LibreRTOS with SAMD21
Hi
I am trying to use the LibreRTOS on a SAMD21. It has examples for the ATMEGA382 but not for the SAMD21. This piece of code is what is confusing to me as I dont have much experience with assembler anymore.
What are they storing for recovery later and how would I do that on the SAMD21 chip.
Any insights welcome here.
/* Nested critical section management macros. */
#define CRITICAL_VAL()   uint8_t __istate_val
#define CRITICAL_ENTER() __asm __volatile( \
        "in %0, __SREG__ \n\t"             \
        "cli             \n\t"             \
        :"=r" (__istate_val) ::"memory")
#define CRITICAL_EXIT()  __asm __volatile( \
        "out __SREG__, %0 \n\t"            \
        ::"r" (__istate_val) :"memory")
An operating system designed to run on the AVRs isn't likely to run on ARM without a fair amount of attention. (that said, it looks like there is very little that is actually CPU dependent in libreRTOS. You can try:
#define CRITICAL_VAL()   uint32_t __istate_val
#define CRITICAL_ENTER() __istate_val = __disable_irq();
#define CRITICAL_EXIT()  if (!__istate_val) __enable_irq();
See http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.dui0491h/CJAFBCBB.html
