Life
Some may get it, others may not. Either way, have a good day guys
  int life ();
  if (life == long) {
    life = 1;
  else {
    life = 0;
  delay (1000);
Laugh? I thought I'd never start.
"life" not in scope in function "loop"
There is a few things I was hoping people would take away from this.
first being life - only run once second - life is not defined... "what is the meaning of life" (the first error you get out of this code.) third - there are a lot of problems in life. (if you try and run this code, it WILL error out) forth - life is long. fifth - if long life is not true then end... do not repeat. sixth - life can change at any second
Thinking about this one again, the “int life ();” in setup is just a prototype, so “life” probably is in scope in loop too, if it’s declared at all.
We don’t know that.
Unless your name is Mo Farah.
“Unless your name is Mo Farah.”
Or Frankenstien or you are a cursed mummy or a zombie
to make an engineer laugh or think or both, you need something that works :)
well technically as it stands, it does not run at all... no life.. I guess that's what you say to those who spend their day in front of their screen :)
Is life a function that hasn't been declared anywhere, or is that a failed variable declaration?
That's only about 9 hours of life even if the variable/function/whateverit'ssupposedtobe was proper.
