Library
Hallo.
How can i the IRremote.h file put in the Arduino-library so i can use this program?
Thanks,
Jack.
#include <IRremote.h>
int RECV_PIN = 11;
IRrecv irrecv(RECV_PIN);
decode_results results;
irrecv.enableIRIn(); // Start the receiver
if (irrecv.decode(&results)) {
Serial.println(results.value, HEX);
irrecv.resume(); // Receive the next value
you have the "IRemote.h" and "IRemote.cpp" files already, right? just copy them to the arduino libraries folder as follows: Make an "IRemote" directory inside of the "libraries" sub-directory of your sketchbook directory. Copy IRemote.h and IRemote.cpp files into that directory. Open Arduino. Go to the Sketch >> Import Library menu, you should see IRemote inside, select it. The library will be compiled.
Hallo giantsfan3. Thanks for the reply. I have the "IRemote.h" and a "IRemoteInt.h" but no "IRemote.cpp"file. Can i make this "IRemote.cpp" file with a C++ program and what is in this file? Can i copy the "IRemote.h" or my RC5 program in this new file? Jack.
Here's the drill, starting from scratch:
  • Download IRremote.zip from Ken Sharriff's blog web site.
  • Put IRremote.zip in the libraries subdirectory of your sketchbook directory and unzip it. This creates the directories that hold the library files and the examples of the IRremote library.
  • Start Arduino.
  • Look at the examples in the IRremote library. Compile them. See how it goes.
  • When you write your own sketch, use the Sketch->Import Library menu and select IRremote to let your sketch use the IRremote functions. Note that, actually, there are two library headers that are #included.
Regards,
Dave
Hi davekw7x. Thanks for your answer. It seems to work. Best regards, Jack.
