library shield wifi FT1076M
Hello!
I have problem with FT1076M wi-fi shield becouse the library doesn't work :frowning:
I have downloaded it and than i have added it to my Arduino IDE and it was all ok.
Now when i can try to compile example i have some errors and i don't understand what it is wrong becouse i haven't modified nothing in the example code.
The errors
Arduino:1.6.7 (Windows 10), Scheda:"Arduino/Genuino Uno"
In file included from C:\Users\FEDERI~1\AppData\Local\Temp\arduino_2861ee5f3d8758ee656c8fbdb630fb07\HTTPClient.ino:1:0:
C:\Users\Federico Coppola\Documents\Arduino\libraries\MWiFI/MWiFi.h:268:37: error: 'prog_char' has not been declared
     uint16_t writeDataPM(uint8_t sk,prog_char *buffer,uint16_t lbuff);
C:\Users\Federico Coppola\Documents\Arduino\libraries\MWiFI/MWiFi.h:269:38: error: 'prog_char' has not been declared
     uint16_t writeDataPM(uint8_t sk, prog_char *buffer);
C:\Users\Federico Coppola\Documents\Arduino\libraries\MWiFI/MWiFi.h:270:40: error: 'prog_char' has not been declared
     uint16_t writeDataLnPM(uint8_t sk, prog_char *buffer);
C:\Users\Federico Coppola\Documents\Arduino\libraries\MWiFI/MWiFi.h:502:41: error: 'prog_char' has not been declared
     uint16_t sendFromProgMem(uint8_t sk,prog_char *pgbuffer,uint16_t lbuff,uint8_t ln);
In file included from C:\Users\Federico Coppola\Documents\Arduino\libraries\MWiFI/HTTPlib.h:116:0,
                 from C:\Users\FEDERI~1\AppData\Local\Temp\arduino_2861ee5f3d8758ee656c8fbdb630fb07\HTTPClient.ino:20:
C:\Users\Federico Coppola\Documents\Arduino\libraries\MWiFI/utility/BASE64.h:28:17: error: 'prog_char' has not been declared
      int search(prog_char* pstring,char c);
In file included from C:\Users\FEDERI~1\AppData\Local\Temp\arduino_2861ee5f3d8758ee656c8fbdb630fb07\HTTPClient.ino:20:0:
C:\Users\Federico Coppola\Documents\Arduino\libraries\MWiFI/HTTPlib.h:161:31: error: 'prog_char' has not been declared
  void sendResponse(int socket,prog_char *page);
C:\Users\Federico Coppola\Documents\Arduino\libraries\MWiFI/HTTPlib.h:169:30: error: 'prog_char' has not been declared
  void sendDynResponse(int sk,prog_char *page,int npar,char *param[]);
C:\Users\Federico Coppola\Documents\Arduino\libraries\MWiFI/HTTPlib.h:324:32: error: 'prog_char' has not been declared
  void sendChunkResponse(int sk,prog_char data[],int ldata,char* param);
C:\Users\Federico Coppola\Documents\Arduino\libraries\MWiFI/HTTPlib.h:326:32: error: 'prog_char' has not been declared
  char* checkHeader(char *buff, prog_char *header);
C:\Users\FEDERI~1\AppData\Local\Temp\arduino_2861ee5f3d8758ee656c8fbdb630fb07\HTTPClient.ino: In function 'void setup()':
C:\Users\FEDERI~1\AppData\Local\Temp\arduino_2861ee5f3d8758ee656c8fbdb630fb07\HTTPClient.ino:53:34: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
   WIFI.setNetMask("255.255.255.0");  //modify default
C:\Users\FEDERI~1\AppData\Local\Temp\arduino_2861ee5f3d8758ee656c8fbdb630fb07\HTTPClient.ino:54:28: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
   WIFI.setGateway("0.0.0.0");        //modify default
C:\Users\FEDERI~1\AppData\Local\Temp\arduino_2861ee5f3d8758ee656c8fbdb630fb07\HTTPClient.ino:56:49: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
   if (PASSWORD==""){WIFI.ConnSetOpen(ACCESSPOINT);}         // if passw= empty string connect in open mode
C:\Users\FEDERI~1\AppData\Local\Temp\arduino_2861ee5f3d8758ee656c8fbdb630fb07\HTTPClient.ino:57:57: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
   else             {WIFI.ConnSetWPA(ACCESSPOINT,PASSWORD);} // else connect in WAP mode
C:\Users\FEDERI~1\AppData\Local\Temp\arduino_2861ee5f3d8758ee656c8fbdb630fb07\HTTPClient.ino: In function 'void socketConnection()':
C:\Users\FEDERI~1\AppData\Local\Temp\arduino_2861ee5f3d8758ee656c8fbdb630fb07\HTTPClient.ino:77:43: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
     csocket=WIFI.openSockTCP(REMOTEIP,PORT);                             // try to connect to remote ip
C:\Users\FEDERI~1\AppData\Local\Temp\arduino_2861ee5f3d8758ee656c8fbdb630fb07\HTTPClient.ino: In function 'void loop()':
C:\Users\FEDERI~1\AppData\Local\Temp\arduino_2861ee5f3d8758ee656c8fbdb630fb07\HTTPClient.ino:97:67: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
     WIFI.addParameter(query,128,"/TestWIFIArduino/TestClient",NULL);
C:\Users\FEDERI~1\AppData\Local\Temp\arduino_2861ee5f3d8758ee656c8fbdb630fb07\HTTPClient.ino:98:41: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
     WIFI.addParameter(query,128,"A1",sa1);
C:\Users\FEDERI~1\AppData\Local\Temp\arduino_2861ee5f3d8758ee656c8fbdb630fb07\HTTPClient.ino:99:41: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
     WIFI.addParameter(query,128,"A2",sa2);
C:\Users\FEDERI~1\AppData\Local\Temp\arduino_2861ee5f3d8758ee656c8fbdb630fb07\HTTPClient.ino:100:41: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
     WIFI.addParameter(query,128,"D1",sd1);
C:\Users\FEDERI~1\AppData\Local\Temp\arduino_2861ee5f3d8758ee656c8fbdb630fb07\HTTPClient.ino:101:41: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
     WIFI.addParameter(query,128,"D2",sd2);
exit status 1
Errore durante la compilazione
  Questo report potrebbe essere più ricco di informazioni con
  "Mostra un output dettagliato durante la compilazione"
  abilitato in "File > Impostazioni"
This it the library: Release New version with progmem correction · open-electronics/MWiFi · GitHub
The example is: HTTPclient
Thanks! :slight_smile:
Tested on IDE 1.6.5. For IDE => 1.6.6 new version is coming.
What version of the IDE are you using?
