library to test/use FRAM i2c ?
I found a header file to test a i2c eeprom 24LC256 , but I used this to test my eeprom CAT24C32.The test sketch works fine.
I have also a FRAM MB85RC256V, I am wondering if can i use the same header to test the FRAM. I saw the command byte write are same like eeprom, but the page write have a different side of buffer, it says have 32Kbytes ...
If I made a mistake please help me. Thanks very much!
here the .h
#ifndef  EEPROM_ROUTINES
#define  EEPROM_ROUTINES
#if defined(ARDUINO) && ARDUINO >= 100
  #include "Arduino.h"
#else
  #include "WProgram.h"
#endif
#include <Wire.h>
#define BLOCKSIZE 8
#define I2CADDR 0x57
#define BLOCKSIZE_READ 30
template <class T>
uint16_t writeObjectSimple(uint8_t i2cAddr, uint16_t addr, const T& value){
      const uint8_t* p = (const uint8_t*)(const void*)&value;
      uint16_t i;
      for (i = 0; i < sizeof(value); i++){
            Wire.beginTransmission(i2cAddr);
                  Wire.write((uint16_t)(addr >> 8));  // MSB
                  Wire.write((uint16_t)(addr & 0xFF));// LSB
                  Wire.write(*p++);
            Wire.endTransmission();
            addr++;
            delay(5);  //max time for writing in 24LC256
      return i;
template <class T>
uint16_t readObjectSimple(uint8_t i2cAddr, uint16_t addr, T& value){
            uint8_t* p = (uint8_t*)(void*)&value;
            uint8_t objSize = sizeof(value);
            uint16_t i;
            for (i = 0; i < objSize; i++){
                  Wire.beginTransmission (i2cAddr);
                  Wire.requestFrom(i2cAddr, (uint8_t)1);
                  if(Wire.available()){
                        *p++ = Wire.read();
                  addr++;
            return i;
template <class T>
uint16_t writeObject(uint16_t addr, const T& value){
      Wire.beginTransmission(I2CADDR);
      Wire.write((uint16_t)(addr & 0xFF));      // LSB
      //in the loop: counts the bytes we may send before
      //our block becomes full
      //but initialise it to the number of bytes up to the
      //next 16-byte aligned address
      uint8_t blockBytes = (addr/BLOCKSIZE + 1)*BLOCKSIZE - addr;
      uint16_t i;
            if (blockBytes == 0){
                  //block is full;
                  Wire.endTransmission(); //dispatch the buffer
                  delay(5);
                  //restart new block
                  addr = (addr/BLOCKSIZE + 1)*BLOCKSIZE;
                  blockBytes = BLOCKSIZE;
            Wire.write(*p++); //dispatch the data byte
            blockBytes--;     //decrement the block space
      delay(5);   //required write delay 5ms
      return i;
template <class T>
uint16_t readObject(uint16_t addr, T& value){
      //counts the bytes we may read before buffer is depleted
      uint8_t   blockBytes = 0;
      uint16_t  objSize = sizeof(value);
      uint16_t  i;
            if (blockBytes==0){
               //we need a new block
               blockBytes = BLOCKSIZE_READ;
               if (objSize < blockBytes) blockBytes = objSize;
               //get the new block
                Wire.requestFrom((uint8_t)I2CADDR, blockBytes);
                  //read a byte from buffer
                  *p++ = Wire.read();
                  blockBytes--;
      return i;
#endif
here the sketch to test
#include <Wire.h>
#include "eeprom_routines.h" //definitions of the functions:
                             //writeObject, readObject,
                             //writeObjectSimple, readObjectSimple
#define BLOCK_OPERATIONS 1
#if BLOCK_OPERATIONS>0
  #define __WRITE__(ad, obj) writeObject(ad,(obj))
  #define __READ__(ad, obj) readObject(ad,(obj))
#else
  #define __WRITE__(ad, obj) writeObjectSimple(0x57,ad,(obj))
  #define __READ__(ad, obj)  readObjectSimple(0x57,ad,(obj))
#endif
#define MEM_ADDR_MULTI 3458
//This is the structure we write and read from EEPROM
class MyData{
      long result;
public:
      float  f1;
      float  f2;
      double f3;
      int    i1;
      long   i2;
      long   i3;
      bool  negative;
      long getResult(){
            return result;
      long calcResult(){
            //makes a calculation with its data
            //and stores the result to a private variable
            long    i = (i2+i3)/i1;
            double  f = f3/(f1+f2);
            result = f/i;
            //round off
            result += result>0 ? 0.5 : -0.5;
            if (negative) result=-result;
            return result;
      MyData() : result(0){   }
void setup(){
      Wire.begin();
      MyData data[5];
      //data[0] - result should be 20
      data[0].i1 = 10;
      data[0].i2 = 150000;
      data[0].i3 = 350000;
      data[0].f1 = 0.5;
      data[0].f2 = 2.5;
      data[0].f3 = 3.0E+6;
      data[0].negative = false;
      //data[1] - result should be -40
      data[1].i1 = data[0].i1;
      data[1].i2 = data[0].i2;
      data[1].i3 = data[0].i3;
      data[1].f1 = data[0].f1;
      data[1].f2 = data[0].f2;
      data[1].f3 = 2*data[0].f3;
      data[1].negative = true;
      //data[2] - result should be 80
      data[2].i1 = data[0].i1;
      data[2].i2 = data[0].i2;
      data[2].i3 = data[0].i3;
      data[2].f1 = data[0].f1;
      data[2].f2 = data[0].f2;
      data[2].f3 = 4*data[0].f3;
      data[2].negative = false;
      //data[3] - result should be -20
      data[3].i1 = data[0].i1;
      data[3].i2 = -data[0].i2;
      data[3].i3 = -data[0].i3;
      data[3].f1 = data[0].f1;
      data[3].f2 = data[0].f2;
      data[3].f3 = data[0].f3;
      data[3].negative = false;
      //data[4] - result should be -2
      data[4].i1 = data[0].i1;
      data[4].i2 = -data[0].i2;
      data[4].i3 = -data[0].i3;
      data[4].f1 = data[0].f1*10;
      data[4].f2 = data[0].f2*10;
      data[4].f3 = -data[0].f3;
      data[4].negative = true;
      Serial.println ("Data before writing to eeprom");
      for (int i=0; i<5; i++){
            data[i].calcResult();
            Serial.print("data-"); Serial.print(i);
            Serial.print(": result = ");
            Serial.println(data[i].getResult());
      Serial.print("Size of each object: ");
      Serial.println(sizeof(MyData)) ;
      Serial.println ("Writing data to eeprom");
      int memaddr = MEM_ADDR_MULTI;
      long t0 = millis();
            memaddr += __WRITE__(memaddr, data[i]);
      long t1 = millis();
      Serial.print ("...writing finished. Elapsed time: ");
      Serial.println(t1-t0);
      Serial.println ("Reading data from eeprom");
      MyData read[5];
      t0 = millis();
            memaddr += __READ__(memaddr, read[i]);
      t1 = millis();
      Serial.print ("Time to read: "); Serial.println(t1-t0);
            Serial.print ("Read object: #");
            Serial.println(i);
            long storedResult = read[i].getResult();
            Serial.print ("  >stored result = ");
            Serial.println(storedResult);
            long newResult = read[i].calcResult();
            Serial.print ("  >recalculated result = ");
            Serial.println(newResult);
            if (storedResult== newResult &&
                  storedResult==data[i].getResult() )
                  Serial.println ("SUCCESS");
            else  Serial.println ("FAIL");
here the serial ouput after test CAT24C32
