Link zum Porgramm: http://www.vixenlights.com/downloads.html
Plugins: sind alle normalerweise dabei
Testdatei für Vixen mit 5 Kanälen: Im Anhang Testdatei5Kanäle.vix
Testdatei für Vixen mit 7 Kanälen: Im Anhang Testdatei7Kanäle.vix
Code für die Ansteuerung von 5 Kanälen:
The purpose of this code is to allow the Arduino to use the
generic serial output of vixen lights to control 5 channels of LEDs.
Author: Matthew Strange
Created: 14 October 2010
// Output
int Channel1 = 48; // red LED, connected to digital pin 5
int Channel2 = 46; // green LED, connected to digital pin 6
int Channel3 = 44; // red LED, connected to digital pin 9
int Channel4 = 42; // green LED, connected to digital pin 10
int Channel5 = 40; // red LED, connected to digital pin 11
int i = 0; // Loop counter
int incomingByte[5]; // array to store the 7 values from the serial port
//setup the pins/ inputs & outputs
Serial.begin(9600); // set up Serial at 9600 bps
pinMode(Channel1, OUTPUT); // sets the pins as output
pinMode(Channel2, OUTPUT);
pinMode(Channel3, OUTPUT);
pinMode(Channel4, OUTPUT);
pinMode(Channel5, OUTPUT);
{ // 7 channels are coming in to the Arduino
if (Serial.available() >= 5) {
// read the oldest byte in the serial buffer:
for (int i=0; i<6; i++) {
// read each byte
incomingByte[i] = Serial.read();
digitalWrite(Channel1, incomingByte[0]); // Write current values to LED pins
digitalWrite(Channel2, incomingByte[1]); // Write current values to LED pins
digitalWrite(Channel3, incomingByte[2]); // Write current values to LED pins
digitalWrite(Channel4, incomingByte[3]); // Write current values to LED pins
digitalWrite(Channel5, incomingByte[4]);
Code für die Ansteuerung von 7 Kanälen:
// Output
int Channel6 = 38; // green LED, connected to digital pin 10
int Channel7 = 36;
int incomingByte[7]; // array to store the 7 values from the serial port
pinMode(Channel6, OUTPUT);
pinMode(Channel7, OUTPUT);
if (Serial.available() >= 7) {
for (int i=0; i<8; i++) {
// read each byte
digitalWrite(Channel6, incomingByte[5]); // Write current values to LED pins
digitalWrite(Channel7, incomingByte[6]); // Write current values to LED pins
So ich hoffe das ich jetzt alles habe....
Ich hoffe ihr probiert das für mich aus !
Testdatei5Kanäle.vix (5.18 KB)
Testdatei7Kanäle.vix (6.92 KB)
