Library to install shown this message
Failed to install library: 'AlPlc_PMC:1.0.6'. 13 INTERNAL: Library install failed: creating temp dir for extraction: mkdir c:\Users\HP\OneDrive\Documents\Arduino\libraries\package-3298413698: The system cannot find the file specified.
There may be a problem with permissions or a full disk.
not full my hard disk empty is 200 gb
But OneDrive in the cloud might be full if you use that.
Which version of the IDE are you using; I think it's 2.x.
yes
Topic moved to IDE 2.x section of the forum.
Those numbered libraries again - #2 by ptillisch contains a description of what should happen. It was for IDE 1.x and looking at the error that you get I think that the process is similar.
Your problem is that it the IDE can't create the temporary directory and you will have to sort that out.
Can you install other libraries? I have just installed AlPlc_PMC (version1.0.6) successfully in IDE 2.3.3.
create the temporary directory folder to solve a problem
Can you answer the question if you can install other libraries?
Is that the solution or a question?
