Library TFT_eSPI. Assign color to each pixel. ESP32-2432S028R
Good morning,
I purchased a ESP32-2432S028R which has an ESP32-wroom_32, 2.8" display with ILI9341 driver.
I would like to see on the screen the color of each pixel that I receive in OSC.
I send the 3 data R, G, B at 254*128 pixels.
What is the correct function to use from the TFT_eSPI library?
Here the program I made but I can only see a white mouvement on the screen.
 #include <OSCBoards.h>
#include <OSCBundle.h>
#include <OSCData.h>
#include <OSCMatch.h>
#include <OSCMessage.h>
#include <OSCTiming.h>
#include <SLIPEncodedSerial.h>
  Open Sound Control (OSC) library for the ESP8266/ESP32
  Example for receiving open sound control (OSC) messages on the ESP8266/ESP32
  Send integers '0' or '1' to the address "/led" to turn on/off the built-in LED of the esp8266.
  This example code is in the public domain.
#include <WiFi.h>
#include <WiFiUdp.h>
#include <WiFiMulti.h>
WiFiMulti wifiMulti;
#include <TFT_eSPI.h>
TFT_eSPI tft = TFT_eSPI();
#define	BLACK 0x0000
#define WHITE 0xFFFF
WiFiUDP Udp;
const unsigned int outPort = 9999;    // remote port (not needed for receive)
const unsigned int localPort = 8004;  // local port to listen for UDP packets (here's where we send the packets)
OSCErrorCode error;
unsigned int ledState = LOW;  // LOW means led is *on*. not use
//------------ END  ESP and OSC setting
#define LED_BUILTIN 16
#define BUILTIN_LED LED_BUILTIN
int numberOfPIXELS = 254*128;
#define numberOfpixels numberOfPIXELS// 64
int size;
  //tft.init();
  //tft.fillScreen(TFT_BLACK); // Background is black
   pinMode(BUILTIN_LED, OUTPUT);
   digitalWrite(BUILTIN_LED, ledState);  // turn *on* led
   delay(10);
    // Connect to the best WiFi network
    wifiMulti.addAP("SFR_A080_EXT", "rtws8bze84czbb5aat33"); // Loic
    wifiMulti.addAP("E5576_BD52_EXT", "564d76L4Mbm"); // miniBox
    Serial.println("Connecting Wifi...");
    if(wifiMulti.run() == WL_CONNECTED)
        Serial.println("");
        Serial.println("WiFi connected");
        Serial.println("IP address: ");
   IPAddress local_IP(192, 168, 8, 104);// 145
    // Set your Gateway IP address
   IPAddress gateway(192, 168, 1, 1);
   IPAddress subnet(255, 255, 0, 0);
    WiFi.mode(WIFI_STA);
  if (WiFi.config(local_IP, gateway, subnet) == false) {
    Serial.print("echec de config");
  ////  digitalWrite(BUILTIN_LED, HIGH);  // turn *on* led
     digitalWrite(BUILTIN_LED, LOW);  // turn *on* led
    Serial.print(".");
  Serial.println("Starting UDP");
  Udp.begin(localPort);
  Serial.print("Local port: ");
#ifdef ESP32
  Serial.print("LocalportESP32: ");
  Serial.println(localPort);
#else
  Serial.println(Udp.localPort());
#endif
  //  turn off led when connected to a wifi network
  digitalWrite(BUILTIN_LED, HIGH);  // turn off* led
    OSCMessage msg;
    size = Udp.parsePacket();
    if (size > 0) {
    while (size--) {
      msg.fill(Udp.read());
    if (!msg.hasError()) {
      msg.dispatch("/matrixdata",assignDataParsed); //
    else {
      error = msg.getError();
      Serial.print("error: ");
      Serial.println(error);
void assignDataParsed(OSCMessage &msg) {
  for (uint8_t i = 0; i < numberOfpixels; i++) {
    tft.drawPixel(msg.getInt(i*3+0), i, WHITE);
Hi @bvking
On the french speaking forum, please speak in french, or ask moderators to move your topic to the root of arduino forum, thanks.
Pandaroux007
T'inquiètes pas @bvking parle parfaitement le français, tout simplement il ne sait plus sur quel forum il se trouve.
Voici le prototype, qui explique comment utiliser cette fonction :
// Draw a pixel blended with the background pixel colour (bg_color) specified,  return blended colour
// If the bg_color is not specified, the background pixel colour will be read from TFT or sprite
uint16_t drawPixel(int32_t x, int32_t y, uint32_t color, uint8_t alpha, uint32_t bg_color = 0x00FFFFFF);
Merci beaucoup lesept.
Dans mon cas, j'ai 3 données par couleur.
Comment je peux transformer mes 3 données r, g ,b (3 int de 0 à 255) pour l'assigner à
uint32_t color. ?
Apparemment il faut que la donnée averagecouleur soit en hexadécimal?
J'ai crée une variable qui est la moyenne des trois valeurs r, g , b.
Maintenant comment convertir une int de 0 à 255 en hexadecimal?
j'ai essayé le programme ci dessous pour un écran de 50*10 pixels, mais évidemment c'est pas aussi simple.
  for (uint8_t i = 0; i < (50); i++) {
     for (uint8_t j = 0; j < (10); j++) {
        averageColor=int ((msg.getInt(j*3+0)+msg.getInt(j*3+1)+msg.getInt(j*3+2))/3);
        Serial.print((i)),Serial.print ( " " ), Serial.print((j)); Serial.print ( " " ); Serial.println ( averageColor);
         tft.drawEllipse((i*10)+200, (j*10)+200, 10, 10,  averageColor); //
         tft.drawPixel(i+150, j+150, averageColor, WHITE, BLACK);
En fait il n'est pas nécessaire de travailler en hexadécimal, l'important c'est que ça soit un uint32_t donc un entier non signé de 32 bits. Le microcontrôleur travaille en binaire, l'hexadécimal est uniquement là pour la facilité de l'utilisateur.
Donc tu as 3 valeurs en uint8_t pour r, g et b. Pour obtenir la couleur, tu peux faire :
uint32_t couleur = r << 16 + g << 8 + b;
J'ai vu qu'il existe une fonction drawPixel plus simple d'utilisation :
drawPixel(int32_t x, int32_t y, uint32_t color)
Il y a, dans la librairie, des fonctions pour passer d'un format de couleurs dans un autre.
  // Colour conversion
           // Convert 8-bit red, green and blue to 16 bits
  uint16_t color565(uint8_t red, uint8_t green, uint8_t blue);
           // Convert 8-bit colour to 16 bits
  uint16_t color8to16(uint8_t color332);
           // Convert 16-bit colour to 8 bits
  uint8_t  color16to8(uint16_t color565);
           // Convert 16-bit colour to/from 24-bit, R+G+B concatenated into LS 24 bits
  uint32_t color16to24(uint16_t color565);
  uint32_t color24to16(uint32_t color888);
Merci pour l'aide.
Mais tous compte fait je pense que je dois faire cette conversion depuis max/msp pour gagner de la ram dans l'arduino.
En fait l'écran fait 240*320. Je me demande comment je peux recevoir de manière optimale 76800 données !!?
Je peux envoyer que 1500 données depuis max/msp. Alors je devrais découper mon image en 52 case car 240*320/1500 = 51.7. Je dois trouver un meilleur moyen d'envoyer des infos depuis max/msp et un meilleur moyen d'assigner chaque pixel avec l'Arduino.
Mais faute de mieux, j'ai programmé l'arduino de manière à ce qu'elle reçoive 1500 donnés à chaque loop successive afin de pouvoir contrôler un écran de 3000 pixels, soit 50*60 pixels.
Pourriez vous me dire si je suis sur la bonne voie?
#include <WiFi.h>
WiFiUDP Udp;
OSCErrorCode error;
//int numberOfPIXELS = 254*128;
int numberOfPIXELS = 64;
int size;
int averageColor;
int frame, modFrame;
  frame=0;
  tft.init();
 // averageColor=int ((msg.getInt(i*3+0)+msg.getInt(i*3+1)+msg.getInt(i*3+2))/3);
   delay(10);
    wifiMulti.addAP("SFR-d078", "XXXXXXX"); // sandra
    wifiMulti.addAP("SFR_A080_EXT", "XXXXXXX"); // Loic
    wifiMulti.addAP("E5576_BD52_EXT", "XXXXXXX"); // miniBox
        Serial.println("");
    Serial.print(".");
#ifdef ESP32
#else
#endif
    OSCMessage msg;
    if (size > 0) {
    while (size--) {
      msg.dispatch("/matrixdata1",assignDataParsed1)
    else {
  for (uint8_t i = 0; i < (50/1); i++) {
     for (uint8_t j = 0; j < (30/2); j++) {
     int r= msg.getInt(j*3+0);
     int g= msg.getInt(j*3+1);
     int b= msg.getInt(j*3+2);
     Serial.print ( " " ); Serial.println ( couleur);
     averageColor = r << 16 + g << 8 + b;
         tft.drawPixel(i, j,  averageColor);
void assignDataParsed1(OSCMessage &msg) {
         tft.drawPixel(i, j+15,  averageColor);
