Lidar lite + GPS + SD card
I’m trying to log on an SD card data from GPS and Lidar and I’m having trouble with opening file and write to it. Here is my code:
#include <SD.h>
#include <SPI.h>
#include <Wire.h>
#include <LIDARLite.h>
#include <LIDARLite_v3HP.h>
#include <Adafruit_GPS.h>
#include <SoftwareSerial.h>
SoftwareSerial mySerial(8, 7);
Adafruit_GPS GPS(&mySerial);
// Set GPSECHO to 'false' to turn off echoing the GPS data to the Serial console
// Set to 'true' if you want to debug and listen to the raw GPS sentences.
#define GPSECHO  true
// this keeps track of whether we're using the interrupt
// off by default!
boolean usingInterrupt = false;
void useInterrupt(boolean); // Func prototype keeps Arduino 0023 happy
const int chipSelect = 10;
LIDARLite myLidarLite;
  // connect at 115200 so we can read the GPS fast enough and echo without dropping chars
  // also spit it out
  Serial.println("Adafruit GPS library basic test!");
  //initializare card
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  Serial.print("Initializing SD card...");
  // see if the card is present and can be initialized:
  if (!SD.begin(chipSelect)) {
    Serial.println("Card failed, or not present");
    // don't do anything more:
    while (1);
  Serial.println("card initialized.");
  myLidarLite.begin();
  // 9600 NMEA is the default baud rate for Adafruit MTK GPS's- some use 4800
  GPS.begin(9600);
  // uncomment this line to turn on RMC (recommended minimum) and GGA (fix data) including altitude
  GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCGGA);
  // uncomment this line to turn on only the "minimum recommended" data
  //GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCONLY);
  // For parsing data, we don't suggest using anything but either RMC only or RMC+GGA since
  // the parser doesn't care about other sentences at this time
  // Set the update rate
  GPS.sendCommand(PMTK_SET_NMEA_UPDATE_1HZ);   // 1 Hz update rate
  // For the parsing code to work nicely and have time to sort thru the data, and
  // print it out we don't suggest using anything higher than 1 Hz
  // Request updates on antenna status, comment out to keep quiet
  GPS.sendCommand(PGCMD_ANTENNA);
  // the nice thing about this code is you can have a timer0 interrupt go off
  // every 1 millisecond, and read data from the GPS for you. that makes the
  // loop code a heck of a lot easier!
  useInterrupt(true);
  // Ask for firmware version
  mySerial.println(PMTK_Q_RELEASE);
// Interrupt is called once a millisecond, looks for any new GPS data, and stores it
SIGNAL(TIMER0_COMPA_vect) {
  char c = GPS.read();
  // if you want to debug, this is a good time to do it!
#ifdef UDR0
  if (GPSECHO)
    if (c) UDR0 = c;
    // writing direct to UDR0 is much much faster than Serial.print
    // but only one character can be written at a time.
#endif
void useInterrupt(boolean v) {
  if (v) {
    // Timer0 is already used for millis() - we'll just interrupt somewhere
    // in the middle and call the "Compare A" function above
    OCR0A = 0xAF;
    TIMSK0 |= _BV(OCIE0A);
    usingInterrupt = true;
    // do not call the interrupt function COMPA anymore
    TIMSK0 &= ~_BV(OCIE0A);
uint32_t timer = millis();
void loop()                     // run over and over again
  // in case you are not using the interrupt above, you'll
  // need to 'hand query' the GPS, not suggested :(
  if (! usingInterrupt) {
    // read data from the GPS in the 'main loop'
    if (GPSECHO)
      if (c) Serial.print(c);
  // if a sentence is received, we can check the checksum, parse it...
  if (GPS.newNMEAreceived()) {
    // a tricky thing here is if we print the NMEA sentence, or data
    // we end up not listening and catching other sentences!
    // so be very wary if using OUTPUT_ALLDATA and trytng to print out data
    //Serial.println(GPS.lastNMEA());   // this also sets the newNMEAreceived() flag to false
    if (!GPS.parse(GPS.lastNMEA()))   // this also sets the newNMEAreceived() flag to false
      return;  // we can fail to parse a sentence in which case we should just wait for another
  // if millis() or timer wraps around, we'll just reset it
  if (timer > millis())  timer = millis();
  // approximately every 2 seconds or so, print out the current stats
  if (millis() - timer > 2000) {
    timer = millis(); // reset the timer
    Serial.print("\nTime: ");
    Serial.print(GPS.hour, DEC); Serial.print(':');
    Serial.print(GPS.minute, DEC); Serial.print(':');
    Serial.print(GPS.seconds, DEC); Serial.print('.');
    Serial.println(GPS.milliseconds);
    Serial.print("Date: ");
    Serial.print(GPS.day, DEC); Serial.print('/');
    Serial.print(GPS.month, DEC); Serial.print("/20");
    Serial.println(GPS.year, DEC);
    Serial.print("Fix: "); Serial.print((int)GPS.fix);
    Serial.print(" quality: "); Serial.println((int)GPS.fixquality);
    Serial.print("Distance: "); Serial.println(myLidarLite.distance());
    if (GPS.fix) {
      Serial.print("Location: ");
      Serial.print(GPS.latitude, 4); Serial.print(GPS.lat);
      Serial.print(", ");
      Serial.print(GPS.longitude, 4); Serial.println(GPS.lon);
      Serial.print("Location (in degrees, works with Google Maps): ");
      Serial.print(GPS.latitudeDegrees, 4);
      Serial.print(", ");
      Serial.println(GPS.longitudeDegrees, 4);
      Serial.print("Speed (knots): "); Serial.println(GPS.speed);
      Serial.print("Angle: "); Serial.println(GPS.angle);
      Serial.print("Altitude: "); Serial.println(GPS.altitude);
      Serial.print("Satellites: "); Serial.println((int)GPS.satellites);
    String dataString = "";
    dataString = String(myLidarLite.distance()); //I only put distance here for testing but I have to log GPS data too
    // open the file. note that only one file can be open at a time,
    // so you have to close this one before opening another.
    File dataFile = SD.open("datalog.txt", FILE_WRITE);
    // if the file is available, write to it:
    if (dataFile) {
      dataFile.println(dataString);
      dataFile.close();
      // print to the serial port too:
      Serial.println(dataString);
    // if the file isn't open, pop up an error:
    else {
      Serial.println("error opening datalog.txt");
It doesn’t write anything on SD card and blocks after showing distance on monitor
Get all the pieces of the project working individually, before putting them together.
Most likely your problem is due to a combination of the first two issues below:
  1. Use of Strings, especially as in the lines below, will eventually cause memory problems and program crashes. Strings are completely unnecessary for this project, so get rid of them.
  1. Especially in a time-critical situation, it is a bad idea to open the SD card file, write one line, and close the file. Open the file once in setup() and close it before the program is terminated.
    if (dataFile) {
      dataFile.close();
  1. This is not necessary or useful.
I tried the thongs you said with no success. This is my code without trying to write on SD.
#include <SD.h>
#include <SPI.h>
#include <Wire.h>
// off by default!
  // also spit it out
  //initializare card
  while (!Serial) {
    while (1);
  GPS.begin(9600);
  useInterrupt(true);
#ifdef UDR0
  if (GPSECHO)
    if (c) UDR0 = c;
#endif
  if (v) {
    OCR0A = 0xAF;
    if (GPSECHO)
    if (GPS.fix) {
      Serial.print(", ");
      Serial.print(", ");
it shows all the things I need but I have to write them on a file on SD card and I cant figure it out.
I also have code to to write distance and code to write GPS data but they are on separate files and I can’t figure out how to combine them. It fails whatever I tried.
What I said was:
Find or write a simple example program to test basic SD card functions, get that working perfectly and make sure you understand it, before doing anything else.
so I’ve started from a blank file and built slowly, I got it working to log my distance but when I try to write the gps code it stops opening file. here is what I have:
#include <Wire.h>
#include <SPI.h>
#include <SD.h>
File myFile;
  while (!Serial) {
  if (!SD.begin(10)) {
    Serial.println("initialization failed!");
    while (1);
  Serial.println("initialization done.");
  myLidarLite.begin(0, true);
  myLidarLite.configure(0);
  GPS.begin(9600);
//  GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCONLY);
  // nothing happens after setup
    myFile = SD.open("test.txt", FILE_WRITE);
    // if the file opened okay, write to it:
    if (myFile) {
      Serial.print("Writing to test.txt...");
      myFile.println("Distance: " + String(myLidarLite.distance()));
      // close the file:
      myFile.close();
      Serial.println("done.");
      // if the file didn't open, print an error:
      Serial.println("error opening test.txt");
    // re-open the file for reading:
    myFile = SD.open("test.txt");
    if (myFile) {
      Serial.println("test.txt:");
      // read from the file until there's nothing else in it:
      while (myFile.available()) {
        Serial.write(myFile.read());
      // close the file:
      myFile.close();
this code works and it logs distance, after GPS.begin(9600); If I uncomment that line it stops working, unable to open the file.
Your project will not work if you continue to ignore the advice given in reply #1.
Those may not be the only problems, though.
