Thanks for your help. It does work now.
Have a good day,
You are welcome. I'm glad it is working now.
Regards,
Per
Using board 'pico' from platform in folder: C:\Users\ceojblinks\AppData\Local\Arduino15\packages\arduino\hardware\mbed\3.3.0
Using core 'arduino' from platform in folder: C:\Users\ceojblinks\AppData\Local\Arduino15\packages\arduino\hardware\mbed\3.3.0
"C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\variants\\RASPBERRY_PI_PICO/defines.txt" "@C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\variants\\RASPBERRY_PI_PICO/cxxflags.txt" -DARDUINO_ARCH_RP2040 -mcpu=cortex-m0plus -w -x c++ -E -CC -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO -DARDUINO_ARCH_MBED -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\cores\\arduino" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\variants\\RASPBERRY_PI_PICO" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\cores\\arduino/api/deprecated-avr-comp" "-iprefixC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\cores\\arduino" "@C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\variants\\RASPBERRY_PI_PICO/includes.txt" "C:\\Users\\ceojblinks\\AppData\\Local\\Temp\\arduino\\sketches\\CA636B232A71D7F019DA17D2F6036D30\\sketch\\soil_meter10a.ino.cpp" -o nul
Alternatives for Wire.h: [Wire]
"C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\variants\\RASPBERRY_PI_PICO/defines.txt" "@C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\variants\\RASPBERRY_PI_PICO/cxxflags.txt" -DARDUINO_ARCH_RP2040 -mcpu=cortex-m0plus -w -x c++ -E -CC -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO -DARDUINO_ARCH_MBED -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\cores\\arduino" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\variants\\RASPBERRY_PI_PICO" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\libraries\\Wire" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\cores\\arduino/api/deprecated-avr-comp" "-iprefixC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\cores\\arduino" "@C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\variants\\RASPBERRY_PI_PICO/includes.txt" "C:\\Users\\ceojblinks\\AppData\\Local\\Temp\\arduino\\sketches\\CA636B232A71D7F019DA17D2F6036D30\\sketch\\soil_meter10a.ino.cpp" -o nul
Alternatives for Adafruit_GFX.h: [Adafruit GFX Library@1.11.5]
-> candidates: [Adafruit GFX Library@1.11.5]
"C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\variants\\RASPBERRY_PI_PICO/defines.txt" "@C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\variants\\RASPBERRY_PI_PICO/cxxflags.txt" -DARDUINO_ARCH_RP2040 -mcpu=cortex-m0plus -w -x c++ -E -CC -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO -DARDUINO_ARCH_MBED -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\cores\\arduino" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\variants\\RASPBERRY_PI_PICO" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\libraries\\Wire" "-IC:\\Users\\ceojblinks\\OneDrive\\Desktop\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\cores\\arduino/api/deprecated-avr-comp" "-iprefixC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\cores\\arduino" "@C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\variants\\RASPBERRY_PI_PICO/includes.txt" "C:\\Users\\ceojblinks\\AppData\\Local\\Temp\\arduino\\sketches\\CA636B232A71D7F019DA17D2F6036D30\\sketch\\soil_meter10a.ino.cpp" -o nul
Alternatives for Adafruit_I2CDevice.h: [Adafruit BusIO@1.14.1]
"C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\variants\\RASPBERRY_PI_PICO/defines.txt" "@C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\variants\\RASPBERRY_PI_PICO/cxxflags.txt" -DARDUINO_ARCH_RP2040 -mcpu=cortex-m0plus -w -x c++ -E -CC -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO -DARDUINO_ARCH_MBED -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\cores\\arduino" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\variants\\RASPBERRY_PI_PICO" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\libraries\\Wire" "-IC:\\Users\\ceojblinks\\OneDrive\\Desktop\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\ceojblinks\\OneDrive\\Desktop\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\cores\\arduino/api/deprecated-avr-comp" "-iprefixC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\cores\\arduino" "@C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\variants\\RASPBERRY_PI_PICO/includes.txt" "C:\\Users\\ceojblinks\\AppData\\Local\\Temp\\arduino\\sketches\\CA636B232A71D7F019DA17D2F6036D30\\sketch\\soil_meter10a.ino.cpp" -o nul
Alternatives for SPI.h: [SPI]
"C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\variants\\RASPBERRY_PI_PICO/defines.txt" "@C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\variants\\RASPBERRY_PI_PICO/cxxflags.txt" -DARDUINO_ARCH_RP2040 -mcpu=cortex-m0plus -w -x c++ -E -CC -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO -DARDUINO_ARCH_MBED -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\cores\\arduino" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\variants\\RASPBERRY_PI_PICO" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\libraries\\Wire" "-IC:\\Users\\ceojblinks\\OneDrive\\Desktop\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\ceojblinks\\OneDrive\\Desktop\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\libraries\\SPI" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\cores\\arduino/api/deprecated-avr-comp" "-iprefixC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\cores\\arduino" "@C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\variants\\RASPBERRY_PI_PICO/includes.txt" "C:\\Users\\ceojblinks\\AppData\\Local\\Temp\\arduino\\sketches\\CA636B232A71D7F019DA17D2F6036D30\\sketch\\soil_meter10a.ino.cpp" -o nul
Alternatives for Adafruit_SSD1306.h: [Adafruit SSD1306@2.5.6]
-> candidates: [Adafruit SSD1306@2.5.6]
"C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\variants\\RASPBERRY_PI_PICO/defines.txt" "@C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\variants\\RASPBERRY_PI_PICO/cxxflags.txt" -DARDUINO_ARCH_RP2040 -mcpu=cortex-m0plus -w -x c++ -E -CC -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO -DARDUINO_ARCH_MBED -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\cores\\arduino" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\variants\\RASPBERRY_PI_PICO" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\libraries\\Wire" "-IC:\\Users\\ceojblinks\\OneDrive\\Desktop\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\ceojblinks\\OneDrive\\Desktop\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\libraries\\SPI" "-IC:\\Users\\ceojblinks\\OneDrive\\Desktop\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\cores\\arduino/api/deprecated-avr-comp" "-iprefixC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\cores\\arduino" "@C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\variants\\RASPBERRY_PI_PICO/includes.txt" "C:\\Users\\ceojblinks\\AppData\\Local\\Temp\\arduino\\sketches\\CA636B232A71D7F019DA17D2F6036D30\\sketch\\soil_meter10a.ino.cpp" -o nul
"C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\variants\\RASPBERRY_PI_PICO/defines.txt" "@C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\variants\\RASPBERRY_PI_PICO/cxxflags.txt" -DARDUINO_ARCH_RP2040 -mcpu=cortex-m0plus -w -x c++ -E -CC -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO -DARDUINO_ARCH_MBED -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\cores\\arduino" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\variants\\RASPBERRY_PI_PICO" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\libraries\\Wire" "-IC:\\Users\\ceojblinks\\OneDrive\\Desktop\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\ceojblinks\\OneDrive\\Desktop\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\libraries\\SPI" "-IC:\\Users\\ceojblinks\\OneDrive\\Desktop\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\cores\\arduino/api/deprecated-avr-comp" "-iprefixC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\cores\\arduino" "@C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\variants\\RASPBERRY_PI_PICO/includes.txt" "C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\libraries\\Wire\\Wire.cpp" -o nul
"C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\variants\\RASPBERRY_PI_PICO/defines.txt" "@C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\variants\\RASPBERRY_PI_PICO/cxxflags.txt" -DARDUINO_ARCH_RP2040 -mcpu=cortex-m0plus -w -x c++ -E -CC -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO -DARDUINO_ARCH_MBED -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\cores\\arduino" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\variants\\RASPBERRY_PI_PICO" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\libraries\\Wire" "-IC:\\Users\\ceojblinks\\OneDrive\\Desktop\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\ceojblinks\\OneDrive\\Desktop\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\libraries\\SPI" "-IC:\\Users\\ceojblinks\\OneDrive\\Desktop\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\cores\\arduino/api/deprecated-avr-comp" "-iprefixC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\cores\\arduino" "@C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\variants\\RASPBERRY_PI_PICO/includes.txt" "C:\\Users\\ceojblinks\\OneDrive\\Desktop\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library\\Adafruit_GFX.cpp" -o nul
"C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\variants\\RASPBERRY_PI_PICO/defines.txt" "@C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\variants\\RASPBERRY_PI_PICO/cxxflags.txt" -DARDUINO_ARCH_RP2040 -mcpu=cortex-m0plus -w -x c++ -E -CC -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO -DARDUINO_ARCH_MBED -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\cores\\arduino" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\variants\\RASPBERRY_PI_PICO" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\libraries\\Wire" "-IC:\\Users\\ceojblinks\\OneDrive\\Desktop\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\ceojblinks\\OneDrive\\Desktop\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\libraries\\SPI" "-IC:\\Users\\ceojblinks\\OneDrive\\Desktop\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\cores\\arduino/api/deprecated-avr-comp" "-iprefixC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\cores\\arduino" "@C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\variants\\RASPBERRY_PI_PICO/includes.txt" "C:\\Users\\ceojblinks\\OneDrive\\Desktop\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library\\Adafruit_GrayOLED.cpp" -o nul
"C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\variants\\RASPBERRY_PI_PICO/defines.txt" "@C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\variants\\RASPBERRY_PI_PICO/cxxflags.txt" -DARDUINO_ARCH_RP2040 -mcpu=cortex-m0plus -w -x c++ -E -CC -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO -DARDUINO_ARCH_MBED -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\cores\\arduino" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\variants\\RASPBERRY_PI_PICO" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\libraries\\Wire" "-IC:\\Users\\ceojblinks\\OneDrive\\Desktop\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\ceojblinks\\OneDrive\\Desktop\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\libraries\\SPI" "-IC:\\Users\\ceojblinks\\OneDrive\\Desktop\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\cores\\arduino/api/deprecated-avr-comp" "-iprefixC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\cores\\arduino" "@C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\variants\\RASPBERRY_PI_PICO/includes.txt" "C:\\Users\\ceojblinks\\OneDrive\\Desktop\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library\\Adafruit_SPITFT.cpp" -o nul
"C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\variants\\RASPBERRY_PI_PICO/defines.txt" "@C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\variants\\RASPBERRY_PI_PICO/cxxflags.txt" -DARDUINO_ARCH_RP2040 -mcpu=cortex-m0plus -w -x c++ -E -CC -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO -DARDUINO_ARCH_MBED -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\cores\\arduino" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\variants\\RASPBERRY_PI_PICO" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\libraries\\Wire" "-IC:\\Users\\ceojblinks\\OneDrive\\Desktop\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\ceojblinks\\OneDrive\\Desktop\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\libraries\\SPI" "-IC:\\Users\\ceojblinks\\OneDrive\\Desktop\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\cores\\arduino/api/deprecated-avr-comp" "-iprefixC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\cores\\arduino" "@C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\variants\\RASPBERRY_PI_PICO/includes.txt" "C:\\Users\\ceojblinks\\OneDrive\\Desktop\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library\\glcdfont.c" -o nul
"C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\variants\\RASPBERRY_PI_PICO/defines.txt" "@C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\variants\\RASPBERRY_PI_PICO/cxxflags.txt" -DARDUINO_ARCH_RP2040 -mcpu=cortex-m0plus -w -x c++ -E -CC -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO -DARDUINO_ARCH_MBED -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\cores\\arduino" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\variants\\RASPBERRY_PI_PICO" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\libraries\\Wire" "-IC:\\Users\\ceojblinks\\OneDrive\\Desktop\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\ceojblinks\\OneDrive\\Desktop\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\libraries\\SPI" "-IC:\\Users\\ceojblinks\\OneDrive\\Desktop\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\cores\\arduino/api/deprecated-avr-comp" "-iprefixC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\cores\\arduino" "@C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\variants\\RASPBERRY_PI_PICO/includes.txt" "C:\\Users\\ceojblinks\\OneDrive\\Desktop\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO\\Adafruit_BusIO_Register.cpp" -o nul
"C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\variants\\RASPBERRY_PI_PICO/defines.txt" "@C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\variants\\RASPBERRY_PI_PICO/cxxflags.txt" -DARDUINO_ARCH_RP2040 -mcpu=cortex-m0plus -w -x c++ -E -CC -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO -DARDUINO_ARCH_MBED -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\cores\\arduino" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\variants\\RASPBERRY_PI_PICO" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\libraries\\Wire" "-IC:\\Users\\ceojblinks\\OneDrive\\Desktop\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\ceojblinks\\OneDrive\\Desktop\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\libraries\\SPI" "-IC:\\Users\\ceojblinks\\OneDrive\\Desktop\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\cores\\arduino/api/deprecated-avr-comp" "-iprefixC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\cores\\arduino" "@C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\variants\\RASPBERRY_PI_PICO/includes.txt" "C:\\Users\\ceojblinks\\OneDrive\\Desktop\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO\\Adafruit_I2CDevice.cpp" -o nul
"C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\variants\\RASPBERRY_PI_PICO/defines.txt" "@C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\variants\\RASPBERRY_PI_PICO/cxxflags.txt" -DARDUINO_ARCH_RP2040 -mcpu=cortex-m0plus -w -x c++ -E -CC -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO -DARDUINO_ARCH_MBED -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\cores\\arduino" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\variants\\RASPBERRY_PI_PICO" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\libraries\\Wire" "-IC:\\Users\\ceojblinks\\OneDrive\\Desktop\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\ceojblinks\\OneDrive\\Desktop\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\libraries\\SPI" "-IC:\\Users\\ceojblinks\\OneDrive\\Desktop\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\cores\\arduino/api/deprecated-avr-comp" "-iprefixC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\cores\\arduino" "@C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\variants\\RASPBERRY_PI_PICO/includes.txt" "C:\\Users\\ceojblinks\\OneDrive\\Desktop\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO\\Adafruit_SPIDevice.cpp" -o nul
"C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\variants\\RASPBERRY_PI_PICO/defines.txt" "@C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\variants\\RASPBERRY_PI_PICO/cxxflags.txt" -DARDUINO_ARCH_RP2040 -mcpu=cortex-m0plus -w -x c++ -E -CC -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO -DARDUINO_ARCH_MBED -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\cores\\arduino" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\variants\\RASPBERRY_PI_PICO" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\libraries\\Wire" "-IC:\\Users\\ceojblinks\\OneDrive\\Desktop\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\ceojblinks\\OneDrive\\Desktop\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\libraries\\SPI" "-IC:\\Users\\ceojblinks\\OneDrive\\Desktop\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\cores\\arduino/api/deprecated-avr-comp" "-iprefixC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\cores\\arduino" "@C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\variants\\RASPBERRY_PI_PICO/includes.txt" "C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\libraries\\SPI\\SPI.cpp" -o nul
"C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -w -g3 -nostdlib "@C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\variants\\RASPBERRY_PI_PICO/defines.txt" "@C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\variants\\RASPBERRY_PI_PICO/cxxflags.txt" -DARDUINO_ARCH_RP2040 -mcpu=cortex-m0plus -w -x c++ -E -CC -DARDUINO=10607 -DARDUINO_RASPBERRY_PI_PICO -DARDUINO_ARCH_MBED -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\cores\\arduino" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\variants\\RASPBERRY_PI_PICO" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\libraries\\Wire" "-IC:\\Users\\ceojblinks\\OneDrive\\Desktop\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\ceojblinks\\OneDrive\\Desktop\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\libraries\\SPI" "-IC:\\Users\\ceojblinks\\OneDrive\\Desktop\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\cores\\arduino/api/deprecated-avr-comp" "-iprefixC:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\cores\\arduino" "@C:\\Users\\ceojblinks\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\variants\\RASPBERRY_PI_PICO/includes.txt" "C:\\Users\\ceojblinks\\OneDrive\\Desktop\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_SSD1306\\Adafruit_SSD1306.cpp" -o nul
Alternatives for pgmspace.h: []
-> candidates: []
C:\Users\ceojblinks\OneDrive\Desktop\OneDrive\Documents\Arduino\libraries\Adafruit_SSD1306\Adafruit_SSD1306.cpp:42:10: fatal error: pgmspace.h: No such file or directory
#include <pgmspace.h>
compilation terminated.
Using library Wire in folder: C:\Users\ceojblinks\AppData\Local\Arduino15\packages\arduino\hardware\mbed\3.3.0\libraries\Wire (legacy)
Using library Adafruit GFX Library at version 1.11.5 in folder: C:\Users\ceojblinks\OneDrive\Desktop\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library
Using library Adafruit BusIO at version 1.14.1 in folder: C:\Users\ceojblinks\OneDrive\Desktop\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO
Using library SPI in folder: C:\Users\ceojblinks\AppData\Local\Arduino15\packages\arduino\hardware\mbed\3.3.0\libraries\SPI (legacy)
Using library Adafruit SSD1306 at version 2.5.6 in folder: C:\Users\ceojblinks\OneDrive\Desktop\OneDrive\Documents\Arduino\libraries\Adafruit_SSD1306
exit status 1
Compilation error: exit status 1
system
Closed
September 7, 2023, 10:22pm
13
