Library Question
This is quite a simple problem. I am trying to load my servo library, but keep getting this error
In file included from C:\Users\user\Desktop\ARC lab\arduino-0013\hardware\cores\arduino/WProgram.h:4,
c:/users/user/desktop/arc lab/arduino-0013/hardware/tools/avr/lib/gcc/…/…/avr/include/stdlib.h:111: error: expected unqualified-id before ‘int’
c:/users/user/desktop/arc lab/arduino-0013/hardware/tools/avr/lib/gcc/…/…/avr/include/stdlib.h:111: error: expected `)’ before ‘int’
In file included from C:\Users\user\Desktop\ARC lab\arduino-0013\hardware\cores\arduino/WProgram.h:6,
This happens when I run the included example, looking like this
// Sweep
// by BARRAGAN <>
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
                // a maximum of eight servo objects can be created
int pos = 0;    // variable to store the servo position
  myservo.attach(9);  // attaches the servo on pin 9 to the servo object
  for(pos = 0; pos < 180; pos += 1)  // goes from 0 degrees to 180 degrees
  {                                  // in steps of 1 degree
    myservo.write(pos);              // tell servo to go to position in variable 'pos'
    delay(15);                       // waits 15ms for the servo to reach the position
  for(pos = 180; pos>=1; pos-=1)     // goes from 180 degrees to 0 degrees
When I try to run the included example involving a stepper motor I get no problems, the example stepper program is this
 * MotorKnob
 * A stepper motor follows the turns of a potentiometer
 * (or other sensor) on analog input 0.
#include <Stepper.h>
// change this to the number of steps on your motor
#define STEPS 100
// create an instance of the stepper class, specifying
// the number of steps of the motor and the pins it's
// attached to
Stepper stepper(STEPS, 8, 9, 10, 11);
// the previous reading from the analog input
int previous = 0;
  // set the speed of the motor to 30 RPMs
  stepper.setSpeed(30);
  // get the sensor value
  int val = analogRead(0);
  // move a number of steps equal to the change in the
  // sensor reading
  stepper.step(val - previous);
  // remember the previous value of the sensor
  previous = val;
So i can call the stepper library, so maybe my servo library is no good? Any feedbck would be appreciated
Are you on a Mega? If so, get MegaServo. They've remapped some pins since, this solved some problems for me.
I am using a Duemilanove, with an Atmega328 on board. I tried to use the MegaServo and it fixed my problems! Thank you very much
