Library's not included in command line compile
Hello,
I need to compile and upload programs via the command line. This works most of the time, but when a program uses an added library the library files aren’t included. The same file compiles fine through the IDE. Is there a way for command line compiles to have access to the libraries added in the IDE?
The command I’m using is like:
Arduino.exe --upload --verbose --port COM6 --board arduino:avr:nano file.ino
Thanks for any insight!
I've never used Arduino from the command-line, but a quick search yielded this:-
--install-library library name[:version]
More info here:- ARDUINO(1)
I just uploaded a sketch that includes a bunch of different libraries via command line with Arduino IDE 1.6.6 and it worked fine. Are you using an old version of the IDE?
I was using a slightly older version of the software, after an upgrade it seems to be working. Thanks for the replies!
