Lier un esp32 a un émulateur
bonjour
Pour un projet de fac , je dois lier un esp32 (Heltec wifi kit) a un émulateur nes
le code fonctionne , il écrit les chiffres demander mais lorsque je veux créer les inputs dans émulateur , ce dernier ne reconnais pas la pression sur la touche.
voici mon code :
// Basic demo for accelerometer readings from Adafruit MPU6050
#include <Adafruit_MPU6050.h>
#include <Adafruit_Sensor.h>
#include <Wire.h>
#include <WiiChuck.h>
#include <BleKeyboard.h>
#include "Adafruit_Sensor_Calibration.h"
#include "GY521.h"
GY521 sensor(0x68);
uint32_t counter = 0;
// select either EEPROM or SPI FLASH storage:
#ifdef ADAFRUIT_SENSOR_CALIBRATION_USE_EEPROM
  Adafruit_Sensor_Calibration_EEPROM cal;
#else
  Adafruit_Sensor_Calibration_SDFat cal;
#endif
pin scl->c->22
pin sda->z->21
BleKeyboard bleKeyboard;
Accessory nunchuck;
Adafruit_MPU6050 mpu;
   Wire.begin(21, 22, 100000); // sda, scl, clock speed
   Wire.write(0x6B);  // PWR_MGMT_1 register
   Wire.write(0);     // set to zero (wakes up the MPU−6050)
   Wire.endTransmission(1);
   Serial.println("Setup complete");
  bleKeyboard.begin();
	nunchuck.begin();
  mpu.begin();
	if (nunchuck.type == Unknown) {
		nunchuck.type = NUNCHUCK;
   //  set calibration values from calibration sketch.
  sensor.axe = 0.574;
  sensor.aye = -0.002;
  sensor.aze = -1.043;
  sensor.gxe = 10.702;
  sensor.gye = -6.436;
  sensor.gze = -0.676;
    sensor.read();
  float x = sensor.getAngleX();
  float y = sensor.getAngleY();
  float z = sensor.getAngleZ();
    nunchuck.readData();    // Read inputs and update maps
  Serial.println(x);
  Serial.println(z);
  // Serial.print("X: ");
  // Serial.print(nunchuck.getAccelX());
  // Serial.print(" \tY: "); Serial.print(nunchuck.getAccelY());
  // Serial.print(" \tZ: "); Serial.println(nunchuck.getAccelZ());
  // Serial.print("Joy: (");
  // Serial.print(nunchuck.getJoyX());
  // Serial.print(nunchuck.getJoyY());
  Serial.print("Button: ");
  if (nunchuck.getButtonZ()) Serial.print(" Z ");
  if (nunchuck.getButtonC()) Serial.print(" C ");
  delay(100);
//touche du clavier en fonction des condition
if(nunchuck.getJoyY()< 70) {
      bleKeyboard.press(KEY_NUM_0);
       bleKeyboard.releaseAll();
       Serial.print("waza1");}
    delay(50);
if(nunchuck.getJoyX() > 180) {
      bleKeyboard.press(KEY_NUM_1);
       Serial.print("waza2");}
    delay(50);
if(nunchuck.getJoyY()>180) {
      bleKeyboard.press(KEY_NUM_3);
       Serial.print("waza3");}
    delay(50);
if(nunchuck.getJoyX() < 70) {
      bleKeyboard.press(KEY_NUM_4);
       Serial.print("waza4");}
    delay(50);
if(nunchuck.getButtonC()) {
      bleKeyboard.press(KEY_NUM_5);
       Serial.print("waza5");delay(50);}
if(nunchuck.getButtonZ()) {
      bleKeyboard.press(KEY_NUM_6);
       Serial.print("waza6");delay(50);    }
if(z<-15) {
      bleKeyboard.press(KEY_NUM_2);
       Serial.print("waza7");delay(50);}
if( x<0) {
      bleKeyboard.press(KEY_NUM_7);
       Serial.print("waza8");}
    delay(50);
if(x>90) {
      bleKeyboard.press(KEY_NUM_8);
       Serial.print("waza9");}
    delay(50);
if(z>-5) {
      bleKeyboard.press(KEY_NUM_9);
       Serial.print("waza");
    delay(50); }
  delay(200);
Merci par avance pour votre aide
Quel émulateur ? Quelle touche ?
salut!
est-ce que par hasard:
  • tu reçois correctement les données d'accélération?
  • tu reçois correctement les données du gyroscope?
  • tu n'arrives pas à faire remonter les appuis sur les touches "c" et "z" alors que tout le reste fonctionne parfaitement (genre au hasard, les valeurs restent à zéro dans l'arduino malgré les manipulations sur le nunchuck?)
salut, les questions de mon dernier post étaient en lien avec un autre utilisateur qui utilise un clone de ton code.
pour le coup il a trouvé la solution en supprimant les nombreux delay();
à noter que les delay sont en dehors des nombreux "if" du code, ce qui n'est pas l'objectif à mon avis, essaie plutot ça (juste le } à déplacer):
if( x<0) {
    delay(50); }
de cette manière, chaque appui de touche provoque une petite pause dans le code, afin de voir l'action sur la touche. dans l'état actuel, ton code cumule les delay(50);
