Life-like movement
Is there a way to program a servo so the delay causes it to pick up speed or reduce speed as it moves to the position?
In 3d animation terms you would have to add curves to a body movement for it to look like natural human motion.
The delays below would control the servo arm speed but at a steady rate.
Is there any code that lets you pick a motion curve for each movement along with the speed?
 // Sweep from 0 to 180 degrees:
  for (angle = 0; angle <= 180; angle += 1) {
    myservo.write(angle);
    delay(15);
  // And back from 180 to 0 degrees:
  for (angle = 180; angle >= 0; angle -= 1) {
    delay(30);
Any function that has the output 0 to 180 can be used, or a lookup table.
An input 0 to whatever, the function gives output of servo position.
Like
servoPosition = 180 * sin(pi/2 * t);
Would make a certain motion as t goes form 0 to 1.
a7
You could have a look at that library
