Thanks George,
Proving my point - I'm the idiot for asking the question, because I can't possibly know anything to ask such a simple question. I stated I'm not looking for you to design or advise on all safety matters. Perhaps you are right that without all the details the site is useless because those responding assume someone asking for help couldn't grasp Pin states, High and Low, On or Off. Why push a button when you have a sensor in place that acts as that button, automatically?
Thanks Tom,
Truth of the matter is I'm not technical, use of wrong nomenclature is worse than lack of details. I know a LED means different things to different people, what LED (size, color, voltage etc.) needs to be considered (by me not you), and not required for a response. Nor is the type or specs on the sensor, or interface it is using to send its inbound signal to the computer (as well as type or make of the computer or OS). What is important is for the response to be structured in Plain language as the question was written. It's my system (project) and as such my responsibility for testing and construction not the responders should I want to use it. I reread my post and feel it was written to convey the fact I know what the Uno board is capable of (just not who to do it), that I have sensors (type, brand, speed etc.) is not relevant other than they send a signal (inbound) to my computer and that signal is sufficiently received and understood to trigger a routine in the software but does not include the capability to trigger an Outbound Pin state, because it is not written into the software. Simply, and I chose it vice Basic, because of previous reference to BASIC being reason for explanation the Arduino is not programed in BASIC. I'm trying to turn On/Off a LED from the Pin state change of a sensor.
A PHIDGET 1012 BOARD (Inbound Pin) receives the signal from the DS Electronics Light bridge (housing the light sensing circuit). No, I don't know the sender or receiving elements used in it, but clearly stated it is working flawlessly. Again, providing all this information serves only to lengthen the post because has no bearing on a reply. Now for fuller disclosure the project is to create a visible indicator (LED) when a Slot Car enters the pit area on a 1/32nd scale Policar Track system that via the Ultimate Racer Timing software provides 1/1000th of a second timing, with Pit Stop functions. Because the Pit area is also part of the normal lap circuit, a 500ms (1/2 sec) delay is required on the sensor before the Fueling sequence starts to distinguish it from the passing on a normal lap, the need for a visible signal to indicate the car is in position (in Pit Area).
Again, the question requires NOTHING explained here for consideration of a reply. I tried to research an answer and hesitated posting because most responders are more interested in professing their knowledge than helping and example from Arduino Learning are written by Tech's in Tech language or not applicable.
Thanks for the time and advice but keep it simple, make it fun.
| TomGeorge Jackson
June 11 |
Hi, @Pepsikid51
Welcome to the forum.
How to get the best out of this forum IDE 1.x
See also FAQ - Arduino Forum for general rules on forum behavior and etiquette. Hello, Welcome to the Arduino Forum. This guide explains how to get the best out of this forum. Please read and follow the instructions below. Being new here you might think this is having rules for the sake of rules, but that is not the case. If you don’t follow the guidelines all that happens is there is a long exchange of posts while we try to get you to tell us what we need in order to help you, which is frus…
Can you please post the code you have?
What model Arduino controller are you using?
Can you please post a link to spec/data of the Bridge.
Thanks.. Tom..
