Library problem
I have a project on Arduino but I am stuck with a library issue.
My board is Galileo Gen2, I need to add an external library in order to make the board read and understand a servo.
But each time after I add the zip library or install it manually, the #Include ... stays black and doesn't read the functions of the library.
I tried everything possible (i.e. check the path, restart, manual installation, add zip library...)
Could anyone please help me figure this out?
Thank you
MelissaG:
It should be #include not #Include
pert:
In the code it is #include not #Include
Can you give me any other remark to help me fix the problem?
Thank you very much
What PC operating system are you using ?
What version of the Arduino IDE ?
What is the name of the library ?
Post a link to the place where you got the library.
What is the full pathname of the xxx.h file that you are trying to refer to with #include
...R
Hello,
I simply uninstalled the Arduino IDE 1.6.5 and installed 1.6.0 and it worked.
The library was perfectly accessed and the servo turned.
I have a question irrelevant to this issue, but, do you think that the dfrobot 2A motor shield is compatible with Galileo Gen2?
Thank you,
Melissa
MelissaG:
I'm still using 1.5.6
You can have several versions on the same PC.
The Arduino folks don't seem to do backwards compatibilty.
I know nothing about Galileo.
...R
MelissaG:
Hello,
Thank you,
Melissa
Where the libraries folder is for any particular IDE version can be different.
All of mine are, I did not uninstall any version IDE when I added another, I had to copy libraries or not.
But the Sketchbook.... they all share that.
Do you think that the dfrobot motor shield L298P is compatible with Galileo Gen2?
