Ciao a tutti.
non riesco a compilare questo dannato sketch
* IRremote: IRtest unittest
* Version 0.1 July, 2009
* Copyright 2009 Ken Shirriff
* http://arcfn.com
* Note: to run these tests, edit IRremote/IRremote.h to add "#define TEST"
* You must then recompile the library by removing IRremote.o and restarting
* the arduino IDE.
#include <IRremote.h>
#include <IRremoteInt.h>
// Dumps out the decode_results structure.
// Call this after IRrecv::decode()
// void * to work around compiler issue
//void dump(void *v) {
// decode_results *results = (decode_results *)v
void dump(decode_results *results) {
int count = results->rawlen;
if (results->decode_type == UNKNOWN) {
Serial.println("Could not decode message");
else {
if (results->decode_type == NEC) {
Serial.print("Decoded NEC: ");
else if (results->decode_type == SONY) {
Serial.print("Decoded SONY: ");
else if (results->decode_type == RC5) {
Serial.print("Decoded RC5: ");
else if (results->decode_type == RC6) {
Serial.print("Decoded RC6: ");
Serial.print(results->value, HEX);
Serial.print(" (");
Serial.print(results->bits, DEC);
Serial.println(" bits)");
Serial.print("Raw (");
Serial.print(count, DEC);
Serial.print("): ");
for (int i = 0; i < count; i++) {
if ((i % 2) == 1) {
Serial.print(results->rawbuf[i]*USECPERTICK, DEC);
else {
Serial.print(-(int)results->rawbuf[i]*USECPERTICK, DEC);
Serial.print(" ");
Serial.println("");
IRrecv irrecv(0);
decode_results results;
class IRsendDummy :
public IRsend
public:
// For testing, just log the marks/spaces
#define SENDLOG_LEN 128
int sendlog[SENDLOG_LEN];
int sendlogcnt;
IRsendDummy() :
IRsend() {
void reset() {
sendlogcnt = 0;
void mark(int time) {
sendlog[sendlogcnt] = time;
if (sendlogcnt < SENDLOG_LEN) sendlogcnt++;
void space(int time) {
sendlog[sendlogcnt] = -time;
// Copies the dummy buf into the interrupt buf
void useDummyBuf() {
int last = SPACE;
irparams.rcvstate = STATE_STOP;
irparams.rawlen = 1; // Skip the gap
for (int i = 0 ; i < sendlogcnt; i++) {
if (sendlog[i] < 0) {
if (last == MARK) {
// New space
irparams.rawbuf[irparams.rawlen++] = (-sendlog[i] - MARK_EXCESS) / USECPERTICK;
last = SPACE;
else {
// More space
irparams.rawbuf[irparams.rawlen - 1] += -sendlog[i] / USECPERTICK;
else if (sendlog[i] > 0) {
if (last == SPACE) {
// New mark
irparams.rawbuf[irparams.rawlen++] = (sendlog[i] + MARK_EXCESS) / USECPERTICK;
last = MARK;
else {
// More mark
irparams.rawbuf[irparams.rawlen - 1] += sendlog[i] / USECPERTICK;
if (irparams.rawlen % 2) {
irparams.rawlen--; // Remove trailing space
IRsendDummy irsenddummy;
void verify(unsigned long val, int bits, int type) {
irsenddummy.useDummyBuf();
irrecv.decode(&results);
Serial.print("Testing ");
Serial.print(val, HEX);
if (results.value == val && results.bits == bits && results.decode_type == type) {
Serial.println(": OK");
else {
Serial.println(": Error");
dump(&results);
void testNEC(unsigned long val, int bits) {
irsenddummy.reset();
irsenddummy.sendNEC(val, bits);
verify(val, bits, NEC);
void testSony(unsigned long val, int bits) {
irsenddummy.sendSony(val, bits);
verify(val, bits, SONY);
void testRC5(unsigned long val, int bits) {
irsenddummy.sendRC5(val, bits);
verify(val, bits, RC5);
void testRC6(unsigned long val, int bits) {
irsenddummy.sendRC6(val, bits);
verify(val, bits, RC6);
void test() {
Serial.println("NEC tests");
testNEC(0x00000000, 32);
testNEC(0xffffffff, 32);
testNEC(0xaaaaaaaa, 32);
testNEC(0x55555555, 32);
testNEC(0x12345678, 32);
Serial.println("Sony tests");
testSony(0xfff, 12);
testSony(0x000, 12);
testSony(0xaaa, 12);
testSony(0x555, 12);
testSony(0x123, 12);
Serial.println("RC5 tests");
testRC5(0xfff, 12);
testRC5(0x000, 12);
testRC5(0xaaa, 12);
testRC5(0x555, 12);
testRC5(0x123, 12);
Serial.println("RC6 tests");
testRC6(0xfffff, 20);
testRC6(0x00000, 20);
testRC6(0xaaaaa, 20);
testRC6(0x55555, 20);
testRC6(0x12345, 20);
test();
ho messo la libreria scaricata da github in \Arduino\arduino-1.0.5\libraries\IRremote
compilando mi escono i seguenti messaggi:
IRremote\IRremote.cpp.o: In function
MATCH(int, int)': /IRremoteInt.h:176: multiple definition of
MATCH(int, int)'
sketch_dec09a.cpp.o:F:\personale\Arduino\arduino-1.0.5\libraries\IRremote/IRremoteInt.h:176: first defined here
IRremote\IRremote.cpp.o: In functionMATCH_MARK(int, int)': /IRremoteInt.h:177: multiple definition of
sketch_dec09a.cpp.o:F:\personale\Arduino\arduino-1.0.5\libraries\IRremote/IRremoteInt.h:177: first defined here
IRremote\IRremote.cpp.o: In functionMATCH_SPACE(int, int)': /IRremoteInt.h:178: multiple definition of
sketch_dec09a.cpp.o:F:\personale\Arduino\arduino-1.0.5\libraries\IRremote/IRremoteInt.h:178: first defined here
Ringrazio qualunque anima pia intenda aiutarmi.
