I make props and models for Film and TV I'm currently doing a lift inertia and creating a panel to show the lift is moving. I'm looking for someone that can write the code for me, this will be paid.
We need a TFT display that will show a background image and scroll numbers in front of the background.
I’m looking at using something like this:
And an Arduino Uno
and I would want 2 push buttons to control the action and also 2 relays. This is what needs to happen:
Power on
Screen displays company logo and “loading” bar
Background image appears on screen
Letter “G” appears
a. If button 1 is pushed:
i. “G” scrolls down – top to bottom – and number “1” comes into view
ii. Relay 1 should activate whilst the text is scrolling downb. If Button 2 is pushed:
i. “G” scrolls Up – bottom to top – and number “-1” comes into view
ii. Relay 2 should activate whilst the text is scrolling up -
This needs to be able to continue infinitely either counting up or down when either button is pushed.
Do you think this all sounds achievable ?
We may need to add some functions, for example a long press of button 1 will jump up 10 numbers, a long press of button 2 will jump down 10 numbers, a long press of both buttons at the same time will reset back to “G”. Something along those lines.
I will need to able in the code to easily adjust the background image, the font and colour of the numbers and the scrolling speed. And the time the relays are activated for
If you could also let me know how much it will cost for you to write this code.
Many thanks,
James Churches
