Hello,
I tried to use the StackString-Library arduino-libraries / StackString · GitLab
I installed the library with the built-in library-manager and it is listed under sketch include library.
As long as I just add the include-command
#include <StackString.hpp>
to my testcode the code compiles
As soon as I try to create a first string like in the example
StackString<100> myString = StackString<100>("Hello, World!");
The compiler complaints
"'StackString' does not name a type; did you mean 'StackString_h'?"
Does anybody have a compiling code-example or any idea what causes the compiler-error?
best regards
Stefan
Hi spycatcher2k,
I raised an issue on gitlab and the author did already reply to it.
the original source had not Demo *.ino-file at all.
in the meantime I was able to get it to compile and I created a Demo-example that shows the use of each command
using namespace Stack; // it is very important to have this line of code. Otherwise the code won't compile
StackString<50> myString = StackString<50>("Hello, World!");
Serial.println(myString.c_str());
myString.prepend("Everybody say: ");
myString.append(" How are you doing?");
StackString<100> myString1 = StackString<100>("http://arjenstens.com");
Serial.println( "012345678901234567890");
Serial.println( "| | | ");
Serial.println( myString1.c_str() );
Serial.print("first occurence of letter 's' is position ");
Serial.println( myString1.find("s") );
Serial.print("second occurence of letter 's' is position ");
Serial.println( myString1.find("s", 2) );
//0123456789012345
StackString<64> MyIniStr = StackString<64>("123456789=abcde");
StackString<64> MyIniIdentifier = StackString<64>("");
StackString<64> MyIniValueStr = StackString<64>("");
Serial.println("0123456789012345");
Serial.println("| | |");
Serial.println("123456789=abcde");
int PosOfEqualSign = MyIniStr.find("=");
Serial.print("PosOfEqualSign:");
Serial.println(PosOfEqualSign);
int Len = MyIniStr.length();
Serial.print("Len:");
Serial.println(Len);
MyIniIdentifier = MyIniStr.substring(0,PosOfEqualSign);
//MyIniIdentifier = MyIniStr.substring(0,9);
Serial.print("MyIniIdentifier =#");
Serial.print(MyIniIdentifier.c_str());
Serial.println("#");
MyIniValueStr = MyIniStr.substring(PosOfEqualSign + 1, (Len - PosOfEqualSign - 1));
Serial.print("MyIniValueStr =#");
Serial.print(MyIniValueStr.c_str());
StackString<10> myNumberAsString = StackString<10>("1133");
int MyNumberAsInteger = myNumberAsString.toInt() * 2;
Serial.print("myNumberAsString =#");
Serial.print(myNumberAsString.c_str());
Serial.print("MyNumberAsInteger = myNumberAsString.toInt() * 2=");
Serial.println(MyNumberAsInteger);
Serial.print("does the string above start with 'https'? ");
if (!myString1.startsWith ("https"))
Serial.println("no !");
Serial.print("does the string above start with 'http'? ");
if (myString1.startsWith ("http"))
Serial.println("YES !");
{ // put your main code here, to run repeatedly:
The output in the COM-Window should look like this
Hello, World!
Everybody say: Hello, World!
Everybody say: Hello, World! How are you doing?
first occurence of letter 's' is position 12
second occurence of letter 's' is position 16
0123456789012345
123456789=abcde
PosOfEqualSign:9
Len:15
MyIniIdentifier =#123456789#
MyIniValueStr =#abcde#
myNumberAsString =#1133#
MyNumberAsInteger = myNumberAsString.toInt() * 2=2266
does the string above start with 'https'? no !
does the string above start with 'http'? YES !
best regards
Stefan
