Light as a Feather RFID Reader SS Issues
Hey all,
So I’ve been trying to hook up a Adafruit PN532 breakout board to a adafruit M0 datalogging feather for the past week. All the proper connections are made, but the SPI select is on Pin 11. (It is in SPI mode) Another device on the SPI bus is a MicroSD card. I modified the example code to see if it would work and in the console I get “Hello” “TIMEOUT” (it says timeout but it isnt even in the code…?) then “Couldn’t find PN53X chip” Could I have a little help? Below is the modified example code. Thanks
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_PN532.h>
// If using the breakout with SPI, define the pins for SPI communication.
#define PN532_SS   (11)
// If using the breakout or shield with I2C, define just the pins connected
// to the IRQ and reset lines.  Use the values below (2, 3) for the shield!
#define PN532_IRQ   (2)
#define PN532_RESET (3)  // Not connected by default on the NFC Shield
// Uncomment just _one_ line below depending on how your breakout or shield
// is connected to the Arduino:
// Use this line for a breakout with a SPI connection:
//Adafruit_PN532 nfc(PN532_SCK, PN532_MISO, PN532_MOSI, PN532_SS);
// Use this line for a breakout with a hardware SPI connection.  Note that
// the PN532 SCK, MOSI, and MISO pins need to be connected to the Arduino's
// hardware SPI SCK, MOSI, and MISO pins.  On an Arduino Uno these are
// SCK = 13, MOSI = 11, MISO = 12.  The SS line can be any digital IO pin.
Adafruit_PN532 nfc(PN532_SS);
// Or use this line for a breakout or shield with an I2C connection:
//Adafruit_PN532 nfc(PN532_IRQ, PN532_RESET);
void setup(void) {
  #ifndef ESP8266
    while (!Serial); // for Leonardo/Micro/Zero
  #endif
  Serial.println("Hello!");
  nfc.begin();
  uint32_t versiondata = nfc.getFirmwareVersion();
  if (! versiondata) {
    Serial.print("Didn't find PN53x board");
    while (1); // halt
  // Got ok data, print it out!
  Serial.print("Found chip PN5"); Serial.println((versiondata>>24) & 0xFF, HEX);
  Serial.print("Firmware ver. "); Serial.print((versiondata>>16) & 0xFF, DEC);
  Serial.print('.'); Serial.println((versiondata>>8) & 0xFF, DEC);
  // configure board to read RFID tags
  nfc.SAMConfig();
  Serial.println("Waiting for an ISO14443A Card ...");
void loop(void) {
  uint8_t success;
  uint8_t uid[] = { 0, 0, 0, 0, 0, 0, 0 };  // Buffer to store the returned UID
  uint8_t uidLength;                        // Length of the UID (4 or 7 bytes depending on ISO14443A card type)
  // Wait for an ISO14443A type cards (Mifare, etc.).  When one is found
  // 'uid' will be populated with the UID, and uidLength will indicate
  // if the uid is 4 bytes (Mifare Classic) or 7 bytes (Mifare Ultralight)
  success = nfc.readPassiveTargetID(PN532_MIFARE_ISO14443A, uid, &uidLength);
  if (success) {
    // Display some basic information about the card
    Serial.println("Found an ISO14443A card");
    Serial.print("  UID Length: ");Serial.print(uidLength, DEC);Serial.println(" bytes");
    Serial.print("  UID Value: ");
    nfc.PrintHex(uid, uidLength);
    if (uidLength == 4)
      // We probably have a Mifare Classic card ...
      uint32_t cardid = uid[0];
      cardid <<= 8;
      cardid |= uid[1];
      cardid <<= 8;
      cardid |= uid[2];
      cardid <<= 8;
      cardid |= uid[3];
      Serial.print("Seems to be a Mifare Classic card #");
      Serial.println(cardid);
    Serial.println("");
The last bit of that comment is wrong. The SS line can be any UNUSED digital IO pin. Pins 11, 12, and 13 are already used.
The M0 feather I'm using has different SPI pins than the UNO or MICRO which this sketch is for, but I switched the SS line to pin 6 and it still doesnt work. Same result. 11,12,and 13 are not SPI lines.
Which pins ARE the SPI pins? Does the Adafruit_PN532 library know that?
then "Couldn't find PN53X chip"
I don't see anything in your code that prints THAT (exact) message.
it says timeout but it isnt even in the code...?
Are you forgetting that you are calling library functions, and that they can also print to the serial port?
So I've been trying to hook up a Adafruit PN532 breakout board to a adafruit M0 datalogging feather for the past week.
Just an opinion:
You pay a premium price to use Adafruit (or Sparkfun or any retailer) so you may wish to try their forum. Based on my experience with Adafruit, they are hit and miss more than here, but occasionally you do win the prize!
Ray
