I am novice with arduino and I need your help. I am using light and motion sencor, my plan is when is movement and not enaught light, then switch on lights. My problem is light are lighting but only afew sec then stop lighting and if is movement then again switch on, after about 1 sec. Where could be problem? Thanks Zdeněk Novotný
code:
#define LDR 0
int luz = 0;
int valor_sensor = 0;
int led = 3;
int sensor = 2;
int state = LOW;
int val = 0;
pinMode(LDR,INPUT);
pinMode(led, OUTPUT); // initalize LED as an output
pinMode(sensor, INPUT); // initialize sensor as an input
Serial.begin(9600); // initialize serial
valor_sensor = analogRead(LDR);
luz = (5.0 * valor_sensor * 100.0)/1024.0;
Serial.print(luz);
Serial.println(" Luz");
val = digitalRead(sensor);
if ( (luz <= 300) && (val == HIGH) ) {
digitalWrite(led, HIGH);
delay(300);}
if ( (luz <= 300) && (state == LOW) ) {
Serial.println(“Motion detected!”);
state = HIGH; // update variable state to HIGH
if (luz > 300) // NESVÍTÍ
digitalWrite(led, LOW);
else {
digitalWrite(led, LOW); // turn LED OFF
if (state == HIGH){
Serial.println(“Motion stopped!”);
state = LOW; // update variable state to LOW
code is mix of 2 codes at motion sencor and light sencor so please dont be scared, its my first own project.
